Thread Tools Display Modes
Old 18th May 2010, 01:48   #8221  |  Link
PeteWalker74
Gran Torino out of sync issue at Chapter 18. The backup of the original Blu-Ray doesn't exhibit this issue. It goes to a sky-blue screen, before the chapter starts, throwing the audio out of sync.
This is a movie-only backup, BD5, using highest quality settings.
[09:25:25] BD Rebuilder v0.33.07 (beta)
  - Source:  GRAN_TORINO
  - Input BD size: 27.67 GB
  - Approximate total content: [01:56:34.779]
  - Target BD size: 4.27 GB
  - Windows Version: 6.1 [7600]
  - MOVIE-ONLY mode enabled
  - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[09:25:25] PHASE ONE, Encoding
 - [09:25:25] Extracting A/V streams [VID_00004]
 - [09:33:41] Reencoding: VID_00004 (1 of 1)
 - [09:33:41] Collecting video information
   - Source Video: VC-1, 1920x1080
   - Rate/Length: 23.976fps, 167,707 frames
   - Bitrate: 4,119 Kbs
 - [09:33:41] Reencoding: VID_00004, Pass 1 of 2
 - [11:00:39] Reencoding: VID_00004, Pass 2 of 2
 - [13:49:18] Video Encode complete
 - [13:49:18] Reencoding audio tracks (if req'd)
 - [13:50:34] Multiplexing M2TS
[13:52:05]PHASE ONE complete
[13:52:05]PHASE TWO - Rebuild Started
 - [13:52:05] Rebuilding AVCHD file Structure
[13:54:55] - Encode and Rebuild complete
[13:54:56]JOB: GRAN_TORINO finished.
And Inspect shows:
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter:  Ok
- FFDSHOW: 3326, Ok
- WIN7 preferred AVC CODEC:  Ok
- WIN7 preferred VC-1 CODEC:  Ok
- WIN7 preferred MPEG2 CODEC:  Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec":  Ok
- FFDSHOW AVC set to "libavcodec":  Ok
- BD Rebuilder v0.33.0.7, Ok
- X264:  Ok
- AFTEN:  Ok
- FAAC:  Ok
- MP4BOX:  Ok
- WAVI:  Ok
- TSMUXER:  Ok
Please let me know if there is a setting that is not correct, or some other issue (perhaps a bug) going on, or perhaps if I need to provide more information. Thank you so much.
PeteWalker74 is offline   Reply With Quote
Old 18th May 2010, 02:37   #8222  |  Link
cnote
cnote
Pete, I believe that the problem is actually in your rip of Gran Torino. I had the same issue with I Am Legend. I could see that during the exact timing of my audio lag, there was a minor flicker during a frame change in the original. For some reason it happens so fast in the original that the sequencing stays in tact. But, when I tried to encode it again the same issue happened. So I backed up a different copy of I Am Legend and it works fine. Hope it helps.
cnote is offline   Reply With Quote
Old 18th May 2010, 02:55   #8223  |  Link
PeteWalker74
I've ripped it twice, and still the same result. One before the latest version of AnyDVD HD, and one after, both with the same problem.
Old 18th May 2010, 03:07   #8224  |  Link
Priapismic
Try my suggestion Pete and I'll bet the results will be satisfactory.
Priapismic is offline   Reply With Quote
Old 18th May 2010, 05:09   #8225  |  Link
jdobbs
I can almost guarantee that what you are seeing is due to a bad rip... I've seen it before. AnyDVD is good, but it isn't perfect, sometimes there's a glitch. If you play back that section with MPC you'll very likely see that the "ski blue screen" issue is there before the encode. It is also what is causing the out-of-sync.
I've successfully backed up the US version of "Gran Torino".
jdobbs.softworks@gmail.com
Old 18th May 2010, 16:12   #8226  |  Link
PeteWalker74
Alright, fair enough. I don't have a problem with backing it up again. It's just weird that if I play the rip, it plays fine around that area, so it doesn't make sense that the rip is bad. That being said, I have no problem with ripping it again, and giving it another go. I let a friend borrow it, but once I get it back, I'll try once again. Thanks, fellas.
Old 18th May 2010, 16:43   #8227  |  Link
anger98
Issue with x264 - check attachment and log
I use to encode my BD manually with FFmpeg but thanks to Dark Shikari I decided to give try to this solution, sadly I found that for some reason x264.exe is crashing on my sistem, I'm using Win7 x64 v6.1.7600 with exactly the software recomended on the post, here is my log on the error (see the picture):
[09:34:46] BD Rebuilder v0.33.07 (beta)
- Source: MYHDMOVIE
- Input BD size: 41.73 GB
- Approximate total content: [04:33:35.740]
- Target BD size: 7.72 GB
- Auto Quality: High Quality (Default), Two Pass
[09:34:46] PHASE ONE, Encoding
- [09:34:46] Extracting A/V streams [VID_00345]
- [09:34:46] Reencoding: VID_00345 (1 of 70)
- [09:34:46] Collecting video information
- Rate/Length: 23.976fps, 240 frames
- [09:34:46] Reencoding: VID_00345, Pass 1 of 1
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.33.07 (beta)
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[09:35:04] - Failed video encode, aborted
anger98 is offline   Reply With Quote
Old 18th May 2010, 16:53   #8228  |  Link
doffot
Help
re encode full blu-ray Armageddon fail in sony bd350
black screen and counter continue
doffot is offline   Reply With Quote
Old 18th May 2010, 17:04   #8229  |  Link
hidef_rec
hidef_rec's Avatar
Haven't used BD-Rb for a while as I started backing up to hard drives, so not constrained by BD5/9 sizes. Excited to see jdobbs added MKV output. Wondering what CRF setting people are using for backups to MKV. In RibBot264, I'm using CQ18, which is single-pass. I'm interested in good quality obviously (as I use a large front projection system), but fast encoding is also important. Thanks in advance for any recommendations.
hidef_rec is offline   Reply With Quote
Old 18th May 2010, 17:35   #8230  |  Link
stonej01
Are you resizing to 720p? That's the only time I've heard of that problem.
Nope, everything is default except delete workfiles after encode and of course selecting the subtitles to use.
Custom target Size = 23450
Full backup
Automatic quality settings
stonej01 is offline   Reply With Quote
Old 18th May 2010, 18:20   #8231  |  Link
Bystander
Sin City now works with 33.07. Choose alternate version (2nd one) if you want just the movie.
Bystander is offline   Reply With Quote
Old 18th May 2010, 21:55   #8232  |  Link
Paddy97
I'm mostly using this output format since it was added. I am using either 18 or 20 as CRF value. Depends a bit how large or small the output gets, haven't decided if I can see any difference on my 108" projector screen between these two settings.
The only thing missing is the ability to add DTS tracks to the MKV output. Today I remux the MKV with DTS for the movies where I want to use DTS.
Paddy97 is offline   Reply With Quote
Old 18th May 2010, 22:38   #8233  |  Link
Capsbackup
Just did a full movie backup to BD5 of The Punisher, region A, and tested with both software players PowerDVD and TMT3 as well as burned to DVD+RW for playback on my Sony S360.
The backup completes successfully, however the two initial menu buttons are not present on the backup.
The original disc and rip work correctly. When you first insert the disc and it starts, there is a brief intro Lionsgate advert followed by a menu tutorial, how to use your remote control, etc.. There is also two buttons available at this time to play the movie or go to the main menu, which allow you to skip this tutorial. If you don't choose, the movie just starts after the tutorial, approx. 30 seconds later.
These two buttons are not there on the BD-RB backup.
The movie does start and play properly after the intro ends, and does return to the main menu when the movie finishes, but for some reason these menu buttons are left off/not present at the beginning.
Capsbackup is offline   Reply With Quote
Old 18th May 2010, 23:06   #8234  |  Link
tekmobile
Webmaster
I have the same problem with the same player.
tekmobile is offline   Reply With Quote
Old 18th May 2010, 23:08   #8235  |  Link
jdobbs
The other possibility is if it is a multi-part feature -- the problem I said I'm working with SoniG showed a similar symptom that seems to be caused by the use of FFMS for frame-serving.
Old 19th May 2010, 00:20   #8236  |  Link
cnote
cnote
That is the thing, I believe you will get the same results when you rip that same original of Gran Torino. You need to acquire a different copy of Gran Torino. I would be shocked if you didn't get the results you are looking for then. I too successfully backed up my US version of Gran Torino.
Old 19th May 2010, 01:04   #8237  |  Link
PeteWalker74
Well, that'd suck balls. I'd have to rent it from Netflix to properly rip it, when I own the damned disc. I think I'll wait until you do your magic with SoniG and cross my fingers that was the issue. Thanks again!
Old 19th May 2010, 02:37   #8238  |  Link
spotswood
No Shutdown in v0.33.07
I've just updated the first post of this thread with a link to the newest beta release of BD-RB (v0.33.07). Changes for this release: Added a hidden option "SHUTDOWN_SLEEP=1" which will make
the "Shutdown after Rebuild" option on the FILE menu to
"Sleep after Rebuild" instead.
Since I've updated to v0.33.07 my computer does not shutdown after the rebuild is complete. I usually enable the "Shutdown after Rebuild" option and let BD Rebuilder do it's thing overnight, but after the last three encodes my system is still on in the morning, even though the log shows I've enabled shutdown and says it's been initiated when the rebuild is complete. Thanks for any help. Log below.
[22:30:53] BD Rebuilder v0.33.07 (beta)
- Source: 007_DR_NO
- Input BD size: 36.97 GB
- Approximate total content: [03:21:28.726]
- Target BD size: 7.91 GB
- SHUTDOWN at completion enabled
- Audio Settings: AC3=1 DTS=1 HD=1 Kbs=448
[22:30:53] PHASE ONE, Encoding
- [22:30:53] Extracting A/V streams [VID_00001]
- [22:47:53] Reencoding: VID_00001 (1 of 10)
- [22:47:53] Collecting video information
- Rate/Length: 23.976fps, 158,013 frames
- Bitrate: 6,175 Kbs
- [22:47:53] Reencoding: VID_00001, Pass 1 of 2
- [00:18:44] Reencoding: VID_00001, Pass 2 of 2
- [04:16:34] Video Encode complete
- [04:16:34] Reencoding audio tracks (if req'd)
- [04:20:20] Multiplexing M2TS
- [04:27:23] Extracting A/V streams [VID_00025]
- [04:27:32] Reencoding: VID_00025 (2 of 10)
- [04:27:32] Collecting video information
- Source Video: MPEG-2, 720x480
- Rate/Length: 29.970fps, 9,200 frames
- Bitrate: 1,164 Kbs
- [04:27:33] Reencoding: VID_00025, Pass 1 of 2
- [04:28:26] Reencoding: VID_00025, Pass 2 of 2
- [04:31:17] Video Encode complete
- [04:31:17] Reencoding audio tracks (if req'd)
- [04:31:19] Multiplexing M2TS
- [04:31:21] Extracting A/V streams [VID_00026]
- [04:31:46] Reencoding: VID_00026 (3 of 10)
- [04:31:46] Collecting video information
- Rate/Length: 29.970fps, 23,676 frames
- Bitrate: 1,221 Kbs
- [04:31:46] Reencoding: VID_00026, Pass 1 of 2
- [04:33:57] Reencoding: VID_00026, Pass 2 of 2
- [04:41:50] Video Encode complete
- [04:41:50] Reencoding audio tracks (if req'd)
- [04:41:54] Multiplexing M2TS
- [04:42:01] Extracting A/V streams [VID_00029]
- [04:42:13] Reencoding: VID_00029 (4 of 10)
- [04:42:13] Collecting video information
- Rate/Length: 23.976fps, 3,776 frames
- Bitrate: 3,519 Kbs
- [04:42:13] Reencoding: VID_00029, Pass 1 of 2
- [04:44:13] Reencoding: VID_00029, Pass 2 of 2
- [04:48:35] Video Encode complete
- [04:48:35] Reencoding audio tracks (if req'd)
- [04:48:37] Multiplexing M2TS
- [04:48:40] Extracting A/V streams [VID_00030]
- [04:51:45] Reencoding: VID_00030 (5 of 10)
- [04:51:45] Collecting video information
- Rate/Length: 29.970fps, 75,845 frames
- Bitrate: 3,260 Kbs
- [04:51:45] Reencoding: VID_00030, Pass 1 of 2
- [05:33:49] Reencoding: VID_00030, Pass 2 of 2
- [07:14:41] Video Encode complete
- [07:14:41] Reencoding audio tracks (if req'd)
- [07:14:53] Multiplexing M2TS
- [07:15:33] Extracting A/V streams [VID_00031]
- [07:16:56] Reencoding: VID_00031 (6 of 10)
- [07:16:56] Collecting video information
- Rate/Length: 29.970fps, 32,282 frames
- [07:16:56] Reencoding: VID_00031, Pass 1 of 2
- [07:33:53] Reencoding: VID_00031, Pass 2 of 2
- [08:16:53] Video Encode complete
- [08:16:53] Reencoding audio tracks (if req'd)
- [08:16:58] Multiplexing M2TS
- [08:17:17] Extracting A/V streams [VID_00054]
- [08:17:34] Reencoding: VID_00054 (7 of 10)
- [08:17:34] Collecting video information
- Rate/Length: 29.970fps, 15,614 frames
- [08:17:34] Reencoding: VID_00054, Pass 1 of 2
- [08:19:02] Reencoding: VID_00054, Pass 2 of 2
- [08:24:46] Video Encode complete
- [08:24:46] Reencoding audio tracks (if req'd)
- [08:24:49] Multiplexing M2TS
- [08:24:54] Extracting A/V streams [VID_00057]
- [08:24:59] Reencoding: VID_00057 (8 of 10)
- [08:24:59] Collecting video information
- Rate/Length: 23.976fps, 1,379 frames
- Bitrate: 3,333 Kbs
- [08:24:59] Reencoding: VID_00057, Pass 1 of 2
- [08:25:43] Reencoding: VID_00057, Pass 2 of 2
- [08:27:19] Video Encode complete
- [08:27:19] Reencoding audio tracks (if req'd)
- [08:27:19] Multiplexing M2TS
- [08:27:23] Extracting A/V streams [VID_00058]
- [08:27:26] Reencoding: VID_00058 (9 of 10)
- [08:27:26] Collecting video information
- Rate/Length: 23.976fps, 708 frames
- Bitrate: 3,325 Kbs
- [08:27:26] Reencoding: VID_00058, Pass 1 of 2
- [08:27:49] Reencoding: VID_00058, Pass 2 of 2
- [08:28:38] Video Encode complete
- [08:28:38] Reencoding audio tracks (if req'd)
- [08:28:38] Multiplexing M2TS
- [08:28:40] Extracting A/V streams [VID_00089]
- [08:28:43] Reencoding: VID_00089 (10 of 10)
- [08:28:43] Collecting video information
- Rate/Length: 23.976fps, 670 frames
- Bitrate: 3,715 Kbs
- [08:28:43] Reencoding: VID_00089, Pass 1 of 2
- [08:29:04] Reencoding: VID_00089, Pass 2 of 2
- [08:30:01] Video Encode complete
- [08:30:01] Reencoding audio tracks (if req'd)
- [08:30:01] Multiplexing M2TS
[08:30:02]PHASE ONE complete
[08:30:02]PHASE TWO - Rebuild Started
- [08:30:02] Rebuilding BD file Structure
[08:30:06] - Encode and Rebuild complete
- WORKFILES folder removed.
- Computer SHUTDOWN initiated.
spotswood is offline   Reply With Quote
Old 19th May 2010, 04:51   #8239  |  Link
jdobbs
Thanks for the report. I'll check it out. Its possible I may done something in the changes to enable sleep mode...
Old 19th May 2010, 13:00   #8240  |  Link
DK
DK's Avatar
same here
bd rb closed down but system was still running
DK is offline   Reply With Quote
Thread Tools
