#28181 | Link |
Yes, Cinavia detection is required on all current players, from Feb 2012 forward. I have a couple of older Samsung players, one that is 3D capable.
Keep in mind that Cinavia is hardly ever placed on new releases. I'm only guessing that it might be because DVDFab cracked Cinavia and can remove it. Whatever the reason, it is hard to come by these days. |
#28182 | Link | |
From the HIDDENOPTS.TXT: IMPORT_THRESHOLD=n n = Threshold size (in minutes), default=15, of BD/DVD titles listed for IMPORT selection I think the menu will overwrite the .ini, but you may want to double-check Edit: Can that title be played with a standalone? Sometimes there is orphaned material on discs which is not included in any playlist. Last edited by Sharc; 1st December 2018 at 10:15. |
#28183 | Link | |
![]() Join Date: Oct 2001
To handle those discs I added a hidden option called IMPORT_DVD_CHAPS. Try that and see if it separates out the titles you mentioned.
jdobbs.softworks@gmail.com Last edited by jdobbs; 1st December 2018 at 14:41. |
#28184 | Link | |
If you want a cinavia free one, you're going to have to scan sites like e-bay, 2nd hand local commerce sites or used items stores. It's what i did to pick up my Panasonic DMP-BDT110's. and dvdcrap (my opinion) isn't the only thing that can remove it. So can AnyDVD+CloneBD, albeit at a cost to the audio. |
#28185 | Link | |
That would be GREAT though if they are not using it as much! ![]() Nasty thing! |
#28186 | Link | |||
I'll look into the Oppo's... Heh, read funny.. But I think checking if mine can be refurbished is a really good idea. I love the internal Hard Drive, and I swapped it for an even larger one. If I'm correct, though, when you make an MKV and play it on a player infected (I know it's not actually "infected") with Cinavia it'll play as normal because that protection only checks the BD structure. Making more BD's from originals (Quick-Play) seems the best workaround, and way to have MKVs played with SUP within them. Pondering a lot, mate... What do you mean "acting up"?? Quote:
Yeah, I know about AnyDVD and CloneBD and I haven't tried that method. I read that the audio quality is really altered.. DVDFab does a good job at removing it, they're making a lot of advances in several areas. Whatever our opinions are about whatever decryption, I'm glad to know there are more than 2 choices. Cool reply. Looking more and more like newer protections + mastering methods are the challenges more than anything and why my LG Player is having some problems. Older movies and self-made BDs through BD-RB are playing fine now that I have the new burner. So..newer player. I'll find one at a local store, and then check that. If that solves it..than, okay. If not, I'll return it. I don't know what you mean by a limited menu? My only concern is CD/DVD/BD playback..and preferred MKV with SUP/SRT handling. I don't like streaming so I don't use the "apps" built in programs. That should also mean, if I can find it, lower priced units. If Netflix offered full BD quality then I'd consider streaming at times, like making a lossless MKV and streaming that.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
#28187 | Link | |
#28188 | Link | |
If your unit was made before the Cinavia Apocalypse, ask first, but like with OPPO, I believe it is specific hardware that is incorporated into the newer units, and they can't / don't do anything while refurbishing the older ones. So, if you really like yours, like I like mine, then after double checking with them that would be the way to go. |
#28189 | Link |
That's very much a consideration. I'll get a hold of them Monday.
#28191 | Link |
LOL!!! Becoming that personal so quick usually won't get you the results you want and you have to do a lot of "hand holding/gripping" as the process happens, or they'll run from you. Wow, Lathe..ha!
Doing some looking around "This may sound controversial, but the Oppo 203 also has the ability to be flashed with a custom 'jailbroken' firmware to circumvent 'region locks' or 'cinavia' problems." Hmm! But the price is wayyyy too high for me.
#28192 | Link | |
OPPO has some pretty fervent fans, so I'm not too surprised that someone has come up with a defeat. Actually, I'm not a software expert like many here, but I would THINK that since that is added as a hardware / software addition, that it SHOULD be possible to kill it / circumnavigate it somehow... I know right out of the gate, since makers of players are not allowed (corrected, sorry) to make them Blu-ray Region Free out of the box, that there were hardware mods immediately for mine and the BDP-93. I little bypass wire that you simply plugged into the board (OPPO already DOES or at least DID make their players automatically PAL to NTSC internally, and the SW hack is super simple to play all region DVDs...)
#28193 | Link | ||
#28195 | Link |
A friend has a newer Player and I got to check my tests BD-REs. Ok, settled, I'm going to get a newer device..that also supports MKV playing. My older LG plays less complicated-older multi-M2ts BDs okay...but not as well as newer. My friend (yes, Lathe..) also commented about how the BDs don't have the normal stuff, and asked where I got them? "Fair Use of your own owned BDs." and I explained it. He doesn't understand any of the process but said if I'd do it for him to keep some discs in good condition, he'd buy some blanks and brews. I said, "Okay, but also donate to the program." So after Winter Solstice is over, next month, I'll have a donation for you. :-)
#28197 | Link |
I'm not "worried" about it, and I don't care for streaming. Because my newer HDTV plays MKV files from USB (with Subs, Chapters, etc), I do that often but I still prefer Menu driven BDs. I enjoy "themes" a lot. My LG BD590 Player also plays MKVs from USB and HD, but not with Chapters. I keep Records and CD Art because I loved them all of my life. I still prefer to see the Art when I pick through my Lossless collection (converted all CDs to Bin/Cue), but MKV, or at least I haven't tried it yet, doesn't show Images. Hmm...Now that I'm thinking about it, my HDTV might..instead of Thumbnails from a movie.
I'll check now..
#28198 | Link | |
First off, that doesn't explain why DVDFab and VideoReDo have no problem finding this particular special feature title. Also, if a title were to contain more than one special feature, all three programs should see that and the title length would be longer. Plus, other than the deleted scenes, all of the special features have one chapter mark. Secondly, that just doesn't seem to be the pattern for any of the discs in any of the 7 seasons that have been released by Warner Bros. Doesn't make sense for it to be done with just one special feature. Running a test using the hidden option, found a chapter that was 5:33 in length. That would match the 5:34 that was not found, less the 1 sec chapter mark at the end. But, when attempting to add it to the batch queue, it was listed as 3:30 in length. Then when running the batch, DGIndex failed with an error stating that there were too many pictures per group (GOP >= 500). If you want, I can make an ISO of this DVD available for you to download for testing. |
#28199 | Link |
Cinavia survives any ripping process. BD standalone players are supposed to also detect Cinavia on ripped media files like MKV wrapped programs. But, as it turns out, not all manufacturers did. TVs are not subject to Cinavia detection, as the BD media is required to verify legality.
| Thread Tools | |
| Display Modes | |
