25th August 2015, 15:23 | #741 | Link | |
Δ
I wonder if i5 6600K can handle 10bit well too. |
26th August 2015, 07:33 | #742 | Link |
Can you retest this too, in order to complete the picture:
1) LG_4K_View-the-Feeling.mp4 - 4K@30fps - 25Mbps http://demo-uhd3d.com/fiche.php?cat=uhd&id=101
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
27th August 2015, 06:01 | #745 | Link |
The platform is very young and those fluctuations are expected.
I'll keep the previous results of clip 1 in order to be inline with the others. Unless you want to rerun the tests for the rest too or you tell me that the others didn't change.
30th August 2015, 12:52 | #746 | Link |
@Yups
Using latest DXVA Checker v3.70 and your HD 530, if you go to "Check Decoders" -> "Select Format" and you choose VP8 or VP9, are there any other decoders besides LAV ? I'm interested in Intel MFT VP8/VP9 decoders that using previous DXVA Checker v3.60 were enumerated by choosing VP8 and VP9 formats. Also, if you have a VP8 or even VP9 sample (any sample) can you check with your system and latest DXVA Checker v3.70, if any Intel MFT decoders appear when you choose "Select Media File..." and test a VP8/VP9 file ? Thanks!
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all Last edited by NikosD; 30th August 2015 at 13:45. |
30th August 2015, 17:44 | #749 | Link | |
No decoder listed. I don't have VP8/9 samples. |
30th August 2015, 18:01 | #750 | Link |
But the image shows clearly Intel's VP9 decoder
If you select VP8 format, does Intel's VP8 MFT decoder appears ? I'll upload two samples later, one VP8 and one VP9 to test the "Select Media File"
30th August 2015, 18:24 | #752 | Link |
Weird...It should say VP8 according to the previous version of DXVA Checker and according to the installed decoders.
Unless of course it is somehow common.
30th August 2015, 19:21 | #753 | Link | |
Δ
http://i.imgur.com/fEslJSK.png |
30th August 2015, 19:27 | #754 | Link |
Does it only show native DXVA? Then you might need a recent nightly version of LAV.
http://files.1f0.de/lavf/nightly/ |
30th August 2015, 19:37 | #755 | Link | |
Δ
30th August 2015, 21:39 | #756 | Link |
Here it is a VP8 sample:
https://www.sendspace.com/file/be21aw And a VP9 from Youtube: https://www.sendspace.com/file/v95vjb
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all Last edited by NikosD; 30th August 2015 at 21:54. |
1st September 2015, 12:27 | #758 | Link |
Guys isn't time to test HW accelerated HEVC encode?
It is present on Skylake and NV Maxwell Gen 2 GPUs (yes even my GTX 970 which doesn't support HEVC decode).. One way to test will be ffmpeg which supports using NVENC for Nvidia support and QuickSync for Intel.. We should make standard binary and command line args with a standard video input too similar to h264 benchmark (Tech ARP - x264 HD Benchmark Ver. 5.0.1).. Then let the benchmarks begin.. |
1st September 2015, 13:35 | #759 | Link |
I have been thinking of this concept since last August when I purchased my Core i7 4790.
But most people are interested in SW encoding and particularly SW quality encoding, not speed. So, a very specific benchmark test regarding speed of HW encoding and expecially HEVC, which is so immature right now, it doesn't make a lot of sense to me. But you are free to open such a thread, I don't think there is something like that in this forum. I know only a quality comparison thread between x264 and x265.
