Old 17th April 2025, 13:27   #32181  |  Link
thebuff
Thanks for your reply - I'll take a look, but I do the same thing every time and just create a new folder, automatically called New Folder by Windows and then rip using DVDFab, so the structure within is always the same.
But I'll give it another go from scratch.
Many thanks
thebuff is offline   Reply With Quote
Old 17th April 2025, 20:32   #32182  |  Link
Lathe
Lathe's Avatar
That error code (75) means "Path/File access error". You may want to check the path to your working or source folder(s) and see if it has some unusual characters, or if it is exceptionally long.
"See if it is exceptionally long...?!!"
Lathe is offline   Reply With Quote
Old 18th April 2025, 12:16   #32183  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Exceptionally long would be more than 259".
Or characters. Whatever seems more important under given circumstances. ;-}}
Old 19th April 2025, 09:17   #32184  |  Link
MrVideo
MrVideo's Avatar
How does BDRB determine how many frames are in a file? I just had BDRB bail because it only got 167640 frames of 179976 frames. But, there are only 167640 frames in the file. I pulled the file into VRD and it shows 167640 frames. I went to the end of the file and it is not truncated.
So, I thought I would edit the AVS file for the video. Well that didn't work. BDRB rebuilt the file.
Bug?
Old 19th April 2025, 13:02   #32185  |  Link
jdobbs
Bug?
BD-RB gets the frame count from data in the MPLS file (length and framerate). Are you getting an error? If so, what error? It's been a while since I looked at that code, but, if I remember correctly, I don't think it should fail even if the frame count was wrong.
jdobbs.softworks@gmail.com
Old 20th April 2025, 02:37   #32186  |  Link
MrVideo
MrVideo's Avatar
Yep, as indicated in the posting, the frame count is less than what BDRB is told that it should be. When BDRB hits the real frame count, it fails indicating that the frame count was less than expected.
Old 20th April 2025, 09:05   #32187  |  Link
MrVideo
MrVideo's Avatar
I just used BDEdit to look at the playlist and took the length of 1:56:31.985 (6991.95 sec) and came up with 167638.9932 frames. Just one frame shy. I have no idea where BDRB came up with 179976 frames.
Old 20th April 2025, 12:25   #32188  |  Link
jdobbs
Could you please post the log so I can see what it says?
Old 20th April 2025, 22:33   #32189  |  Link
MrVideo
MrVideo's Avatar
It says what I've said in the posting, but here it is:
[04/19/25] BD Rebuilder v0.62.12
[21:18:32] Source:
  - Input BD size: 53.31 GB
  - Approximate total content: [02:27:51.037]
  - Target BD size: 22.95 GB
  - Windows Version: 6.1 [7601]
  - Quality: High Quality (Default), 1-Pass VBR
  - UHD-BD source detected.
  - Decoding/Frame serving: NVENCC
- Resuming from previously started job.
[21:18:39] PHASE ONE, Encoding
 - [21:18:39] Processing: VID_00001 (1 of 1)
 - [21:18:39] Reencoding video [VID_00001]
   - Source Video: HEVC, 3840x2160
   - Rate/Length: 23.976fps, 179,976 frames
   - Bitrate: 20,665 Kbs
 - [21:18:39] Reencoding: VID_00001, Pass 1 of 1
   - Error: NVENCC prematurely terminated.
   - Encoded: 167640, expected: 179976
[21:51:29] - Failed video encode, aborted
But, I was thinking about supplying the following anyway, as I thought it might come in handy:
http://vidiot.com/images/BDEDIT-BDRB-mpls.jpg
Hopefully there is a clue in there.
Old 21st April 2025, 00:33   #32190  |  Link
jdobbs
[21:18:32] Source:
I'll look at it. In the meantime, try adding the following to your INI file:
NVENC_NO_FRAMECHK=1
Old 21st April 2025, 03:31   #32191  |  Link
MrVideo
MrVideo's Avatar
BTW, pings to jdobbs.net are fine, but the website does not respond.
Old 21st April 2025, 03:53   #32192  |  Link
MrVideo
MrVideo's Avatar
NVENC_NO_FRAMECHK=1
Oh boy, a hidden hidden option.
That worked. Re-encode completed. Thanks.
Old 21st April 2025, 12:17   #32193  |  Link
jdobbs
I shut it down.
It was created specifically for NVENC support. If I remember correctly, I added the frame count check because it was the only way I could identify when it crashed (at that time). The hidden option was put there as a workaround in case something (like your issue) popped up.
Old 21st April 2025, 13:39   #32194  |  Link
MrVideo
MrVideo's Avatar
I shut it down.
Does this mean that your website is no more? Or is it temporary as it is still listed in your signature.
Well, it worked.
Old 21st April 2025, 13:40   #32195  |  Link
jdobbs
Well, it worked.
It wasn't getting enough hits to justify the cost. I'll just take it out of my signature.
Old 22nd April 2025, 00:12   #32196  |  Link
MrVideo
MrVideo's Avatar
Sorry to read that. My website, etc., is on my personal Linux server, about 6 ft from where I am sitting. No paying a 3rd party to host it. Much cheaper.
Old 22nd April 2025, 00:34   #32197  |  Link
jdobbs
Yeah. I had mine running on my server here too. It's the fixed IP VPN costs that I was referring to. The VPN stopped working (quit forwarding ports) for the umpteenth time last week and I decided to call it quits before I had to renew it.
Old 22nd April 2025, 12:55   #32198  |  Link
MrVideo
MrVideo's Avatar
I have a static IP business account, that I recently updated to 1Gbps down/50 Mbps up. It is a cable connection. They have work to do before the 50 Mbps up can be increased. It is just taking them a long time. No VPN involved. True that it isn't cheap, but not as bad as I thought it was going to be. To go from 100 Mbps down to 10x faster was not 10x the price. It wasn't even double.
