Old 2nd May 2018, 14:31   #3021  |  Link
ChaosKing
Seems it only happens if mvtools-sf is in the filter chain.
Edit:
Is there a way (hack) to avoid this problem without modifying mvtools? I mean except putting it outside of FrameEval, bcs it's very slow and I need it only for many short scenes.
I will report this bug to feisty2 but who knows when and if he's gonna fix it.
Old 2nd May 2018, 15:39   #3022  |  Link
ChaosKing
Originally Posted by HolyWu View Post
Generally I don't recommend invoking filters within FrameEval unless unavoidable, because that introduces extra overhead.
PHP Code:
from vapoursynth import core
import vapoursynth
as vs
import functools
def frame_eval
(nclip):
    return
core.misc.AverageFrames(clipweights=[1] * 5)
clip core.std.BlankClip(width=720height=480format=vs.YUV420P8length=10000)
#clip = core.misc.AverageFrames(clip, weights=[1] * 5)
# I get 1014.60 fps
#clip = core.std.FrameEval(clip, functools.partial(frame_eval, clip=clip))
# I get 566.09 fps
clip.set_output()
You should assign the filtered result to a variable outside FrameEval and then pass it in via functools.partial() as additional argument if possible.
Why didn't I think of that... it works perfectly.
Old 2nd May 2018, 16:45   #3023  |  Link
ChaosKing
I get the same speed up ~3x with your script. But what kind of cpu do you have to get 3000fps? My Ryzen 1700 8core @3.6ghz gets only half of that (VS R43)
Old 5th May 2018, 18:27   #3024  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
R44-test2
More large page fixes and updated zimg. Test again because this will probably work better.
WINDOWS 10 APRIL UPDATE IS REQUIRED FOR PROPER LARGE PAGE TESTING
I forgot to mention that the cache logic has been improved so settings max memory usage to yuuuuuge numbers shouldn't be necessary anymore.
Myrsloik is offline   Reply With Quote
Old 5th May 2018, 23:55   #3025  |  Link
ChaosKing
Yep, I get the same speed (64-65fps, 4fps more than test1) with and without core.max_cache_size = 32768, cpu @ 99%, April 1803 update is installed.
With no max_cache set this is shown: Script exceeded memory limit. Consider raising cache size.
Old 7th May 2018, 16:31   #3026  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Did something break with the Windows 10 April 1803 update? I'm unable to load KNLMeansCL anymore; the plugin has been in the plugins64 folder all the time and now VSEdit is saying "AttributeError: No attribute with the name knlm exists. Did you mistype a plugin namespace?"
import vapoursynth as vs
core = vs.get_core()
clp = core.dgdecodenv.DGSource(r'C:\Temp\testclip.dgi')
clp = core.knlm.KNLMeansCL(clp)
clp.set_output()
Old 7th May 2018, 16:39   #3027  |  Link
DJATOM
DJATOM's Avatar
Check if your video drivers properly installed... Massive updates usually breaks things for me.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 7th May 2018, 16:41   #3028  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Yes, just found out that the stupid update rendered the graphics card useless and the NVIDIA driver package didn't even find an older version from the computer. Because I don't play games with the computer, I never noticed until now.
Old 7th May 2018, 17:13   #3029  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I get this message with a 1080p source and some MVTools-based denoising + contrasharpening and advanced downsizing stuff in the script. I've tried setting the cache at 12000 but at some point the warning appears in the encoder log. Of course, with that value being so high (I have 16 GB of memory), the computer ends up swapping a lot so I need to tune it back to 10240 or so.
After some time, the memory usage of the vspipe process goes down to 3-4 GB of memory and stays there until the end. Does it mean that it's actually not useful to set a high value to start the encoding with?
EDIT: Except that with r44t2, the memory usage stays high all the time.
Last edited by Boulder; 7th May 2018 at 18:45. Reason: Additional info after running the encode for over an hour
Old 7th May 2018, 17:39   #3030  |  Link
LigH
LigH's Avatar
Side info...
MABS is supposed to be able to build ffmpeg with VapourSynth support (for video filtering, like in mpv, IIRC). But it is important to know: If you build ffmpeg with VS support, VS also becomes a requirement to even start this specific ffmpeg build, it won't run on a PC where VS is not installed.
So I doubt I would provide such a build, as I won't need it for this kind of usage.
New German Gleitz board
Old 7th May 2018, 20:19   #3031  |  Link
Myrsloik
Myrsloik's Avatar
Basically the logic is closer to Avisynth behavior now. All leftover memory is used for recycled framebuffers. I have some ideas on how to improve things later. I don't think it's ideal but it does improve another corner case a lot... But if it stops at such a low total memory usage you can set it lower to begin with and it won't cause any problems.
Old 18th May 2018, 23:46   #3032  |  Link
Pat357
Originally Posted by LigH View Post
Side info...
Appearently can ffmpeg with --enable vapoursynth be build that it will run also without any VS installed. This is done by building everything as static and load the stuff as delayed import.
The guys here build a binary ffmpeg this way (with gcc) and this version, unlike many other builds (ie the media-suite version) works very well.
The build from media-suite needs indeed that VS is installed, but even then I can't make it output any video from a valid VPY script.
See https://forum.doom9.org/showthread.php?t=175341
Pat357 is offline   Reply With Quote
Old 20th May 2018, 15:19   #3033  |  Link
LigH
LigH's Avatar
Supporting VS optionally when the environment is available ... that will be much more interesting.
Old 21st May 2018, 20:10   #3034  |  Link
lansing
I'm wondering can vapoursynth read color value in hex?
Old 22nd May 2018, 01:14   #3035  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Color is only ever read as a Python list of each value per plane. There's nothing keeping you from implementing a convenience function, however, like:
def Hex2List(colorhex):
  digits = math.ceil(colorhex ** (1/16.))
  colorlist = []
  for plane in range(0,digits):
    colorlist.insert(0, colorhex % 256)
    colorhex = colorhex // 256
  return colorlist
And calling it as Hex2List(0x778899).
You can always use an actual list like [0x77, 0x88, 0x99], so the value of this convenience is questionable.
Old 22nd May 2018, 02:32   #3036  |  Link
lansing
  colorlist = []
    colorlist.append(colorhex % 256)
  return colorlist
I'm talking about things like using it in blankclip like this, instead of the longer rgb value.
clip = core.std.BlankClip(color="#ffffff")
Old 22nd May 2018, 04:57   #3037  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Is BlankClip(color=[0xff, 0xff, 0xff]) that much harder? If it is, use that convenience function in my last post.
Old 22nd May 2018, 05:23   #3038  |  Link
lansing
I will need to load in a bunch of color, so the shorter the representation the better.
And Hex2List(0x778899) and [0x77, 0x88, 0x99] give me different color.
Old 22nd May 2018, 07:15   #3039  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Whoops, edited. I forgot to test. If you're going to get a lot of use out of it, might as well rename it H2L or something.
Old 22nd May 2018, 08:43   #3040  |  Link
lansing
Thanks foxyshadis and Holy, the function works now
speed, vaporware, vapoursynth
