Old 22nd February 2018, 15:56   #1  |  Link
srfscenar
CCE section encode
Hi all,
I have a film to encode and I want to use as average 5000Kbps. The thing is that there is a section of almost 20'' in the middle of the film that I want to use a higher bitrate as it is a very demanding shot.
How can I achieve this?
I am using the latest version.
Thanks,
" 2 minds are better than 1 "
srfscenar is offline   Reply With Quote
Old 22nd February 2018, 16:21   #2  |  Link
kolak
Just set average to 5Mbit and max to 8.5Mbit and it encoder will raise bitrate where needed by itself.
If still not happy you need to use segment re-encoding. Check manual how to do it.
Old 22nd February 2018, 16:26   #3  |  Link
srfscenar
Thanks Kolak.
Yes, I am not happy with the result at that part.
I'll check the manusl to see what it says. I just thought there are any tips that the manual might be missing.
Thanks,
Old 23rd February 2018, 00:04   #4  |  Link
srfscenar
well, I did look at the manual but it was not very clear on what to do exactly.
If anyone has done it, I'd appreciate a walkthrough.
Old 23rd February 2018, 00:51   #5  |  Link
kolak
It's quite easy.
Go to bitrate allocation window:
select in/out timecode, set bitrate for that region and hit encode. SP3 re-encodes just given segment (if you on SP/SP2 then it will re-encode whole file as real segment re-encode is not supported).
SP3 is crazy good with progressive sources. Its bitrate allocation engine is very good, so not much normally can be manually done.
Old 23rd February 2018, 00:54   #6  |  Link
srfscenar
Thanks Kolak, I'll try that!
That procedure is after you finish the whole encode, right?
Is there a way to set it before you start encoding the whole film first?
Thanks,
Old 23rd February 2018, 00:58   #7  |  Link
kolak
Thanks,
Run 1st pass only, do adjustments and then do 1 or 2 more passes.
As I said- it's rare you can do much better than SP3 itself. If region is crazy difficult then SP3 will allocate maximum bitrate you set anyway, so you can't do any better manually. You have to then raise maximum bitrate or simplify source- de-noise etc.
You have to be carful and know what can be changed between passes- some things require re-creation of the 1st pass. Manual should say what is allowed. Last time I used SP3 was many years ago.
Old 23rd February 2018, 01:03   #8  |  Link
srfscenar
Thanks a lot!!!
Sent from my iPhone using Tapatalk
Old 29th April 2018, 10:52   #9  |  Link
PhillipWyllie
Assuming this is for DVD you got to be very carefull that at no point the total bitrate exceed the DVD max. You can fernagle Scenarist to accept such streams but some DVD players do not. IIRC a smooth-in smooth-out approach doesn't work well but rather start and end your changes at closed GoPs.
Specs: Intel Core 2 Quad Q6600(4*2.4GHz), Win XP Pro SP2, 2 Gb DDR2, 1*120Gb HDD, 1*500Gb HDD
PhillipWyllie is offline   Reply With Quote
Old 29th April 2018, 12:36   #10  |  Link
mp3dom
Using CCE, you already have the limitation of segment encoding only between closed gops. Also, the encoder is strictly "DVD compliant" and checks that the bitrate doesn't exceed the DVD specs
Old 29th April 2018, 14:48   #11  |  Link
PhillipWyllie
CCE doesn't account for other streams and will always keep the bitrate below 9.8Mbit/s. When you factor in audio it's easy to overshoot when you set the bitrate manually.
Old 29th April 2018, 20:23   #12  |  Link
mp3dom
Of course it doesn't account, it could never know how many audio stream you'll put in a dvd. Set the right value in the maximum bitrate field is the job of the compressionist. If you set (for example) 8.5 Mbps as a max bitrate, CCE will not go beyond that value even during segment encoding, which is what you would expected from a dvd-specs video encoder.
