16th February 2022, 21:09 | #24743 | Link |
Sebastian Ledesma
Hi Nev!
First, thanks for LAV, it's a great piece of software. Second, I have a couple of .mp4 files that LAV splitter (even version 0.76) dont recognize the video stream, only the audio stream (I've used GraphStudioNext to confirm). VLC and Windows Media Player 12 play the files with autio and video, but the first 6-10 seconds the image it's freezed, so probably the file it's corrupted. MediaInfo recognizes them as 'MPEG 4 visual'. Here are the details: General Complete name : C:\sebas\analize\ASSASIN_-_AURA.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/mp41) File size : 27.5 MiB Duration : 3 min 13 s Overall bit rate mode : Constant Overall bit rate : 1 194 kb/s Writing application : Lavf58.28.100 Video ID : 1 Format : MPEG-4 Visual Format profile : Simple@L1 Format settings, BVOP : No Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : mp4v-20 Duration : 3 min 5 s Bit rate mode : Constant Bit rate : 1 104 kb/s Width : 640 pixels Height : 480 pixels Display aspect ratio : 2.40:1 Original display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.150 Stream size : 24.4 MiB (89%) Title : ISO Media file produced by Google Inc. Created on: 05/03/2019. Writing library : Lavc58.53.100 Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 3 min 13 s Bit rate mode : Constant Bit rate : 129 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 2.96 MiB (11%) Title : ISO Media file produced by Google Inc. Created on: 05/03/2019. Default : Yes Alternate group : 1 and the other one: General Complete name : C:\sebas\analize\REIK_FT_OZUNA_WISIN_-_ME_NIEGO.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/mp41) File size : 33.2 MiB Duration : 3 min 39 s Overall bit rate mode : Constant Overall bit rate : 1 270 kb/s Writing application : Lavf55.34.101 Video ID : 1 Format : MPEG-4 Visual Format profile : Simple@L1 Format settings, BVOP : No Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : mp4v-20 Duration : 3 min 27 s Bit rate mode : Constant Bit rate : 1 200 kb/s Width : 640 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.163 Stream size : 29.7 MiB (90%) Writing library : Lavc55.52.102 Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 3 min 39 s Bit rate mode : Constant Bit rate : 128 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 3.35 MiB (10%) Default : Yes Alternate group : 1 For reference, i've uploaded the files here: http://www.solidynepro.us/sebas/ASSASIN_-_AURA.mp4 http://www.solidynepro.us/sebas/REIK...-_ME_NIEGO.mp4 Can you confirm that the files are damaged or it's just a mpeg4 sub-format currently not recognized? Thanks in advance Sebastian Ledesma |
16th February 2022, 23:27 | #24744 | Link |
First file hangs for 7 seconds because the audio track is 7 seconds longer than the video track. So the file is somewhat 'broken'.
Second file needs increased analyzeduration, otherwise it fails due to unknown resolution. So that file is also a bit broken. You can make it playable by remuxing it with MkvToolNix.
MPC-HC 2.2.1 |
17th February 2022, 15:09 | #24745 | Link | |
Sebastian Ledesma
I'm learning how to use MkvToolNix to repair those files. |
22nd February 2022, 17:35 | #24746 | Link |
MPC-HC is my favourite Mediaplayer and I love all it's features - especially in combination with MadVR. But I have one Problem, which remains even with the latest Version I've just installed: If I have a *.MKV Video-File with a lot different audio-tracks the media player doesn't offer me to choose between all of them in the Audio Track selection: For example I have some Movies with Dolby Digital Plus, Dolby Digital, Dolby True HD PLUS one DTS-HD MA Track (I muxed that together with MKVToolnix from different Sources). In my Example all the Dolby Tracks are shown, but the DTS-HD MA Track dissapeared. I did nothin wrong with MKVToolnix - I use this tool for many years. I've just selected ONE Audio Track as default etc.). VLC Player or PowerDVD show all Audio Tracks and I can choose between all of them and all are played without problem. I'm not sure, but I think it's maybe a Problem with the Lav Splitter?! Here the Mediainfo Output of the Video: Code:
General Unique ID : 20034899356123229208554096159581207675 (0xF1294CD792C45C1FE323C8F5C9EFC7B) Complete name : W:\NVIDIA_SHIELD\BLURAY\FILME\Guardians of the Galaxy 2\Guardians of the Galaxy Vol.2 (2017).mkv Format : Matroska Format version : Version 4 File size : 27.5 GiB Duration : 2 h 15 min Overall bit rate mode : Variable Overall bit rate : 29.0 Mb/s Encoded date : UTC 2022-02-09 16:37:11 Writing application : mkvmerge v65.0.0 ('Too Much') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.4 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 15 min Bit rate : 16.6 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.083 Stream size : 15.7 GiB (57%) Language : German Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Audio #1 ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Format profile : Blu-ray Disc Codec ID : A_EAC3 Duration : 2 h 15 min Bit rate mode : Constant Bit rate : 1 024 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 21 ms Stream size : 994 MiB (4%) Title : Deutsch Dolby Digital Plus 7.1 (UHD Blu-ray) Language : German Service kind : Complete Main Default : Yes Forced : No Audio #2 ID : 3 Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec ID : A_DTS Duration : 2 h 15 min Bit rate mode : Variable Bit rate : 2 538 kb/s Channel(s) : 8 channels Channel layout : C L R LFE Lb Rb Lss Rss Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless Delay relative to video : 5 ms Stream size : 2.41 GiB (9%) Title : DTS-HD MA 7.1 (by Asterixi) Language : German Default : No Forced : No Audio #3 ID : 4 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 15 min Bit rate mode : Constant Bit rate : 576 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 559 MiB (2%) Title : Deutsch Dolby Digital 5.1 (UHD Blu-ray) Language : German Service kind : Complete Main Default : No Forced : No Audio #4 ID : 5 Format : MLP FBA 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Codec ID : A_TRUEHD Duration : 2 h 15 min Bit rate mode : Variable Bit rate : 7 509 kb/s Maximum bit rate : 11.3 Mb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 1 200.000 FPS (40 SPF) Compression mode : Lossless Stream size : 7.12 GiB (26%) Title : English TrueHD Atmos 7.1 (UHD Blu-ray) Language : English Default : No Forced : No Number of dynamic objects : 13 Bed channel count : 1 channel Bed channel configuration : LFE Audio #5 ID : 6 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 15 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 621 MiB (2%) Title : English Dolby Digital 5.1 (UHD Blu-ray) Language : English Service kind : Complete Main Default : No Forced : No Text #1 ID : 7 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 6 min Bit rate : 0 b/s Count of elements : 6 Stream size : 73.0 Bytes (0%) Title : Deutsch Forced (SRT) Language : German Default : Yes Forced : Yes Text #2 ID : 8 Format : VobSub Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 2 h 6 min Bit rate : 16 b/s Count of elements : 6 Stream size : 15.6 KiB (0%) Title : Deutsch Forced (VobSub) Language : German Default : No Forced : Yes Text #3 ID : 9 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 64 b/s Count of elements : 12 Stream size : 60.2 KiB (0%) Title : Deutsch Forced (PGS) Language : German Default : No Forced : Yes Text #4 ID : 10 Format : VobSub Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 2 h 14 min Bit rate : 7 729 b/s Count of elements : 1535 Stream size : 7.45 MiB (0%) Title : Deutsch (VobSub) Language : German Default : No Forced : No Text #5 ID : 11 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 14 min Bit rate : 38.5 kb/s Count of elements : 3070 Stream size : 37.1 MiB (0%) Title : Deutsch (PGS) Language : German Default : No Forced : No Text #6 ID : 12 Format : VobSub Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 2 h 14 min Bit rate : 8 871 b/s Count of elements : 1973 Stream size : 8.56 MiB (0%) Title : English SDH (VobSub) Language : English Default : No Forced : No Text #7 ID : 13 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 14 min Bit rate : 44.4 kb/s Count of elements : 3946 Stream size : 42.8 MiB (0%) Title : English SDH (PGS) Language : English Default : No Forced : No Menu 00:00:00.000 : en:King Cobra & Giant Sea Monkey 00:09:54.375 : en:Golden Morons 00:15:08.314 : en:Space Chase 00:22:12.279 : en:Not From Missouri 00:32:31.898 : en:Deepest, Darkest, Secrets 00:36:50.323 : en:Berhert Ambush 00:42:27.368 : en:Finding Meaning 00:48:01.660 : en:Taserface 00:53:17.101 : en:Celestial Catch 00:58:44.136 : en:Let's Agree To Never Discuss This 01:05:50.436 : en:Eclector Escape 01:11:10.631 : en:Sibling Rivalry 01:18:41.790 : en:Eternity 01:23:53.518 : en:Two Of A Kind 01:30:22.949 : en:Inflated Ego 01:39:34.375 : en:What A Day 01:47:04.408 : en:From The Heart 01:54:19.801 : en:A Father's Sacrifice 01:58:51.906 : en:The Colors Of Ogord 02:07:11.656 : en:End Credits |
22nd February 2022, 18:12 | #24748 | Link |
The only reason any audio track wouldn't be shown from a MKV file would be if its marked as Hidden. You should make sure that is not the case. If you muxed it yourself, you may have accidentally applied that flag.
22nd February 2022, 18:20 | #24749 | Link |
Yes. All Formats are checked for Bitstreaming. I already posted this in the MPC-HC Thread, but I was told, that this is an error of the LAV-Splitter. And that seems to be right: I forced MPC-HC to use Haali Media Splitter instead and suddenly ALL of my Audio Tracks appeared in the Audio Selection. Unfortunately Haali Media Splitter is too old for HEVC so I had no picture - only Sound. So this was just a Test to proove that nothing had gone wrong while Muxing. This Problem doesn't encounter with just one Video file - it encounters on all Videos with a lot of Audio Tracks with that different kind like my example.
Someone told me, that this might be because MKVToolnix changed the kind how tracks should be marked. So I marked ALL Audio Tracks as "Default" and tried to mux it again: But no effect: There are still missing some Audio Tracks... |
22nd February 2022, 18:32 | #24750 | Link |
@nevcairiel
No, there is nothing marked as hidden. And as I said it's not only one File causing this Problems. hmmm, I now muxed it with TS-Muxer (Nightly) to a *.mts File and now ALL Tracks are recognized by LAV-Splitter?! So there is a Problem with LAV-Splitter and MKV-Files or there is a BUG in MKVToolnix.... or there is something in MKVToolnix which I can't see?! But I'm not a Newbie with that tool. I use it for many many years?! Last edited by bananenmann; 22nd February 2022 at 18:38. |
22nd February 2022, 19:19 | #24751 | Link |
Use the Header Editor in mkvmerge on your existing file, and check the missing track for "Track enabled". If its present and set to "No", then the audio will be skipped.
Nothing in your screenshot shows anything regarding that, you even selected the wrong track if DTS-HD is supposed to be missing. Its the only reasonable explanation for a MKV audio track to not show - because thats what the MKV spec says should happen. Otherwise the only thing I can tell you is that I need a sample.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 22nd February 2022 at 22:09. |
22nd February 2022, 23:07 | #24752 | Link |
No, the last Picture was another Video File. In that File I tried to set the DTS-HD Audio Track as the first and default track - as you can see it in my MKVToolnix Picture. MPC-HC offers me the DTS-HD Track as the default one (as it should be), then the second one: Dolby Digital Plus 7.1 Track is missing and the True-HD and the normal Dolby Digital Track are visible again.... My first Post was a different file: There I put the 7.1 Dolby Digital Plus Track as the default first track and the DTS-HD track as the second track. It seems that always the second Track is missing. There the DTS-HD Track was missing.
But you are Right, I did a mistake: I always thought that in the bottom window there has to be a green checkmark for the Element to be copied with. I didn't see that each track has to be separately aktivated in the right window (I don't mean "Standard Track" and even not "Forced Track" - but as you said the Track on it's own has to be enabled there as well. In my last Picture all elements have a green checkmark, but you can see that in the right window the 7.1 Dolby Ditgital Plus Track is NOT enabled. And that is exatly the one Audio Track which is missing in that file while playing it with MPC-HC. A little bit confusing, because I always have ALL tracks in the right window disabled - only the default and forced tracks are enabled ... and everything worked. I could always choose between all tracks (Audio and Subtitle). But since I have such a lot Audio Tracks (more than two) in one file this behaviour happened. So sorry for disturbing you - it was my fault. Maybe it would be better in MKVToolnix when a copied, but disabled track is tried to be muxed in a MKV - that there is a warning Message or a red checkmark or something like this. Have a nice evening Last edited by bananenmann; 22nd February 2022 at 23:10. |
28th February 2022, 15:27 | #24753 | Link |
LAV Filters 0.76.1
LAV Splitter - Changed: When requesting a HTTP URL, the URL itself is send as a referrer to increase compatibility - Fixed: The priority of "Default" subtitle tracks in MKV files was wrong when a forced track was present LAV Video - Changed: Improved color reporting for DVD menus/subtitles - Fixed: D3D11 surface clearing did not work properly on Intel GPUs If you missed 0.76, the release notes are here Only a collection of small fixed on top of 0.76, before I dive into some bigger changes and these won't get out for quite a while.
28th February 2022, 17:37 | #24754 | Link |
Thanks!
Can you reveal anything about those changes that you are planning?
MPC-HC 2.2.1 |
2nd March 2022, 11:20 | #24756 | Link | |
Dtswav
I have a problem with bitstreaming DTSWAV files (in MPCHC). The passthrough option for DTS in WAV files just does not work. It works in avi, m2ts and other video files but not in wav. There is no sound at all. The music palys only if I check "fallback to PCM" option. Here is my discussion with clsid2 on github on that topic: https://github.com/clsid2/mpc-hc/issues/1555 |
12th March 2022, 05:49 | #24757 | Link |
Just a heads up for those who are interested. I managed to add direct3d 12 hardware decoding in lavfilters.
https://github.com/tiben20/LAVFilters I based my work on the fork Steve Lhomme did on vlc. So far most of h264,hevc, vp9, vc1 codecs works. Of course since there is no d3d12 directshow renderer at the moment its kinda useless. I started today a fork to add d3d12 rendering in the mpc videorenderer from the mpc-be team. I only did this because i love contributing to the open source community. I don't think the d3d11 hardware acceleration will be beat in a near future but at least its a first step into direct3d 12 |
12th March 2022, 14:00 | #24759 | Link |
Afaik the D3D12 stuff is basically just same as D3D11 but with a somewhat simplified API. So don't get your expectations up to high.
I suggest testing if your AMD issues also occur with the Movies&TV player from Windows.
MPC-HC 2.2.1 |
12th March 2022, 14:42 | #24760 | Link | |
MPC-HC Developer
Wait a sec... What is not working on AMD cards?
Anyway I don't think there is any gain of using D3D12 at this moment. It is just an API on top of the same hardware decoder. Maybe adding video processing (like deinterlacing) to LAV would be more fun? |
