29th August 2017, 01:59 | #3241 | Link |
MPC-HC Need subtitle help
Hi, been using MPC-HC for a long time, with the latest version finally you incorporated the ability to search from multiple subtitle websites (I was using a previous version in beta, I think that had that ability). Anyway, I have "download subtitles automatically" checked and for weeks now it has worked perfectly, open a movie, MPC searches for and find subtitles and automatically uses the first one, without the subtitle box popping up.
However for the last few days, instead of the subtitles downloading and playing, the box pops up all the time for me to choose which one to use. Do you have any idea why this has happened, and if there is a fix for it?? |
9th September 2017, 04:34 | #3242 | Link | |
maybe it is more efficient to use libass for subtitle rendering. it a big change but MPC HC is benefiting from the stead development of libass in the long run. |
9th September 2017, 13:32 | #3243 | Link | ||
For this video 'bestvideo' and 'bestaudio' correspond to: Code:
youtube-dl.exe -F aqz-KE-bpKQ format code extension resolution note 258 m4a audio only DASH audio 387k , m4a_dash container, mp4a.40.2, 29.15MiB 315 webm 3840x2160 2160p60 28416k , vp9, 60fps, video only, 1.63GiB Code:
youtube-dl.exe -F aqz-KE-bpKQ format code extension resolution note 17 3gp 176x144 small , mp4v.20.3, mp4a.40.2@ 24k 36 3gp 320x180 small , mp4v.20.3, mp4a.40.2 43 webm 640x360 medium , vp8.0, vorbis@128k 18 mp4 640x360 medium , avc1.42001E, mp4a.40.2@ 96k 22 mp4 1280x720 hd720 , avc1.64001F, mp4a.40.2@192k (best) youtube-dl.exe -f best -o - aqz-KE-bpKQ | mpc-hc.exe - /close Code:
FOR /F %A IN ('youtube-dl.exe -gf bestvideo aqz-KE-bpKQ') DO ( FOR /F %B IN ('youtube-dl.exe -gf bestaudio aqz-KE-bpKQ') DO ( ffmpeg.exe -i %A -i %B -c copy -f nut - | mpc-hc.exe - /close ) ) Code:
FOR /F %A IN ('youtube-dl.exe -gf bestvideo aqz-KE-bpKQ') DO ( FOR /F %B IN ('youtube-dl.exe -gf bestaudio aqz-KE-bpKQ') DO ( mpc-hc.exe %A /dub %B ) ) ------ A question to the MPC-HC devs on my part: Code:
mpc-hc /? /dub "dubname" Load an additional audio file /sub "subname" Load an additional subtitle file /sub on the other hand does not. Could you, just like MPC-BE, have it accept subtitle urls as well?! But then I guess it won't do me any good, because new versions won't work on my WinXP pc...
My hobby website |
9th September 2017, 17:35 | #3244 | Link |
So out of the blue MPC-HC created a folder named "MPC-HC Capture" in My Documents.
I regularly check the My Documents folder and it was literally created on 9-9-2017 0:13 as of today. Any clue on how that folder got in there? Since I don't use any capture software whatsoever. Thanks. Last edited by bitterman; 9th September 2017 at 17:38. |
9th September 2017, 17:49 | #3245 | Link |
It's common that apps write to default windows locations, don't use such locations, problem solved.
9th September 2017, 18:16 | #3246 | Link |
I understand, but why did MPC-HC created this (empty) folder anyway?
Did I accidentally clicked on a key which triggered something? Even in the options all of the capture settings are greyed out. Because I don't use that stuff. I'm just a little bit flabbergasted about this. Last edited by bitterman; 9th September 2017 at 18:26. |
10th September 2017, 11:30 | #3247 | Link | ||
After almost 2 years the internal audio renderer is finally fixed! Thanks so much, @kasper93! I also made a (hopefully) small feature request about it.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
10th September 2017, 14:41 | #3249 | Link | |
Edit: Have you selected the Internal Audio renderer under Output?
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 10th September 2017 at 15:19. |
10th September 2017, 15:21 | #3251 | Link |
Btw, this change alone deserves at lest a minor version number bump if not a major one! It fixes such a huge bug!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 10th September 2017 at 15:35. |
15th September 2017, 13:39 | #3253 | Link |
Hi all,
I've being using MPC-HC for years on many setups, I always install the portable x64 version, run it with default settings and everything is fine. In my latest laptop (MSI GL62 with Intel HD 630 and NVIDIA 1050Ti), the video is choppy. I have the latest driver for the Intel HD 630 (from last month) and for NVIDIA (same, from last month). Device manager is all clear from issues and everything is recognized. The coppy playback happen on all type of files, from 720P to 1080P and increase as I increase the screen of the MPC-HC window. Same happen with VLC. If it helps, when I try to play with the volume keys (up and down arrow), the playback almost stop!). Check out the image below: https://imgur.com/a/Ljbu4 Would appreciate any help. |
18th September 2017, 09:47 | #3259 | Link |
Sorry if this has been discussed before but when running build .112 with internal LAV + madVR everything is O.K. !!
But when I use external LAV filters (even with the same as the internals(.66)) I loose h/w-acceleration. After blocking external LAV video decoder it works again. I already tried re-installing external LAV with reset. Does anyone maybe have an idea/solution ? |
dxva, media player classic, mpc, mpc-hc |
