Old 29th July 2023, 17:21   #1  |  Link
martynuzza
x262 MPEG-2 encoder in commercial DVD production?
Hi. I think I've found a DVD I bought, which was encoded with x262.
The movie is "L'ULTIMA NOTTE DI AMORE" (2023). This is the mediainfo:
General
Complete name                            : C:\Users\utente\Desktop\VTS_01_1.VOB
Format                                   : MPEG-PS
File size                                : 1 024 MiB
Duration                                 : 18 min 37 s
Overall bit rate mode                    : Variable
Overall bit rate                         : 7 687 kb/s
Writing library                          : x264 - core 130 r2508M 37d9949 - H.264/MPEG-4 AVC codec - Copyleft 2003-2013 - http://www.videolan.org/x264.html - options: cabac=0 ref=1 mpeg2=1 deblock=0:-2:-2 analyse=0:0 me=tesa subme=9 psy=1 psy_rd=1.00:0.15 mixed_ref=0 me_range=24 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=22,15 fast_pskip=0 chroma_qp_offset=-2 threads=54 lookahead_threads=4 sliced_threads=0 nr=0 decimate=0 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=2 b_pyramid=0 b_adapt=0 b_bias=0 direct=0 weightb=0 open_gop=0 weightp=0 keyint=12 keyint_min=1 scenecut=0 intra_refresh=0 rc_lookahead=12 rc=2pass mbtree=1 bitrate=6500 ratetol=1.0 qcomp=0.60 qpmin=1 qpmax=31 qpstep=4 cplxblur=20.0 qblur=0.5 vbv_maxrate=8700 vbv_bufsize=1835 nal_hrd=none ip_ratio=1.40 aq=1:0.70
Video
Format                                   : MPEG Video
Format version                           : Version 2
Format profile                           : Main@Main
Format settings                          : BVOP
Format settings, BVOP                    : Yes
Format settings, Matrix                  : Default
Format settings, GOP                     : M=3, N=12
Bit rate mode                            : Variable
Bit rate                                 : 6 702 kb/s
Maximum bit rate                         : 8 700 kb/s
Width                                    : 720 pixels
Height                                   : 576 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 25.000 FPS
Standard                                 : PAL
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.646
Time code of first frame                 : 00:00:00:00
Time code source                         : Group of pictures header
GOP, Open/Closed                         : Closed
Stream size                              : 892 MiB (87%)
Color primaries                          : BT.601 PAL
Transfer characteristics                 : BT.470 System B/G
Matrix coefficients                      : BT.470 System B/G
Audio #1
ID                                       : 189 (0xBD)-128 (0x80)
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : Dolby Digital
Muxing mode                              : DVD-Video
Duration                                 : 18 min 36 s
Bit rate mode                            : Constant
Bit rate                                 : 192 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Stream size                              : 25.6 MiB (2%)
Service kind                             : Complete Main
Audio #2
ID                                       : 189 (0xBD)-129 (0x81)
Format                                   : AC-3
Bit rate                                 : 448 kb/s
Channel(s)                               : 6 channels
Channel layout                           : L R C LFE Ls Rs
Stream size                              : 59.6 MiB (6%)
Audio #3
ID                                       : 189 (0xBD)-130 (0x82)
Format                                   : AC-3
Bit rate                                 : 192 kb/s
Text
ID                                       : 189 (0xBD)-32 (0x20)
Format                                   : RLE
Format/Info                              : Run-length encoding
Menu
Format                                   : DVD-Video
Is it really possible that it was used professionally and commercially? The disc is for sale on amazon and everywhere.
martynuzza is offline   Reply With Quote
Old 30th July 2023, 11:15   #2  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Given how widespread x262 is in Italy I wouldn't be surprised.
What I'm surprised to see though is that they didn't stripe off the writing library as it's generally done instead.
Old 22nd August 2023, 20:48   #3  |  Link
Brazil2
Originally Posted by martynuzza View Post
General
Format                                   : MPEG-PS
Video
Format                                   : MPEG Video
There is something wrong in this report, x264 has never ever created MPEG2 files but H.264/AVC ones...
Brazil2 is offline   Reply With Quote
Old 22nd August 2023, 22:38   #4  |  Link
rwill
options: cabac=0 ref=1 mpeg2=1 deblock=0:-2:-2 ... (emphasis mine)
its from x262? like what this thread is about?
Old 22nd August 2023, 23:08   #5  |  Link
benwaggoner
Yeah, there ain't no in-loop deblocking in MPEG-2!
(sometimes I think of VC-1 as the final spiritual successor of MPEG-2/H.263, with H.264 as the first of a new generation of codec approaches).
Ben Waggoner
My Compression Book
