#1 | Link | |
Incompatible HDR10+ Injection
For my source mkv file, MediaInfo shows the follwing video info:
ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@Main HDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 55 min 49 s Bit rate : 3 644 kb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.018 Stream size : 1.42 GiB (89%) Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1 170 cd/m2 Maximum Frame-Average Light Level : 320 cd/m2 Code:
hdr10plus_tool extract source.mkv -o source_hdrinfo.json Code:
hdr10plus_tool.exe inject -i target.hevc -j source_hdrinfo.json -o target_injected.hevc Quote:
How can I do a proper injection here? |
#2 | Link |
Mastering display and content light level info is located in the SEI, I'm not sure how hdr10plus_tool handles that, but from the result I assume it's not handling that.
(And the matrix transfer primaries chromaloc are located in VUI in SPS, your result seems not containing that as well) (Which actually, is probably the real reason why it's not recognized, not the lack of mastering and cll info) |
#4 | Link |
IDK but it doesn't matter. Fix your base bitstream.
You can use FFmpeg bitstream filter hevc_metadata to fix the VUI info, don't really have a good idea about the mastering and cll SEI but that's just a little bonus. Code:
ffmpeg -i a.265 -bsf:v hevc_metadata=colour_primaries=9:transfer_characteristics=16:matrix_coefficients=9:video_full_range_flag=0 -c copy b.265 Last edited by Z2697; 12th October 2025 at 22:36. |
| Tags |
| hdr, hdr10+, hdr10plus_tool, hevc. h.265 |
| Thread Tools | |
| Display Modes | |
