Thread Tools Display Modes
Old 1st August 2025, 11:06   #1  |  Link
Encore
DTS-X demuxing preferred file extension?
Hello guys,
I have been ripping and remuxing UHD-BDs for backing up and now almost running out of HDD spaces and not wanting to purchase more. I decided to encode my remuxes. Many of these have dts-x.7.1 audios. Unlike TrueHD audio (.thd) dts audios have three extensions (.dts, .dtsma and .dtshd ). My question is, what is the appropriate extension to use when demuxing dts-x.7.1 audio to preserve the height channel data?
Below is one of .dts audio file I did from a dts-x remux.
Audio
Format                                   : DTS XLL X
Format/Info                              : Digital Theater Systems
Commercial name                          : DTS-HD MA + DTS:X
Bit rate mode                            : Variable
Channel(s)                               : 8 channels
Channel layout                           : C L R LFE Lb Rb Lss Rss Objects
Sampling rate                            : 48.0 kHz
Frame rate                               : 93.750 FPS (512 SPF)
Bit depth                                : 16 bits
Compression mode                         : Lossless
Encore is offline   Reply With Quote
Old 1st August 2025, 23:56   #2  |  Link
tebasuna51
tebasuna51's Avatar
You can use any extension without problems (I use always .dts) because all audio software read the header to know the properties no mather the file extension.
Old 2nd August 2025, 08:20   #3  |  Link
Encore
Thanks tebasuna51. I have demuxed using .dts and .dtshd and media info show same details. But, I haven't had proper testing in my HT to see any difference. As, I want to delete remuxes, I thought of asking.
demuxing., dts-x.7.1, file extension
Thread Tools
