Thread Tools Display Modes
Old 12th January 2025, 01:14   #1  |  Link
jay123210599
Video to Gif Error
Whenever I use ffmpeg to try to convert a yuv420p video to gif, I get this:
[swscaler @ 0000019797c785c0] [swscaler @ 00000197921477c0] No accelerated colorspace conversion found from yuv420p to bgr8.
[swscaler @ 0000019797c785c0] [swscaler @ 000001979215e7c0] No accelerated colorspace conversion found from yuv420p to bgr8.
[swscaler @ 0000019797c785c0] [swscaler @ 000001979216ef00] No accelerated colorspace conversion found from yuv420p to bgr8.
[swscaler @ 0000019797c785c0] [swscaler @ 000001979217f600] No accelerated colorspace conversion found from yuv420p to bgr8.
[swscaler @ 0000019797c785c0] [swscaler @ 000001979264be80] No accelerated colorspace conversion found from yuv420p to bgr8.
[swscaler @ 0000019797c785c0] [swscaler @ 0000019792658e40] No accelerated colorspace conversion found from yuv420p to bgr8.
[swscaler @ 0000019797c785c0] [swscaler @ 0000019792665e40] No accelerated colorspace conversion found from yuv420p to bgr8.
[swscaler @ 0000019797c785c0] [swscaler @ 0000019792672e00] No accelerated colorspace conversion found from yuv420p to bgr8.
[swscaler @ 0000019797c785c0] [swscaler @ 0000019792698500] No accelerated colorspace conversion found from yuv420p to bgr8.
[swscaler @ 0000019797c785c0] [swscaler @ 0000019792d600c0] No accelerated colorspace conversion found from yuv420p to bgr8.
[swscaler @ 0000019797c785c0] [swscaler @ 0000019792d6d080] No accelerated colorspace conversion found from yuv420p to bgr8.
[swscaler @ 0000019797c785c0] [swscaler @ 0000019792dfbbc0] No accelerated colorspace conversion found from yuv420p to bgr8.
[swscaler @ 0000019797c785c0] [swscaler @ 0000019792e12f80] No accelerated colorspace conversion found from yuv420p to bgr8.
How do I fix this?
jay123210599 is offline   Reply With Quote
Old 12th January 2025, 02:10   #2  |  Link
Z2697
Contribute to FFmpeg.
Z2697 is offline   Reply With Quote
Old 12th January 2025, 02:26   #3  |  Link
jay123210599
I'm serious.
Old 12th January 2025, 02:50   #4  |  Link
there is no information to work with...
you try to use hardware acceleration which the api can't do.
Old 12th January 2025, 04:27   #5  |  Link
Z2697
Originally Posted by jay123210599 View Post
I'm serious.
I'm also serious.
Old 12th January 2025, 04:30   #6  |  Link
Z2697
If you mean GPU acceleration that's not actually the case here.
I didn't look into the specific piece of code which triggered this warning but I think what it actually means is instruction sets optimization / acceleration.
The warning is because the optimization / acceleration is not implemented.
Old 12th January 2025, 07:17   #7  |  Link
GeoffreyA
Yes. Probably, it's just the plain C code, and that specific path hasn't got an SIMD version.
GeoffreyA is online now   Reply With Quote
Old 12th January 2025, 07:18   #8  |  Link
GeoffreyA
How do I fix this?
Is the result all right?
Old 12th January 2025, 13:10   #9  |  Link
jay123210599
Here's the command I used:
Here's the information of my video:
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High 4:4:4 Predictive@L4
Format settings                          : CABAC / 3 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 3 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 8 s 13 ms
Bit rate                                 : 92.5 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (23976/1000) FPS
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 1.860
Stream size                              : 88.3 MiB (98%)
Writing library                          : x264 core 157 r2935M 545de2f
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=7 / psy=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=cqp / mbtree=0 / qp=0
Default                                  : No
Forced                                   : No
Color range                              : Limited
Matrix coefficients                      : BT.709
Old 12th January 2025, 14:00   #10  |  Link
GeoffreyA
Adding the accurate-rounding flags removes the warning.
-sws_flags accurate_rnd+full_chroma_int
As noted a couple of weeks ago, a palette can be used for better quality, but it takes more time.
https://forum.doom9.org/showthread.p...27#post2011227
ffmpeg -colorspace bt709 -i INPUT -vf palettegen -sws_flags accurate_rnd+full_chroma_int "palette.png"
ffmpeg -colorspace bt709 -i INPUT -i "palette.png" -lavfi paletteuse -sws_flags accurate_rnd+full_chroma_int "OUTPUT.gif"
ffmpeg, yuv420p
Thread Tools
