Thread Tools Display Modes
Old 12th February 2026, 12:18   #1721  |  Link
DMD
DMD's Avatar
Originally Posted by Kuler087 View Post
Thank you for your great dedication to this new release, as always.
my PC with Ryzen 7950X
DMD is offline   Reply With Quote
Old 13th February 2026, 00:49   #1722  |  Link
coopzr
Can you please let me know how the upgrade to cmv4.0 works on your latest beta?
I thought that you couldn't replace the L1 from cmv2.9 to cmv4.0. I don't have a clue how this works.
When should this be used? (Only when the content doesn't exceed display capabilities, or always?)
Are there any downsides or weird behaviour?
coopzr is offline   Reply With Quote
Old 13th February 2026, 01:10   #1723  |  Link
Kuler087
Kuler087's Avatar
It doesn’t replace the metadata; it simply generates a CMV 4.0 block with level 9.
L2 will then be ignored at playback, but if the content stays within your target TV brightness, it won’t matter. In that case, you avoid CMV 2.9 black crush and the 4000-nits MDL overdimming issues.
So this is essentially a quick workaround to fix CMV 2.9 playback, rather than generating new metadata from scratch. As you know, CoreELEC will most likely get this feature soon, which is even bette, nothing to process manually before watching a movie.
Workflow 1, skip 2nd input and select ''u''
DoVi_Scripts //// Dolby Vision Stuff (more tabs below)
LG OLED G5 77'' + 7.2.4 Denon AVR + Ugoos AM6Bplus + Kaleidescape Strato E
Sorry for my English
Kuler087 is offline   Reply With Quote
Old 13th February 2026, 02:47   #1724  |  Link
coopzr
So essentially, it changes the RPU version to 4.0. It keeps the same old levels and adds the L9 level.
So it's essentially the old levels in a newer container.
L2 is ignored by the player because L2 is always ignored in cmv4.0.
Is that right?
Old 13th February 2026, 03:10   #1725  |  Link
Kuler087
Kuler087's Avatar
Yes
L2 will be ignored if the TV supports cmv4.0
Old 13th February 2026, 04:21   #1726  |  Link
coopzr
In a normal cmv4.0 metadata with no mid tone offset trim, do video players use L3?
If they use it: what happens if it is removed?
If they don't use it: what is the point of the automatic data?
These questions are assuming no mid tone offset trim and only the automatic data generated by the algorithm.
Old 13th February 2026, 04:30   #1727  |  Link
Kuler087
Kuler087's Avatar
Of course, the player uses L3 and L1 together.
I did many L3 test files here:
https://drive.google.com/drive/folde...usp=drive_link
and many real scene comparisons here:
https://drive.google.com/drive/folde...iSlcdMiy2ka0mf
Old 13th February 2026, 05:19   #1728  |  Link
coopzr
So that would imply that upgrading to cmv4 (which does not generate L3) would be inferior to generating it, right?
Old 13th February 2026, 12:54   #1729  |  Link
Kuler087
Kuler087's Avatar
yes but not for content that is under your display peak brightness
Old 13th February 2026, 20:39   #1730  |  Link
en6ads
Hmm. I don't see "u" as an option listed in workflow 1 (version 3.1.1). Is there a newer beta than 3.1.1?
  - INPUT INFO  -
Parsing RPU file...
Summary:
  Frames: 552
  Profile: 7 (FEL)
  DM version: 1 (CM v2.9)
  Scene/shot count: 2
  RPU mastering display: 0.0001/1000 nits
  RPU content light level (L1): MaxCLL: 147.74 nits, MaxFALL: 10.05 nits
  L6 metadata: Mastering display: 0.0001/1000 nits. MaxCLL: 546 nits, MaxFALL: 129 nits
  L5 offsets: top=0, bottom=0, left=440, right=440
  L2 trims: 100 nits, 600 nits, 1000 nits
  Base Layer (HDR10+P7): min: 0.0001 cd/m2, max: 1000 cd/m2(Display P3), MaxCLL: 1000nits, MaxFALL: 129nits
  Resolution\FPS: 3840 x 2160 @ 23.976
  Input: "U:\movies\Sunset Boulevard (1950)\Sunset Boulevard (1950) - 2160p Paramount 2025 USA-DV P7 FEL CM2.9-1000nit MDL.mkv"
  Output Path Free Space: 2321gb
  *You can select more than one value but no space between values (except: e/m/p/s/7/v/r/t).
  *EG: You can select 569fp4 or 569dp4 but not 569p4fd, 569p4fr, 569p4ms, emsv, etc...
  CHOICES: (default=X  - check another file)
  Check_New_File=X   L5=5   L6=6   L9=9   Resync=R or D   SceneCut_Edit=F   Source_PQ=Q
  PLOT=P   Extract=E   Check_Sync=S   Metafier=M   Transfer_Levels=T   P7_to_P8=7   Remover=V  No.DV.TM=N
I tried "u" anyway can it generates this, still a CM2.9 FEL. What am I missing?:
  - INPUT INFO  -
Parsing RPU file...
Summary:
  Frames: 552
  Profile: 7 (FEL)
  Scene/shot count: 2
  Input: "C:\video\DoVi.Scripts-3.1.1\Sunset Boulevard (1950) - 2160p Paramount 2025 USA-DV P7 FEL CM2.9-1000nit MDL_DV.mkv"
  Output Path Free Space: 2265gb
en6ads is offline   Reply With Quote
Old 13th February 2026, 20:46   #1731  |  Link
Kuler087
Kuler087's Avatar
This new option was added to the beta yesterday. It seems every time I release a new stable, I get a new idea the next day...
Old 13th February 2026, 20:55   #1732  |  Link
en6ads
Awesome I'll try the new beta. Thank you!
Old 15th February 2026, 20:27   #1733  |  Link
dkangel
Il y a du plagiat dans l'air !!!
https://github.com/MaitreAnonyme/Mai...leases/tag/2.0
dkangel is offline   Reply With Quote
Old 15th February 2026, 22:11   #1734  |  Link
Kuler087
Kuler087's Avatar
héhéhé
Old 17th February 2026, 18:56   #1735  |  Link
Enet47
Dee
I've done a thread search on heere and checked the Git but I still don't understand where DEE.exe(?) or the DEE folder is or how to install it. Is it part of the much larger Tools package? Also, does the new FEL functionality mean that I no longer need to convert to 8.1?
Enet47 is offline   Reply With Quote
Old 17th February 2026, 19:16   #1736  |  Link
Kuler087
Kuler087's Avatar
DEE is a paidware, and you just have to put the whole DEE folder into the dovi_scripts Tools folder.
Not really because:
DEE does hevc re-encoding (lossy) and the P7 to P8 doesnt re-encode (lossless).
The FEL encoding workflow can encode any DV video, but it is mostly intended for 12bit mezzanine file (prores or jpeg 2000).
Old 17th February 2026, 20:04   #1737  |  Link
Enet47
Not really because:
Thanks
Old 18th February 2026, 15:04   #1738  |  Link
Kontrarian
Kontrarian's Avatar
I can't get 3-1 to work for some reason. I tried using the latest beta .bat, I've tried updating the tools, changing the DIR DoVi_Scripts to DoVi.Scripts, etc. It always gets stuck at this line:
Frame 588 complete. Last frame: 0.534 seconds. ETA: 33:47:46.130
But the completed frame will be different.
Here's the full code from my last attempt: https://pastebin.com/LJdD6Pwe
Kontrarian is offline   Reply With Quote
Old 18th February 2026, 15:18   #1739  |  Link
Kuler087
Kuler087's Avatar
I had those issues before on my Windows 11 PC, and I have no idea how it corrected itself. It seems it is related to the gpu drivers version, Windows update, and cm_analyze...
Old 18th February 2026, 15:56   #1740  |  Link
ac777103
just checking my understanding of the new CMV4 upgrade option via workflow 1. Are there any negative effects vs the vanilla 2.9 playback, or only potential benefits? I guess this will work equally for both MEL and FEL? Trying to think if there is a reason not to do this for all my 2.9 files.
ac777103 is offline   Reply With Quote
batch scripts, dolby vision processing, dovi_scripts
Thread Tools
