Thread Tools Display Modes
Old 20th September 2017, 11:36   #1  |  Link
theluckyman
Is this tool is right for fix subtitles and rebuild DVD?
I was gonna backup original disc of 'Going in Style (2017)' but subtitle is gray and hard to read so if I was gonna use this tool just to rebuild exact same way but fix subtitle issue, will it work or could you guys point me which tool should I use to get subtitles fix like normal which it should have?
Thanks,
concerned
theluckyman is offline   Reply With Quote
Old 20th September 2017, 14:21   #2  |  Link
Ghitulescu
Ghitulescu's Avatar
which tool are you referring to?
Born in the USB (not USA)
Old 20th September 2017, 16:55   #3  |  Link
rjd0309
Wanted Dead or Dead
rjd0309's Avatar
If you just want to change the color of the subtitles, it's just a matter of altering a few of the colors in the Color Lookup Table (CLUT) in the IFO file. Any number of tools can do this -- DvdSubEdit, DvdReMake, PgcEdit.
rjd0309 is offline   Reply With Quote
dvd fix, subtitle help, subtitle issue
Thread Tools
