Old 20th January 2023, 11:09   #8961  |  Link
Barough
Barough's Avatar
x265 v3.5+87
Built on January 20, 2023, GCC 12.2.0
https://www.mediafire.com/file/iz8fqi7rqpi55sm
Old 20th January 2023, 19:12   #8962  |  Link
benwaggoner
Originally Posted by ShortKatz View Post
Nope, the patch still does apply. So, I was wondering, if this bug is so big and there since (minimum) 2018, why did no one else notice?
Have been a before/after analysis to show the benefits of the fix?
Ben Waggoner
My Compression Book
Old 20th January 2023, 21:52   #8963  |  Link
jpsdr
I've made a new build of my custom version, small quick encode test seems fine.
Check my Github.
My github.
Old 21st January 2023, 05:25   #8964  |  Link
TDS
Formally known as .......
TDS's Avatar
Check my Github.
I have done a lot of testing, you maybe interested in the results:-
https://forum.doom9.org/showthread.p...17#post1981517
https://forum.doom9.org/showthread.p...53#post1981553
But only up to build 85.
This can be SO "TeDiouS"..
Long term RipBot264 user.
#1 Ryzen 7950X
#2 Intel i9-13900KF
#3 Ryzen 5950X
#4 Ryzen 5900X
#5 Ryzen 3950X
TDS is offline   Reply With Quote
Old 21st January 2023, 23:45   #8965  |  Link
LeXXuz
20 years and counting...
LeXXuz's Avatar
Check my Github.
jpsdr, I have been using v+75 with extra switches: "--aq-mode 5 --sbrc --sbrc-aq5 --sbrc-hyst" for 1080p SDR content.
Is this still valid with v+87? A lot of talk about new switch names here which confuses me a little.
LeXXuz is offline   Reply With Quote
Old 22nd January 2023, 10:40   #8966  |  Link
jpsdr
@LeXXuz
For the same command line effect, you have to replace --sbrc --sbrc-aq5 --sbrc-hyst with --aq-auto 10 assuming you don't want the new sbrc (wich has totaly nothing to do with the first patch) and just keep the auto AQ feature.
(And still check with the log file )
My github.
Old 22nd January 2023, 12:37   #8967  |  Link
LeXXuz
LeXXuz's Avatar
@LeXXuz
Thank you jpsdr. Actually I'm not sure if I want or need the new sbrc as I don't fully understand what it does and if it is beneficial for my usage.
So with the latest version I just add "--aq-mode 5 --aq-auto 10", is that right?
EDIT: Btw the clang version shows "x265 [INFO]: build info [Windows][MSVC 1928][64 bit] 10bit", is that correct
Old 23rd January 2023, 06:17   #8968  |  Link
Boulder
Pig on the wing
Boulder's Avatar
If you want to use the automatic AQ mode with AQ5 + hysteresis enabled, just use --aq-auto 10. --aq-auto 6 for HDR (enables auto mode + hysteresis, no AQ3 or AQ5 used since it's counterproductive).
Old 23rd January 2023, 18:34   #8969  |  Link
jpsdr
Yes, because it's build with llvm but still with Visual Studio (so using clang compiler instead).
My github.
Old 30th January 2023, 05:59   #8970  |  Link
Boulder
Pig on the wing
Boulder's Avatar
@jpsdr: I've seen mentioned in some places that AQ mode 4 needs a bit lower aq-strength than other modes. Would it be possible to have a separate aq-strength parameter for it in case aq-auto is enabled?
Old 30th January 2023, 21:22   #8971  |  Link
jpsdr
@Boulder
Euh... I don't know. I'll see but absolutely not promises... Don't have time for now.
My github.
Old 31st January 2023, 05:57   #8972  |  Link
Boulder
Pig on the wing
Boulder's Avatar
@Boulder
Thank you
I was thinking that it might be as simple as adding the parameter and then conditionally using it as the base strength when the mode for the frame is either X265_AQ_EDGE or X265_AQ_EDGE_BIAS.
Old 31st January 2023, 18:29   #8973  |  Link
jpsdr
@Boulder
For X265_AQ_EDGE the calcul is:
                            inclinedEdge = curFrame->m_lowres.edgeInclined[blockXY];
                            qp_adj = curFrame->m_lowres.qpCuTreeOffset[blockXY];
                            if(inclinedEdge && (qp_adj - avg_adj > 0))
                                qp_adj = ((strength + AQ_EDGE_BIAS) * (qp_adj - avg_adj));
                            else
                                qp_adj = strength * (qp_adj - avg_adj);
So, you want something that can change the value of strength when aq-auto is enabled ?
If it's that, 2 options. Somethings like strength2 = strength*coeff or strength2 = strength + bias with coeff=1 or bias=0 when aq-auto is disabled and use strength2 instead of strength in calcul.
And if i add some kind of AQ4 specific parameter, it can be applied to AQ 4 mode, with or without aq-auto enable, if default value keeps original behavior.
My github.
Old 31st January 2023, 19:20   #8974  |  Link
Boulder
Pig on the wing
Boulder's Avatar
What I was thinking was basically that - having AQ 4 its own strength parameter. Maybe making it equal to aq-strength in case aq-auto is not enabled so any command line would work normally.
I was wondering if it would make sense to just change the calculation of 'strength' here, I haven't had the time to get the whole idea to work because the compiled exe won't accept my new parameters for some reason. What I did was just carbon copy the existing aq-strength and aq-bias-strength parameters in various files and adjust the variable names accordingly, but probably I've missed something. In this example there's also a different value for AQ 5 bias strength.
                    if (param->rc.aqMode == X265_AQ_EDGE || param->rc.aqMode == X265_AQ_EDGE_BIASED)
                        strength = param->rc.aqStrengthEdge * avg_adj;
                    else
                        strength = param->rc.aqStrength * avg_adj;
                    avg_adj = avg_adj - 0.5f * (avg_adj_pow2 - modeTwoConst) / avg_adj;
                    if (param->rc.aqMode == X265_AQ_EDGE_BIASED)
                        bias_strength = param->rc.aqBiasStrengthEdge * param->rc.aqStrengthEdge;
                    else
                        bias_strength = param->rc.aqBiasStrength * param->rc.aqStrength;
Old 1st February 2023, 20:35   #8975  |  Link
jpsdr
Is it what you want ?
https://github.com/jpsdr/x265/commit...6dc36cef1d1880
My github.
Old 2nd February 2023, 05:51   #8976  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Yes, that looks exactly what I thought of doing Thank you so much, I really appreciate it
Old 2nd February 2023, 14:21   #8977  |  Link
jpsdr
I don't know when i'll be able to make a build (as it takes time), maybe this evening, maybe in few days, but you still can make your own build frommy github.
My github.
Old 2nd February 2023, 19:20   #8978  |  Link
Boulder
Pig on the wing
Boulder's Avatar
No worries, I created a diff file to use for patching in Media Autobuild Suite so I got a compiled exe to test. First impression looks good, so I believe it's working. I didn't do any frame by frame compares but just watched an encoded clip to see if anything's weird.
Old 5th February 2023, 11:43   #8979  |  Link
jpsdr
If you have your own build, in that case, i'll realy take my time to make a new build...
My github.
Old 5th February 2023, 11:55   #8980  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Yeah, no problem with that
If anyone wants to test the modifications, here's the build I made. 10-bit only, and optimized for Zen 3. I can also provide the patch file I used if needed.
https://drive.google.com/file/d/1WGi...usp=share_link
