#8761 | Link | |
![]() Join Date: Jan 2006
You mean can rarely process 8-bit HEVC without also supporting 10-bit HEVC, right?
#8763 | Link | |
#8765 | Link |
About "histogram" vs "classic", what about hrd-pq ? If Boulder's video is 8 bit, i assume it sdr, so the "issue" is maybe main10 / 10 bits sdr video...
Has someone made tests to see if "histogram" behaves better than "classic" with main10 / 10 bits video in hdr-pq ?
My github. |
#8766 | Link | |
Pig on the wing
So the issue is probably seen with SDR sources encoded with the Main10 profile.
#8770 | Link |
x265 v3.5+69
https://www.mediafire.com/file/kuh2ekbo2p6a7rf/ |
#8773 | Link |
.... There is not...? I ran cmake to create a VS projet and checked all possible options, i thought all the supports were enabled.
Setting --profile main, -D 8 (and all others related stuff saying that video is 8 bits) on the command line is not working ? If not, for now, unfortunately i don't know what to do for... ![]()
My github. |
#8774 | Link |
If you enabled HIGH_BIT_DEPTH when configuring the build, it only builds 10 bit.
12 bit if you do MAIN12 too. There's a multilib script to get a statically linked executable with all bit depths. I can't really help for Windows/VS though.
LG C2 OLED | GitHub Projects |
#8775 | Link | ||
20 years and counting...
#8776 | Link |
Ah.... Don't know how to do it for now, don't realy have time for now, sorry. Try to see if i can figure out something when there will be the need for a new build.
Otherwise, anyone can also make a build from my repo.
My github. |
#8777 | Link |
I just noticed that the new histogram scene cut commit removed the logging of consecutive B frames %, seemingly for no reason.
If anyone had a use for it, here's a diff: https://github.com/quietvoid/x265/co...a35be4377e390e Should probably be renamed from m_histogram now but I just copied the old code back.
#8778 | Link |
Pig on the wing
Here's a very crude tool written in Python to get those average figures out of the csv log file written with csv-log-level 2 set. It expects that SSIM or PSNR is not enabled as those change the column structure. Only tested with two csv files I had on my HDD
![]() Usage: "python logtool.py filename.csv". It will then write a .log file to the path where the csv file is and output the same information in the command prompt window. Code:
import pandas as pd import os import sys filename = os.path.abspath(sys.argv[1]) log_content = pd.read_csv(filename, sep=",", decimal=".", header=0) log_content = log_content.iloc[:-4,11:-9] log_content.columns = log_content.columns.str.replace('.1', '', regex=True) log_content.columns = log_content.columns.str.replace('66', ' 16x16', regex=True) log_content.columns = log_content.columns.str.replace('326', ' 32x16', regex=True) log_content.columns = log_content.columns.str.replace('6x32', ' 16x32', regex=True) log_content.columns = log_content.columns.str.replace('6x8', ' 16x8', regex=True) log_content.columns = log_content.columns.str.replace('86', ' 8x16', regex=True) log_content.columns = log_content.columns.str.replace('AMP6', 'AMP 16', regex=True) log_content = log_content.replace('%', '', regex=True).astype(float) average = log_content.describe().loc['mean'].to_string() print (average) with open(filename+str('.log'), mode='w') as outputfile: outputfile.write(str(average)) outputfile.close()
#8779 | Link |
piping to x265 with powershell
sorry if that is too off-topic... this works just fine in a command prompt: ffmpeg.exe -i FILE -pix_fmt yuv420p10le -strict -1 -f yuv4mpegpipe - | x265.exe - --y4m .....etc. Now I wanted to use Powershell for that and the piping isn't working, the x265 process doesn't even start, while ffpmpeg is running: It seems that using the pipe character isn't working here. Does anyone have an idea? |
#8780 | Link | |
Lost my old account :(
There are some workaround and more info here https://stackoverflow.com/questions/...-in-powershell |
