Old 24th January 2021, 14:06   #7961  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Chromaloc seems like a big misfire to me at this point, since so many encoders and decoders don't actually encode/decode differently based on the parameter. Other than for HDR Blu-Ray, which requires chromaloc 2, I recommend leaving it at the default for broader compatibility.
At 4K resolutions, getting it wrong is pretty hard to see, but the lower the frame size, the more screen area an error will take up.
True, but the thing is that he was using chromaloc 2 in x265 but his input (the AVS Script output) wasn't, so it was just wrong. Either he specifies the normal 4:2:0 or he converts it to type2 and specifies chromaloc 2. That's what I meant
FranceBB is online now   Reply With Quote
Old 25th January 2021, 10:43   #7962  |  Link
outhud
Originally Posted by LigH View Post
Success! With the great support of Christopher Degawa, main supporter of the media-autobuild suite, I was able to tweak my workflow until I could build an x265 binary with Yuuki-Asuna mod (Asuna branch = based on v3.4-stable). It required some pkgconfig tuning and I found a way to use the "video decoders only" light ffmpeg build as already used by m-ab-s in its x264 binary (option 6); so it should contain support for AVS input, VPY input, LAVF input, MP4 output (L-SMASH), MKV output (Haali, obsolete), and ZIMG scaling.
Very nice! Thank you.
outhud is offline   Reply With Quote
Old 25th January 2021, 14:31   #7963  |  Link
K.i.N.G
Has anyone done any re-tests recently to see if SAO has improved?
It's been a while since I've tested it and concluded not to use it (removed too much detail)
K.i.N.G is offline   Reply With Quote
Old 25th January 2021, 16:28   #7964  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
there hasn't been any work on SAO for a long time. So doubtful
TV: Samsung 50" QE50Q60T AVR: Yamaha RX-V481 5.1 CD Player: Yamaha CD-S300 DAB+ Tuner: Yamaha T-D500 BD Player: Samsung UBD-M8500 UHD Speakers: Klipsch 5.1 Reference Phono: Audio-Technica AT-LP120XUSB
Old 25th January 2021, 19:30   #7965  |  Link
benwaggoner
There was --limit-sao, which provided a pretty nice performance boost without material quality loss when SAO was limited to only I and P frames.
SAO can definitely be helpful at moderate-low bitrates. But the x265 implementation has fixed parameters for SAO. Adjusting them some based on bitrate or QP or content analysis could make it a more reliable net benefit even at high bitrates and high detail.
Ben Waggoner
My Compression Book
Old 26th January 2021, 21:43   #7966  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Update with correct version numbering
x265 3.4+13-g729a838d3+41 (Asuna)
x265 [info]: HEVC encoder version 3.4+13-g729a838d3+41
x265 [info]: build info [Windows][GCC 10.2.0][64 bit] Asuna 8bit+10bit+12bit
x265 [info]: (lsmash 2.16.1)
x265 [info]: (libavformat 58.65.101)
x265 [info]: (libavcodec  58.117.101)
x265 [info]: (libavutil   56.63.101)
Thanks! Any chance you can include 32-Bit binary as well, as you used to do?
Old 26th January 2021, 22:23   #7967  |  Link
benwaggoner
What's your use case for a 32-bit version?
Ben Waggoner
My Compression Book
Old 27th January 2021, 23:37   #7968  |  Link
LoRd_MuldeR
Software Developer
I usually include 32-Bit and 64-Bit binaries with my GUI, so we can pick the "best" one for the specific machine at runtime.
Of course, you could ask whether it still makes sense to support 32-Bit systems these days. But the code for supporting multiple architectures is already there in the GUI, so I don't see much reason to drop this feature.
...unless it becomes too cumbersome to obtain 32-Bit encoder binaries
(Another possible use case is Avisynth input: If you want to use "official" AviSynth 2.6, you'll be locked to 32-Bit. And yes, I know there is Avisynth+ as well as VapurSynth now)
Old 28th January 2021, 01:47   #7969  |  Link
benwaggoner
At higher resolutions and presets, x265 can use more than 2 GB; some of my 8K tests used >>4GB of RAM. And 64-bit is just faster overall. The only use case where I can imagine 32-bit being "best" is running a 32-bit OS. If you are still supporting 32-bit OSes, you'd need a 32-bit build.
And just piping from 32-bit AVS to a 64-bit encoding process is trivial. I've been doing that for more than a decade. The piping overhead is generally a lot smaller than the 64-bit encoding performance boost.
Not that I have any skin in the game or anything, just an aversion to 32-bit for anything performance-critical .
Ben Waggoner
My Compression Book
Old 28th January 2021, 02:30   #7970  |  Link
LoRd_MuldeR
Software Developer
That's exactly the point. The GUI program is 32-Bit, so can run on 32-Bit as well as 64-Bit platforms. At the same time, the encoder binary will be selected, at runtime, based on the actual CPU architecture.
So "best" means we select the 64-Bit binary, if we detect that we are running on 64-Bit system; otherwise 32-Bit binary will be selected.
As said before: You can argue that support for 32-Bit OS is mostly irrelevant these days. But since support for multiple CPU architectures has already been implemented in the GUI, supporting 32-Bit OS pretty much comes for free.
(provided 32-Bit encoder binaries are easily available )
Yeah, sure. But I was referring to LigH's "Asuna" x265 build, which features built-in Avisynth support. And if you want to use built-in Avisynth input, your Avisynth DLL has to match the "bitness" of the x265 binary.
(If you pipe from Avs2YUV or similar tool, then we don't need Avisynth support in x265 to begin with)
Old 28th January 2021, 02:49   #7971  |  Link
aegisofrime
@Ligh, thanks very much for your build! I gotta ask, did you notice any memory leak issues? I did an overnight encode, only to wake up and find that x265.exe has ate most of my RAM. Did a bit of googling and found that DJATOM might have fixed the memory leak, not sure the same bit of code is in your code base?
https://github.com/staxrip/staxrip/issues/445
aegisofrime is offline   Reply With Quote
Old 28th January 2021, 03:32   #7972  |  Link
DJATOM
DJATOM's Avatar
Yuuki Asuna mod merged my early VS reader works. After some testing from StaxRip users and devs it was found that vspipe's strategy of requesting new frames doesn't work well, I tried different approach to the problem and now it seems no leaks spotted. You can get my build on github and try it. If leak still occurs, describe in details how to reproduce it.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 29th January 2021, 12:04   #7973  |  Link
LigH
LigH's Avatar
I will try to build it again as soon as I get a fix for rust / cargo failing.
New German Gleitz board
Old 29th January 2021, 16:23   #7974  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by DJATOM View Post
Yuuki Asuna mod
Quoted just to hail you.
Can you please explain me the meaning of the files inside your x265 build on GitHub? The ones with the processor suffix are self explanatory, I need clarifications about:
x265-x64-v3.4+65-aMod-gcc10.2.1.exe
x265-x64-v3.4+65-aMod-gcc10.2.1-opt-znver1.exe
x265-x64-v3.4+65-aMod-gcc10.2.1-opt-znver2.exe
Moreover, can you explain me how your builds are different from the LigH one? AVS support, etc?
@turment on Telegram
Old 29th January 2021, 17:10   #7975  |  Link
DJATOM
DJATOM's Avatar
CPU-specific builds made with (for example, zen2 = -march=znver2) compiler flag which should optimize program for specific CPU microarchitecture. Non-opt build is just generic build without such flag.
As for differences, I tried to make commits descriptive. But yeaр, it contains 2 frameserver readers (Avisynth+/Vapoursynth) and y4m reader understand vspipe's XLENGTH header, which "says" how much frames x265 should expect from it.
LigH just uses another mod for his builds. I'm not saying that my build/mod is superior, it just contains certain feature set that I'm using for my needs. That's it.
Me on GitHub
Old 29th January 2021, 18:01   #7976  |  Link
tormento
Acid fr0g
tormento's Avatar
Thank you for your answer.
Old 29th January 2021, 22:10   #7977  |  Link
benwaggoner
Just curious - has anyone done any perf benchmarking of x265 on ARM processors? With the Apple M1 and workstation successors coming, and the AWS Graviton EC2 instances, it seems we're on the verge of high-performance ARM w/ SIMD compute becoming available. Obviously x265 has a HUGE amount of x64 assembly optimizations, but has some ARM as well. Anyone do any testing or have any data?
I don't imagine that peak ARM perf is anywhere near the latest Ryzen, but perhaps fps/watt is interesting?
Ben Waggoner
My Compression Book
Old 29th January 2021, 22:54   #7978  |  Link
DJATOM
DJATOM's Avatar
My friend recently bought a new mac mini with m1 chip, here some numbers on the same source
M1 with 8 gb ram (lpddr4x 4266 mhz) : 5.27 fps
3700x with 32 gb ram (3666 mhz ram oc): 7.73 fps
It was 1080p 8 bit bdmv, encoded in 10 bit mode.
Me on GitHub
Old 29th January 2021, 23:08   #7979  |  Link
Ritsuka
x265 had almost no arm64 assembly. Apple contributed a patch to HandBrake with some neon intrinsics. Unfortunately there seems no one interesting in getting it merged upstream.
Ritsuka is offline   Reply With Quote
Old 29th January 2021, 23:29   #7980  |  Link
DJATOM
DJATOM's Avatar
He used that patch: https://imgur.com/a/ArgJEEe
Me on GitHub
