27th March 2006, 09:31 | #361 | Link | |
Be Brave!
27th March 2006, 14:14 | #363 | Link |
Great - thanks for your help, people!
I'll try it ASAP. My DivX3 movies are of some historical/archaeological value to me, and in backing them up on DVD I'd like to have them at least in a correct aspect ratio (can't do anything against the sucky video-quality), so I don't have to re-correct it in MPC/VLC all the time while viewing... EDIT: It worked fine, those nifty tools that can be found here in this forum are amazing! Last edited by DFKT; 27th March 2006 at 14:46. |
10th April 2006, 13:43 | #367 | Link |
Are there any commandline-switches in "MPEG4Modifier 1.34" to set (Pixel/Display-) AR and save changed avi-file? If not, would someone be so kind to add them?
Thanks Olnima Last edited by olnima; 10th April 2006 at 14:05. |
17th April 2006, 14:18 | #368 | Link |
download-mirror is here:
http://www.hardware-test.de/doom9/ffmpeg-mstomp4.rar |
18th April 2006, 17:27 | #369 | Link | ||
I have an idea, how about the ability to actually remove n-vops without re-encoding right in the tool?
Perhaps this is possible to do because the 3ivx directshow filter can do it: http://www.3ivx.com/support/tbd_451.html read at the bottom: Quote:
hardware players to get the audio out of sync. Apparently this is true, it's not a vbr vs cbr issue or a packed bitstream issue. For every n-vop, the audio will slowly get out of sync. You can read about that here: http://www.jarnot.com/twiki/bin/view...=print.pattern Quote:
(which is one of the most popular divx/xvid players in the usa) Perhaps you can make a checkbox to remove n-vops by duplicating the previous or next frame available? Last edited by _ck_; 18th April 2006 at 18:17. |
18th April 2006, 17:58 | #371 | Link |
3ivX would be removing when remuxing to mp4/mov. mp4box can do the same. Doesn't help for avi though since it doesn't support VFR.
No problems with N-VOP's here on my MTK based standalone. Just another reason not to by an ESS based player. |
18th April 2006, 18:16 | #372 | Link | ||
I may be misunderstanding something but from what I am seeing, it IS possible to have a bitstream that is not packed yet still has nvops and causes this sound sync issue? Here is a screenshot of the situation existing: and sure enough the sound slowly goes out of sync on that video Quote:
I'm still going to hope someone can come up with a way to remove/replace nvops without re-encoding... ps. where can I find a list of non-ESS hardware players? Last edited by _ck_; 18th April 2006 at 19:13. |
18th April 2006, 18:21 | #373 | Link | |
Life's clearer in 4K UHD
http://forum.doom9.org/showthread.php?t=91616 And try using the forums "search" facility
19th April 2006, 04:22 | #374 | Link |
my player has this problem exactly
'N-VOPs - This is the rather interesting thing I discovered, that, to my knowledge, no one else has discovered. The Philips 642 seems not to recognize N-VOPs...in other words, it just skips right over them. This leads to audio synch problems. The audio can be brought back in synch by fast forwarding or rewinding a few frames, but then it will go back out of synch the next time it encounters more N-VOPs. ' Its a yamada player tho, its pretty old. No idea what chipset. |
20th April 2006, 09:06 | #375 | Link | |
20th April 2006, 09:18 | #376 | Link |
I wouldn't call it a problem. Decoders that can't handle N-VOP's are the problem. XviD only drops frames when two are 100% identical.
Here's a clip anyway. I-VOPs: 1 (1.00%) P-VOPs: 1 (1.00%) B-VOPs: 0 (0.00%) S-VOPs: 0 (0.00%) N-VOPs: 98 (98.00%) http://celticdruid.no-ip.com/test/nvop.avi Without n-vops XviD would have had to encode 99 P-VOP's even though it is just 100 identical frames. Only does it when bframes aren't enabled to, which I guess would be hard to avoid in _ck_'s case since DXN doesn't allow interlaced content and B-VOP's. edit: I guess not being about to disable N-VOP's even for 100% identical frames could be seen as a problem. ie. qpel isn't a problem since you can disable it if you want. Last edited by celtic_druid; 20th April 2006 at 09:24. |
20th April 2006, 12:50 | #377 | Link |
Well if you did want to change N-VOPs into coded P-VOPs, you'd have to:
a) change the VOP header from not coded to coded b) insert a run of binary 1s of length equal to (number of macroblocks)-1 followed by a 0 c) pad with 1s to the next byte boundary (I think) d) adjust the avi headers and index Unfortunately I don't have time to write something to do it right now. |
20th April 2006, 17:02 | #378 | Link |
Yeah that example was a mpeg2 interlaced with a quick'n'dirty re-encoding to mpeg4, (attempting to) preserve interlace. But of course the interlace has nothing to do with the nvop problem. The capture source obviously caused the problem by inserting duplicate frames to try to stay in sync (possibly when unavoidably dropping real frames, hardware lag, etc)?
Not sure if it's a good idea to post it as a clip publically but it looks like the problem is at least understood anyway? You short-circuited my brain on what little I do know about mpeg4 format with your technical solution but I look forward to one day when you do have the time to tackle it I am very grateful for any tools created to fix this issue without re-encoding, so many thanks whenever you finally get the chance... Last edited by _ck_; 20th April 2006 at 17:08. |
20th April 2006, 20:24 | #379 | Link | |
I would like to conduct some more "hardware playback" tests with MPEG-4 SP N-VOP encodes. Could you please generate a 30 second (or so) sample please? Cheers
