6th January 2006, 14:20 | #81 | Link |
@jsoto
BTW, your tool is really good. It do it's work fantastic fast Before I've met Delaycut I used BeSweet just for delaying AC3... it's much slower...
Кайда барасын, Пятачок? ...let me see you stripped... |
6th January 2006, 22:07 | #82 | Link |
Just a Member
Thanks, Sajan...but BeSweet is much much more (I know you know it).
delaycut 1.2.1.1 is out. Check my sites.. Changed: Maximum number of char changed to 8 in delay edit boxes BugFix: Spaces in output path (CLI mode) jsoto
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ |
7th January 2006, 08:08 | #83 | Link |
@jsoto
Yes, I know about BeSweet. But sometimes powerful programs can't do very simple operations..... no, they can but do it very slowly because optimized on other work. So BeSweet is optimized on processing audio and implement delay not by delaying but through processing entire audio. Such as PGCdemux creates celltimes.txt by processing entire PGC (try create celltimes without audio & video demuxing in PGCdemux and in IFOedit).
4th February 2006, 17:33 | #85 | Link |
woman @ german doom9
BugReport from 24th May 2005, 15:41
Hello jsoto. Can you correct the Duration indication with delaycut? delaycut.exe -info audio.wav Code:
[Input info] Bitrate=2304000 Actual rate=2304000.000000 Byte rate=288000 Sampling Frec=48000 Bits of Prec=24 TotalSamples=13599557 Bytespersample= 6.0000 Filesize=81597386 Duration=00:00:00.283 Channels mode=2 Channels Code:
====== INPUT FILE INFO ======================== File is wav Bitrate (kbit/s) 2304000 Act rate (kbit/s) 2304000.000 Byte rate (kbit/s) 288000 File size (bytes) 81597386 Channels mode 2 Channels Sampling Frec 48000 Bits of Prec. 24 Duration 00:00:00.283 Sample length (ms) 0.020833 Num of samples 13599557 Bytes per Sample 6 Size % Samplesize 0 ============================================= ====== TARGET FILE INFO ====================== Start Sample 0 End Sample 13599556 Num of Samples 13599557 Duration 00:04:43.324 NotFixedDelay 0.0000 =============================================
katjarella by Creyskull Visuell Design |
12th February 2006, 13:32 | #86 | Link |
Just a Member
Done (I hope) in 1.2.1.2
jsoto
27th February 2006, 12:28 | #88 | Link |
Hi jsoto,
I'm a total newbie at ripping and encoding. I am currently using dgindex to generate d2v files along with mpa files. Typically there is a whole family of mpa files with various delay times associated with a single stream. (Maybe because of those "chrink" sounds in poorly encoding dvds and vcds). This results for example in an mpa file which is about 2 seconds shorter. My question is, how can I use your tool (or is there any other?) where I can put in all dgindex mpa files and it automagically spits out a single mpa file with the correct run time (i.e. delay corrected)? If there isn't an easy way, is there a painful way? My goal is to eventually encode the (dgindex delay corrected) mpa stream into aac and then mux with mp4 video into and mkv container. Any help will be appreciated! Thanks! |
27th February 2006, 22:37 | #89 | Link | |
Just a Member
jsoto
6th April 2006, 17:31 | #90 | Link |
Of all the programs I have used to correct these errors (others being besliced and ac3fix), Delaycut seems to keep the audio in sync with the video the best. However, some of these cut points that are "fixed" or "silenced" will beep or pop on playback. If I were to send you some sample files that exhibit this behaviour, do you think it would be something you could use to correct these audible errors?
6th April 2006, 18:05 | #91 | Link | |
- Ignore: ignore the error and mantain the frame with the error - Fix: fix the CRC's expecting the error remain unnoticed. - Silence: fill the frame with silence. - Skip: delete the output frame |
6th April 2006, 21:00 | #92 | Link |
Can you also explain the ramifications of selecting each option?
Does Ignore really do nothing other than print a log message indicating that an error exists? Does Fix replace an embeded CRC code but leave bad data in the stream? Does Silence mute any audio in the truncated frame, but leave bad data? Does Skip remove the truncated frame but cause desync to associated video? What about some sort of combination of Fix and Silence where you mute the bad frame then fix the CRC code...? Would that make sense? Last edited by FreQi; 6th April 2006 at 21:59. |
7th April 2006, 02:12 | #93 | Link | |||||
All truncated frames (too short) are skipped. The next options are applied only for full frames with bad CRC's.
7th April 2006, 21:03 | #94 | Link |
Just a Member
Thanks for the perfect answer tebasuna51, everything you said is correct.
So, the preferred option (at least to me) is silenced. jsoto BTW, I found a problem sometimes (due the last code change) in the case of last frame uncompleted/errored..., seems delaycut rewinds and rewinds and never ends... A simple workaround is to cut away just the last frame.
11th October 2006, 07:10 | #95 | Link |
Hi all,
I m doing AC3 decoder project, The code wat i m using CRC check is checksum = 0xffff; for (i = 0; i < 5/8framesize ; i++) { Check_Sum = (Check_Sum ^ CRC_Data [i]); Check_Sum = (Check_Sum & 0x8000)? (Check_Sum<<1) ^ 0x8005 : (Check_Sum <<1); } by using i m not getting the result so can any body snd the algorithm or c-code for CRC error check. regards Ganesh |
11th October 2006, 09:26 | #96 | Link |
In delayac3.cpp (DelayCut sources) you have the c-code.
Search for: ac3_crc_init ac3_crc mul_poly pow_poly ... |
12th October 2006, 14:28 | #99 | Link | |
http://rapidshare.de/files/36084216/Overture.rar.html |
22nd November 2006, 13:54 | #100 | Link |
AC3 Decoder
Hi all,
I m doing AC3 Decoder code development. In that i got doubt, that how to transform LFE samples into time domain. since we are using 256 and 512 blocklength transform. Here we will get 7 LFE samples after mantissa decoding. and i am in confusion that whether we should mixup with FullBandwidth channel. please Let me know the solution...... |
