Old 2nd February 2021, 05:27   #4181  |  Link
feisty2
I'm Siri
feisty2's Avatar
plugin path: https://github.com/IFeelBloated/vsFi...Plugin.vxx#L59
script path: https://github.com/IFeelBloated/Vapo...orMagik.py#L71
feisty2 is offline   Reply With Quote
Old 2nd February 2021, 11:52   #4182  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by lansing View Post
Can I retrieve the paths for the vs plugin folder and script folder through the api?
The script "folder" isn't a single folder but simply all the normal python import paths. You can see vsrepo.py to see how it's determined by default I guess.
The "vs plugin folder" is also harder to determine. Basically you have 3 locations:
1. The core plugins
2. The global plugins
3. User plugins
The location of 2 is written to the registry and 3 is always in the same appdata location. Why do you even need to find out where things are?
Myrsloik is offline   Reply With Quote
Old 2nd February 2021, 12:09   #4183  |  Link
lansing
1. The core plugins
3. User plugins
I want to create links in vseditor to open them in one click. Right now I’m relying on vsrepogui, but when vsrepogui didn’t work, it’ll be a pain to look for them manually.
Old 2nd February 2021, 12:28   #4184  |  Link
ChaosKing
For plugins http://www.vapoursynth.com/doc/plugins.html#windows
vsrepogui just uses the paths provided by vsrepo.
But registry can be tricky if the user has installed 32bit vapoursynth or it is a "per user installation".
I need to check 4 locations in vsrepogui to cover all cases.
            var regl32 = new VsRegistry().GetRegistry(localKey32, @"SOFTWARE\VapourSynth-32");
            var regl64 = new VsRegistry().GetRegistry(localKey64, @"SOFTWARE\VapourSynth");
            var regu32 = new VsRegistry().GetRegistry(userKey32, @"SOFTWARE\VapourSynth-32");
            var regu64 = new VsRegistry().GetRegistry(userKey64, @"SOFTWARE\VapourSynth");
localKey* => RegistryHive.LocalMachine
userKey* => RegistryHive.CurrentUser
EDIT
vsrepo code for scripts
https://github.com/vapoursynth/vsrep...vsrepo.py#L186
import site
site_package_dir = site.getusersitepackages()
Which returns C:\Users\USER\AppData\Roaming\Python\Python38\site-packages
Old 2nd February 2021, 13:21   #4185  |  Link
lansing
User plugin should be all I need. I think I’ll just call vsrepo to open them.
Old 3rd February 2021, 19:57   #4186  |  Link
Jukus
How should such a video be indexed?
Format                                   : AVI
Format/Info                              : Audio Video Interleave
Commercial name                          : DV
Format profile                           : OpenDML
Overall bit rate mode                    : Constant
Overall bit rate                         : 30 Mb/s
Video
Format                                   : DV
Codec ID                                 : dvsd
Codec ID/Hint                            : Sony
Bit rate mode                            : Constant
Width                                    : 720 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 29.970 (30000/1001) FPS
Original frame rate                      : 29.970 (29970/1000) FPS
Standard                                 : NTSC
Chroma subsampling                       : 4:1:1
Bit depth                                : 8 bits
Scan type                                : Interlaced
Scan order                               : Bottom Field First
Jukus is offline   Reply With Quote
Old 3rd February 2021, 20:04   #4187  |  Link
stax76
stax76's Avatar
You can open that with ffms2 or L-Smash-Source.
Old 3rd February 2021, 21:39   #4188  |  Link
LigH
LigH's Avatar
Disadvantage: Because it is a "keyframe only" video format, the index will be huge and indexing will take a lot of time.
New German Gleitz board
Old 3rd February 2021, 21:47   #4189  |  Link
poisondeathray
If you're on windows, you can open it up with core.avisource.AVISource without indexing. Disadvantage - requires system installed DV codec and none that I know of return the original NTSC 4:1:1 .
Old 4th February 2021, 13:40   #4190  |  Link
feisty2
I'm Siri
feisty2's Avatar
does anyone actually need half precision (fp16) facilities and does any plugin actually provide support for it? I don't really wanna have it in my project and I have very good reasons:
1) there's no native support for fp16 in standard C/C++ and most CPUs provide very little or no support for it, meaning you will have to create your homegrown software-emulated fp16 type. it's not portable and it's very likely that it will be way slower than fp32 which comes with native hardware support.
2) unlike fp32 and fp64 which are universally well defined (literally every implementation out there adopts the representation defined by IEEE 754), the representation of fp16 varies on different platforms. there's the IEEE fp16, and BFloat16 (Google TPU), and who knows what else! applying arithmetic operations defined for one fp16 representation on another fp16 representation leads to garbage result. The user (or maybe even the developer) usually has absolutely no clue which fp16 representation is being used and all sorts of weird shit can happen. It might be better to avoid all this by simply not supporting fp16.
Old 4th February 2021, 13:44   #4191  |  Link
Myrsloik
Myrsloik's Avatar
1. That's not how you do it. You use the unpack/pack instructions for fp16 for load and store and then feed that to the normal fp32 path. It's the only way to make it perform well.
2. Obviously it's whatever the cpu native fp16 format is, just like with other floats. So IEEE all the way on x86 (and just about all sane cpus).
Support is mostly pointless.
Old 4th February 2021, 17:46   #4192  |  Link
Jukus
The file weighs over 30 gb
Duration over 02:30:00
The size of the ffms index is 50+ kb
Old 5th February 2021, 11:16   #4193  |  Link
lansing
What function do I use to retrieve warning message from the api? If I run a script with clip = core.get_core() in PyCharm it'll give me a nice deprecated warning, but in vseditor I couldn't find a function that can do that. the getError() only return on fatal error like frame failed to load.
Old 5th February 2021, 11:26   #4194  |  Link
feisty2
I'm Siri
feisty2's Avatar
https://github.com/vapoursynth/vapou...ynth.pyx#L2337
it has nothing to do with VS per se. you just have to find a way to utilize python's warnings module in your application.
Old 5th February 2021, 23:12   #4195  |  Link
LigH
LigH's Avatar
@Jukus: OK, maybe it's worse with uncompressed audio. My memories may be not completely correct in this case.
Old 6th February 2021, 01:36   #4196  |  Link
lansing
I don't really know what to do. Maybe like embedding Python into my vseditor project and then have it evaluate the script so I can catch the warning?
Old 6th February 2021, 08:20   #4197  |  Link
feisty2
I'm Siri
feisty2's Avatar
you can use vaporsynth's FFI facilities to execute arbitrary python code in your C++ programs. you need to:
1) define a python function that does what you want, in this case, the function should collect all warning messages from warnings and return them as a list of strings.
2) pass the function to a special filter and execute it, in this case, you can instantly execute the acquired function in your filter's constructor, then call Core.Alert() to send all warning messages to console.
Old 6th February 2021, 17:18   #4198  |  Link
lansing
What is vaporsynth's FFI facilities?
Old 6th February 2021, 17:40   #4199  |  Link
feisty2
I'm Siri
feisty2's Avatar
https://github.com/IFeelBloated/vsFi...e/Function.vxx
and use it to run python code thru a special filter
struct PythonEval {
	static constexpr auto Name = "PythonEval";
	static constexpr auto Signature = "code:func;";
	PythonEval(auto Arguments, auto Core) {
		for (auto PythonCode = static_cast<Function>(Arguments["code"]); auto&& WarningMessage : PythonCode())
			Core.Alert(static_cast<std::string>(WarningMessage));
Old 7th February 2021, 07:51   #4200  |  Link
lansing
This is what I found to catch the warnings:
import warnings
with warnings.catch_warnings(record=True) as warning_list:
    core = vs.get_core()
    clip = core.dgdecodenv.DGSource(r'hello.dgi')
    clip.set_output()
for warning in warning_list:
    print(warning.message)
But I need to wrap the whole script inside this warnings.catch_warnings in order to catch them.
speed, vaporware, vapoursynth
