18th August 2009, 16:34 | #1141 | Link |
Despite obviously being a bad example I wanted to state that your calculation was wrong.
And your new example's also bad, since you're not cutting away any frames in it, so "+10ms" is the delay you'd need for adding another track. Or am I mistaken? And what about my second question? |
18th August 2009, 17:11 | #1142 | Link | |
MKVToolNix author
If both of the audio tracks come from the same source then both need the same delay of -5ms obviously, even though that isn't obvious from the first packet's timecode. There are several cases in which simply taking the first packet's timecode as the delay will not work. There are cases where it will work. Just try it, watch the resulting file, if A/V sync is off then re-mux with adjusted delay and repeat.
Anyway, end of topic for me. Sorry. Just try muxing with different values; if the first timecode works for you then fine, if not then adjust and retry.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
19th August 2009, 20:58 | #1144 | Link |
MKVToolNix author
No. Yes, it has been requested multiple times. Yes, I will probably implement something like that. No, this will not be in the near future.
25th August 2009, 15:47 | #1145 | Link |
21 years and counting...
I've noticed that mkvmerge and mkvextract produce heavily fragmented output files (Windows).
I was wondering if this is a problem of mkvmerge's writing routine, as other muxers (tsmuxer, avimuxgui,...) do not produce such fragmented files. I've demuxed a 9GB Matroska file to an almost empty partition. OO Defrag show's that the files are spread all over the volume. |
25th August 2009, 18:46 | #1146 | Link |
MKVToolNix author
Both tools write files in small chunks, does not use any preallocation or similar and have pretty much no optimizations in this regard. This will stay that way until someone provides a good patch for me.
28th August 2009, 08:08 | #1149 | Link |
MKVToolNix author
Plans yes, but no timetable.
28th August 2009, 16:13 | #1151 | Link |
MKVToolNix author
No, sorry.
28th August 2009, 16:59 | #1153 | Link |
MKVToolNix author
I don't have any first hand experience with 64bit Windows as I don't have such an installation. But I haven't heard of it not working on 64bit Windows yet, so my guess is that yes, it does work.
30th August 2009, 15:15 | #1154 | Link |
a small request, would it be possible to add the field 'var (various)' in the language field of tracks? atm the only other option is undetermined, but this is just different from saying that this tracks features more than just 1 language.
30th August 2009, 15:59 | #1155 | Link |
MKVToolNix author
No, sorry. The Matroska specs list which values are acceptable for the 'track language' element, and those are the ISO639-2 codes and 'und'.
31st August 2009, 07:42 | #1156 | Link |
I am having trouble with the Header Editor on Vista x64 and mkvmerge 2.9.8. I open up my .mkv file created with x264 and make a couple of changes, but when I hit save the program crashes. I have even tried opening the file and saving it without making any changes but it still crashes. logfile is below, any help appreciated.
Problem signature: Problem Event Name: APPCRASH Application Name: mmg.exe Application Version: 2.9.8.0 Application Timestamp: 4a83f000 Fault Module Name: mmg.exe Fault Module Version: 2.9.8.0 Fault Module Timestamp: 4a83f000 Exception Code: c0000005 Exception Offset: 000e0ec5 OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 3081 Additional Information 1: fd00 Additional Information 2: ea6f5fe8924aaa756324d57f87834160 Additional Information 3: fd00 Additional Information 4: ea6f5fe8924aaa756324d57f87834160 Read our privacy statement: http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409 |
31st August 2009, 08:16 | #1157 | Link |
MKVToolNix author
Please try to create a small(er) file with x264 for which the header editor crashes. Then upload that file to my FTP server and I'll take a look at it. Thanks.
31st August 2009, 08:53 | #1159 | Link |
MKVToolNix author
Nice one, LeMoi. I didn't know that was in there already Looks like that one came directly from the official ISO639-2 list because I certainly don't remember adding it manually.
31st August 2009, 15:38 | #1160 | Link |
Hi mosu, is it OK to package mkvtoolnix without GUI stuff? My package is 20 MB and I want to keep it as small as possible so I've removed mmg.exe and files starting with wx as I assumed wxwidgets is only used in mmg. A user reported a crash due to missing wx files so it seems at least one of the command line applications uses a wx file.
