Old 5th December 2023, 00:31   #1  |  Link
Yosho
Need to delay DTS-HD MA track then mux to mp4
If I mux a ts with DTS-HD MA track and DV HEVC video with tsmuxer and select to delay it, then convert to mkv it stays delayed, but if I try to convert to MP4 the audio is changed back to being delayed.
What can I use to change the audio delay permanently where the delay stays for good and then can be used in MP4 conversions?
Yosho is offline   Reply With Quote
Old 6th December 2023, 00:25   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
You would have to specify again because the offset you want is not part of the source file, but became a property of the container.
If you want the correction to be with the file: reencode.
Old 6th December 2023, 13:04   #3  |  Link
tebasuna51
tebasuna51's Avatar
eac3to can insert silent frames to a DTS-MA without recode it, and the delay can be preserved. For instance:
eac3to Input.dts Output.dts +300ms
DTS Master Audio, 7.1 channels, 24 bits, 48kHz, dialnorm: 0dB
(core: DTS-ES, 5.1 channels, 1509kbps, 48kHz, dialnorm: 0dB)
Applying DTS delay...
A remaining delay of +2ms could not be fixed.
Creating file output.dts
Input.dts
Total Frames / SubF: 5614 / 5614
Duration ..........: 59882 ms (0 h. 0 m. 59.882 s.)
Output.dts
Total Frames / SubF: 5642 / 5642
Duration ..........: 60181 ms (0 h. 1 m. 0.181 s.)
eac3to add 28 silent frames of 10.666 ms, a total of 298.6 ms, for that the remaining: +2ms could not be fixed
You can do the delay +- 5 ms
Old 6th December 2023, 18:52   #4  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Out of interest... Why are you using the .mp4 container?
Old 7th December 2023, 12:59   #5  |  Link
Emulgator
Emulgator's Avatar
Top solution, will keep that in mind. Thanks, tebasuna51 !
Old 7th December 2023, 14:32   #6  |  Link
Yosho
MKV is not supported on separate hardware used to view.
Old 7th December 2023, 15:00   #7  |  Link
SeeMoreDigital
Really!
What hardware are you using?
Old 7th December 2023, 16:18   #8  |  Link
Yosho
Input.dts
Output.dts
Figured it out with your help! Thanks!
Should have been using the 100ms option and changing the - to a + and changing it to +1024ms.
Old 7th December 2023, 16:23   #9  |  Link
Yosho
Really!
LG C9 USB port.
I didn't like the Shield that everyone talks about..
You have to install apps, and change settings and things, and I just don't have time to dedicate for that to be to my liking.
Old 7th December 2023, 16:42   #10  |  Link
SeeMoreDigital
LG C9 USB port.
The [2019] LG C9 supports the .mkv container just fine. However, in order to hear lossless DTS-HD MA you'll need to access the TV's pass-through mode and send the DTS-HD MA bit-stream via HDMI to an AVR. Regular lossy DTS audio can be natively decoded by the TV's in-built/on-board audio decoder.
Just-so-you-know.... The C9 is the last LG television to support native decoding of lossy DTS.
Old 7th December 2023, 17:27   #11  |  Link
Yosho
Never had a problem with DTS-HD MA myself on the C9.
But maybe I'm just playing the AC3 inside it or something?
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Duration : 2 h 12 min
Bit rate : 16.2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.082
Stream size : 15.0 GiB (70%)
Title :
Language : English
Tagged date : 2023-12-07 15:30:45 UTC
Color range : Full
Codec configuration box : hvcC+dvcC
Audio #1
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : ec-3
Bit rate mode : Constant
Bit rate : 1 024 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 968 MiB (4%)
Title : Original
Language : English
Service kind : Complete Main
Default : Yes
Alternate group : 1
Audio #2
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : mp4a-A9
Bit rate mode : Variable
Bit rate : 2 034 kb/s
Maximum bit rate : 2 376 kb/s / 2 034 kb/s
Channel(s) : 2 channels
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 1.88 GiB (9%)
Language : English
Default : Yes
Alternate group : 2
Audio #3
Format : DTS XLL
Codec ID : mp4a-A9
Bit rate : 3 672 kb/s
Maximum bit rate : 5 194 kb/s / 3 672 kb/s
Channel layout : C L R Ls Rs LFE
Bit depth : 24 bits
Stream size : 3.39 GiB (16%)
Language : English
Default : Yes
Alternate group : 3
Old 7th December 2023, 18:12   #12  |  Link
SeeMoreDigital
The television will be able tell you which audio track it's accessing and playing...
Old 7th December 2023, 18:25   #13  |  Link
Yosho
Is it not supposed to be able to play them?
Old 7th December 2023, 18:33   #14  |  Link
SeeMoreDigital
The TV's media player app can access and play Dolby Digital Plus. It can also access and play the lossy DTS core embedded within a lossless DTS-HD MA stream.
Have you tried selecting between the three audio tracks?
Old 7th December 2023, 18:39   #15  |  Link
Yosho
Yep, they all work. So I'm playing the DTS core, since it shows as DTS, but not the full lossless stream because it would be useless with tv speakers?
Old 7th December 2023, 18:42   #16  |  Link
SeeMoreDigital
Indeed...
Out of interest... Do you have an AVR capable of decoding DTS-HD MA bit-streams?
Old 7th December 2023, 18:58   #17  |  Link
Yosho
Indeed...
I do not.
Old 7th December 2023, 19:08   #18  |  Link
SeeMoreDigital
I do not.
In that case it's pretty pointless keeping the lossless DTS-HD MA stream. You might as well extract and keep the lossy DTS core(s).
I see from your MediaInfo report that the video stream has been encoded with Dolby Vision. This being the case you will need to mux everything into the .mp4 or .m2ts/.ts container.
If the video stream had been encoded with regular HDR10, muxing everything into the .mkv container will be fine.
Old 7th December 2023, 19:46   #19  |  Link
Yosho
That would make sense.
Sometimes I wonder though about if I'm seeing things or not, and some Dolby Vision is washed out or grayer blacks on P5 MP4's as well..
Old 7th December 2023, 19:59   #20  |  Link
SeeMoreDigital
That's not something I can help you with as I play my Dolby Vision encoded files using an OPPO UDP-203 hardware media player...
