Old 12th December 2009, 11:44   #1  |  Link
gaikokujinkyofusho
trouble batch re-encoding mpeg 1 & 2 (PAL and NTSC) video into mp4 x264
Hi, I have alot of video and much of it is encoded with mpeg 1 & 2. I have been trying to find a program that supports batch encoding into x/h264 and acc but so far (using SUPER and automen frontends) almost every one of my files "breaks" (gives an error before finishing encoding). I seem to have a bit more luck with mkv containers but as mp4 is supported a bit more widely i would prefer mp4. Are there any encoders out there that are perhaps a bit less finicky? (I am assuming that perhaps there are errors in my files? this is a bit out of my league).
Any ideas or suggestions would really be appreciated.
Cheers
-Gaiko
gaikokujinkyofusho is offline   Reply With Quote
Old 12th December 2009, 14:26   #2  |  Link
Inspector.Gadget
SUPER is a piece of garbage. Use a known good workflow: DGIndex -> Avisynth -> x264.
Inspector.Gadget is offline   Reply With Quote
Old 12th December 2009, 17:27   #3  |  Link
gaikokujinkyofusho
Hmmm, i think the quality of SUPER was established when i posted that it didn't seem to suffice. I am aware of DGIndex avisynth and x264 but how to use them (like making a avisynth script?) is a bit beyond me. Is there perhaps a front end that can make DGIndex, Avisynth and x264 a bit more noob friendly?
Thank you,
-Gaiko
Old 12th December 2009, 18:02   #4  |  Link
Chengbin
HDConvertToX is pretty good for this.
Chengbin is offline   Reply With Quote
Old 12th December 2009, 20:43   #5  |  Link
Inspector.Gadget
MeGUI. I still recommend using DGIndex manually, though, because it's a useful chance to preview the content and check for the presence/percentage of pulldown flags in the source. So long as you're not cutting (which is easy), you need to use all of two buttons to get a D2V file and audio.
Old 12th December 2009, 21:12   #6  |  Link
roozhou
If you are doing batch encoding, try MediaCoder.
I personally don't recommend DGIndex for batch encoding because it requires additional passes and disk spaces to finish your job.
roozhou is offline   Reply With Quote
automen, frontend, mp4, mpeg, super
