Old 11th June 2021, 17:03   #61581  |  Link
James_b
Any plans for a Madvr stream port? Web browser wieving is the most used now days and it's not that good in all cases.
James_b is offline   Reply With Quote
Old 11th June 2021, 17:50   #61582  |  Link
Klaus1189
What exactly is not that good in all cases? What do you want to improve?
Old 11th June 2021, 17:52   #61583  |  Link
el Filou
el Filou's Avatar
There is no way to do that as you need support from the player/app for madVR to work right.
There would be too many problems if madVR silently replaced the browser's video renderer (not sure that would even be possible).
madshi would probably now tell you to buy an Envy to benefit from madVR with all apps/sources.
HTPC: Windows 10 20H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 466.27
Old 11th June 2021, 22:52   #61584  |  Link
amayra
Quality Checker
amayra's Avatar
both madvr and lav are not built with stream support in mind
go with mpv+youtube-dl for that
mpv have good advance option for stream like cache and quality control
I love Doom9
amayra is offline   Reply With Quote
Old 12th June 2021, 03:07   #61585  |  Link
or you do the same with madVR using youtube-dl because youtube-dl is doing the work here.
Old 12th June 2021, 08:55   #61586  |  Link
Asmodian
I use Zoom Player to watch YouTube rendered by madVR, it works great (it also uses youtube-dl).
madVR options explained
Old 12th June 2021, 12:16   #61587  |  Link
tp4tissue
tp4tissue's Avatar
Videos lower than 25Mbit/s Average isn't worth watching.
No thanks.
Ghetto | 2500k 5Ghz
Old 12th June 2021, 15:11   #61588  |  Link
ashlar42
So you watch based on tech and not content? Good luck with that.
Old 13th June 2021, 08:11   #61589  |  Link
lello
Originally Posted by lello View Post
In addition to the htpc, I installed JRiver + madvr on the notebook for the various experiments.
When madvr crashes on the notebook, it saves me a text file on the desktop with the crash data while on the htpc this doesn't happen: is there any setting to tell where to save the craash file?
With ctrl + c I copied the crash you see in the txt file attachment: someone can tell me why madvr often crashes me?
Thank you
Attachments Pending Approval
File Type: txt Madvr crash.txt
lello is offline   Reply With Quote
Old 16th June 2021, 13:22   #61590  |  Link
maxkill
anyone had a green tint on new releases? i'm experiencing a very strange color malfunction on newer releases, the old ones work fine. i've tried updating geforce but no luck. this is with all players so it's not only madvr that fails to play them correctly
Optimal 4k settings for smoother image MadVR guide
http://forum.doom9.net/showthread.php?t=176161
maxkill is offline   Reply With Quote
Old 17th June 2021, 00:17   #61591  |  Link
Reclunk
You're probably trying to play a Dolby Vision file. I'll be interested for a workaround for this if possible.
Reclunk is offline   Reply With Quote
Old 17th June 2021, 10:57   #61592  |  Link
ashlar42
Originally Posted by chros View Post
In short, get a used 1060 6GB with a TV and you are done. Take a look at the link in my signature to see what settings it can handle with different content.
Ended up getting a RTX 3070 as a gift, of all things!
I will still look at your settings, as I guess there will be totally conservative, considering that they are supposed to run on a 1060 and, apparently, the 3070 is the best Nvidia card to date, as far as performance/energy used is concerned.
Old 18th June 2021, 14:58   #61593  |  Link
Nnn
Hello everyone,
I bought recently an ASUS TUF GTX 1650 Super VGA and now I'm experimenting with madVR settings. I have read the relevant guides and seen "general good settings", but I would like to use madVR with the best and safest settings according to my VGA with MPC-HC.
I would like to watch 1080p and sometimes 2160p content on my monitor, which is a DELL S2721DS (1440p, 75Hz, IPS).
And when I play a video with the default settings, I always get some presentation glitches. Is this normal?
What is your opinion?
Thank you!
Nnn is offline   Reply With Quote
Old 18th June 2021, 15:41   #61594  |  Link
clsid
Enable VSync in NVIDIA settings.
In madVR set "frames to present in advance" to 1.
MPC-HC 1.9.14
Old 18th June 2021, 16:11   #61595  |  Link
SirMaster
For watching YouTube with madVR I have been using this which works great with MPC-HC or other DirectShow players.
https://ys.3dyd.com/
Also there has been some work on using madVR with HDMI input cards.
https://github.com/defl/videoprocessor
Thread here (ignore the first couple pages)
https://www.avsforum.com/threads/how...#post-60820362
SirMaster is offline   Reply With Quote
Old 18th June 2021, 16:31   #61596  |  Link
el Filou
el Filou's Avatar
Is that still recommended with newer drivers? See: https://nvidia.custhelp.com/app/answ...driver-version
Maybe just do the change in the application-specific settings page and not as a global setting.
Note that this specific usage is expressly forbidden by the newer license distributed with madVR:
(i) directly or indirectly use the Software in any way with external or
internal video capture devices or cards of any kind, and/or to receive or process incoming video from or in conjunction with any
professional or consumer electronic devices, and/or with any devices with one or more HDMI outputs..
so I would recommend everyone to preciously keep your old archives of madVR releases (0.92.17 and the test builds before 114) before that new license was included, as you can only legally use that setup with such an older distribution archive (if you download them now, the new license is included).
(I doubt madVR labs would legally sue individuals, but still...)
Old 18th June 2021, 17:03   #61597  |  Link
nevcairiel
Incidentally both of you agree, because clsid suggest to enable it, and the article suggest that disabling it is bad.
Old 18th June 2021, 17:21   #61598  |  Link
el Filou
el Filou's Avatar
What I meant was that NVIDIA recommends leaving it at default (app-controlled).
My advice of making sure to force it to On only in the player app-specific page and not global settings is so it doesn't impact something else in Windows.
Old 19th June 2021, 12:16   #61599  |  Link
maxkill
Yes this is correct, no player so far seems to be able to play them without showing incorrect colors
Old 20th June 2021, 19:03   #61600  |  Link
ashlar42
I'm getting an access violation at address $4a500782 in module madVR64.ax. Read of address $0 when trying to use SmoothMotion.
madVR 0.92.17 beta 113 (I think, I don't see any indication of the beta number... it was one of the last non expiring ones).
It does it always with both MPC-HC and Kodi DS Player.
