Old 7th March 2016, 15:29   #3981  |  Link
Shiandow
Originally Posted by aufkrawall View Post
When there is downscaling after SuperRes needed, it uses the scaler selected in MPDN main application:
Is there a way to use a render script shader for this? Maybe add a SSIM checkbox in SuperRes settings?
You can change the prescaler to "SuperXbr + SSIM" to achieve that.
Btw: I'm still not fully happy with the deband filter. Could someone please port MPV's deband filter to HLSL? It's already ported to ReShade, if this is any help:
https://github.com/crosire/reshade-s...wski/Deband.fx
In what way is MPV's debanding filter better than MPDN's?
Old 7th March 2016, 16:29   #3982  |  Link
aufkrawall
I can't find it:
It's not in the list of all available scalers either.
It's working very well for me in games, while MPDN's deband filter often misses quite some banding in videos compared to madVR. So I thought it might not hurt to have the option to try it.
Btw: Now that super-xbr has far less problems with ringing, it might make sense to add it also as a chroma scaler?
Old 7th March 2016, 16:35   #3983  |  Link
lanzorg
Online streaming, pipe input, RAR archives, DVD playback
Does anyone know how to launch MPDN from Firefox or Chrome with streaming websites like YouTube?
lanzorg is offline   Reply With Quote
Old 7th March 2016, 16:57   #3984  |  Link
Shiandow
I can't find it:
No, you'd have to add it; if you press "modify list" you can add whatever prescaler you want, which can be as complicated as you like. Since there are increasingly more options it's not really doable to add every single possible method, but I'm always open to better options to put in the default list.
Well, the method is quite simple so I can give it a try. I might try to improve a bit on the method. FWIW I currently see the biggest banding problems when the source is pretty much 'broken', MadVR might be a bit more aggressive in those cases, but in exchange MPDN's method can be used at pretty much full strength without completely obliterating the image.
I'd have to see if that's possible, but for now I'd rather focus on the new reconstructive Bilateral method, which seems rather promising (still need some kind of 'limiter' to prevent artefacts, but other than that the quality is impressive).
Old 7th March 2016, 21:36   #3985  |  Link
aufkrawall
I can add SSIM downscaler there, but then SuperRes isn't used at all according to OSD and it's still downscaled with MPDN internal downscaler.
I think this would definitely make sense, since even "HQ" sources often suffer severe banding.
When you set the threshold of your deband filter to a very high value, this kind of banding isn't reduced as much as with madVR deband filter, but the image gets a softer look in general too.
Looking forward to it.
With cartoons, there are currently often errors which are still easy to spot.
Old 7th March 2016, 23:08   #3986  |  Link
foozoor
foozoor's Avatar
I use my laptop/ultrabook very often and sometimes I watch some videos.
Could you share a preset for the Intel HD 530 integrated GPU?
foozoor is offline   Reply With Quote
Old 7th March 2016, 23:18   #3987  |  Link
Shiandow
The OSD system might be having some trouble (making it more failproof has been on my todo list for a while) or something is wrong. As far as I can tell the this script should do what you want.
That goes both ways by the way, if you know where to look 'non-reconstructive' methods cause errors that are quite easy to spot as well . One of the easiest to spot is chroma bleeding, but sometimes it's simply loss of detail.
Old 8th March 2016, 00:33   #3988  |  Link
aufkrawall
Oops, mea culpa. I totally didn't consider that a script chain can be added as a prescaler option.
Works well and OSD reports it correctly.
Agreed. However, imho such kind of errors is less obtrusive than e.g. bright colored dots between areas of different color, like in cartoons.
Old 8th March 2016, 01:20   #3989  |  Link
Shiandow
Those kinds of artefacts should have stopped mostly with the new version (1.26.2), if not then something is wrong. The remaining artefacts are mostly colour not following edges correctly (usually when there's a dark edge next to a red area).
Old 8th March 2016, 01:46   #3990  |  Link
aufkrawall
Yep, that describes it well.
Old 8th March 2016, 07:43   #3991  |  Link
so the debanding algo is changed now?
in the past it was powerful but it could easily remove a huge deal of details unlike madVR f3kd based deband filter.
Old 8th March 2016, 07:51   #3992  |  Link
Zachs
Suptitle, MediaPlayer.NET
You might've remembered it the wrong way around.
Zachs is offline   Reply With Quote
Old 8th March 2016, 07:56   #3993  |  Link
i did the test my self and posted it here so now. it was at the time the deband filter was still in part of madVR that some time ago! i can search for the post or at least the disc if you like.
Old 8th March 2016, 08:01   #3994  |  Link
Zachs
I can't remember the earliest implementation of the filter but it's been like this for a long time i.e. preserves more details but not as strong.
Old 8th March 2016, 08:07   #3995  |  Link
found the post.
http://forum.doom9.org/showpost.php?...ostcount=30693
it extremely terrible in motion.
i can cut a sample later but this will take time i don't even know which season this was.
Old 8th March 2016, 13:09   #3996  |  Link
Shiandow
found the post.
That does seem to be an earlier implementation of the algorithm.
Might want to give it another try with the new version on default settings. Although that image looks like it could be 'broken' in the sense that you have to choose between representing the source accurately, or removing the banding.
Old 8th March 2016, 14:41   #3997  |  Link
got this crash after first time starting with a complete reset of all setting.
TITLE: SharpDX Error
An unexpected error 'SharpDX.SharpDXException' has occurred.
ADDITIONAL INFORMATION:
HRESULT: [0x887A0005], Module: [SharpDX.DXGI], ApiCode: [DXGI_ERROR_DEVICE_REMOVED/DeviceRemoved], Message: The GPU device instance has been suspended. Use GetDeviceRemovedReason to determine the appropriate action.
 (SharpDX)
BUTTONS:
&Abort
it was most likely running out of vram still this is no reason to crash i guess.
Old 8th March 2016, 15:08   #3998  |  Link
yes it is clearly changed.
and it doesn't harm the truck anymore.
this is with 1.0
http://abload.de/img/truckxoad8.png
Old 8th March 2016, 15:27   #3999  |  Link
aufkrawall
MPDN's deband with a very high strength looks a bit like a deblocking filter. I notice this when e.g. watching a news video, the face of the newsspeaker becomes a bit too blurry.
Old 8th March 2016, 15:54   #4000  |  Link
Shiandow
FYI I think the 'power' setting doesn't really do anything at the moment. Should probably fix that at some point.
direct3d, mpdn, nnedi3, opencl, reclock
