Old 30th January 2016, 18:22   #3901  |  Link
The Dark Lord
Low MKV Video frame rate
I'm having problem with playing some MKVs mostly those downloaded from Youtube.
MPDN is rendering the video at average of 15 frames, which of course translates to massive stuttering.
as you can see there are no dropped or delayed frames.
MPC-HC and other players like VLC have no problem rendering these files at 23 frames.
My specs:
win 10 64bit
i7- 4770K
Geforce 970 (Driver 361.43)
Latest MPDN 32-bit
The Dark Lord is offline   Reply With Quote
Old 30th January 2016, 20:26   #3902  |  Link
Anima123
Originally Posted by Shiandow View Post
The new downscaler should be available in the next release of the MPDN extensions.
Right on this weekend?
Anima123 is offline   Reply With Quote
Old 31st January 2016, 01:20   #3903  |  Link
Shiandow
With any luck, yes. At any rate it'll be soon.
The code's already on Github, you could also copy that to the Extensions folder and use it that way. At least, I think that should work.
Old 31st January 2016, 02:53   #3904  |  Link
Zachs
Suptitle, MediaPlayer.NET
I'm away on holiday at the moment though. Buy I have my laptop with be so hopefully I'll find some time to do a release later today.
Zachs is offline   Reply With Quote
Old 31st January 2016, 03:06   #3905  |  Link
louiebh
did the livestreamer issue i had work for you?
louiebh is offline   Reply With Quote
Old 31st January 2016, 03:44   #3906  |  Link
Zachs
Haven't had time to try it yet. But have your tried YouTube-dl? Does that work?
Old 31st January 2016, 21:50   #3907  |  Link
louiebh
i saw it mentioned earlier in the thread when i good livestreamer and mpdn but I had literally no idea how to install it or get it working and it seemed from what i could see, be a way to download videos then watch them later rather than stream them directly through the browser?
but no im somwhat savvy but this was beyond me could you point me the github/mainpage didnt make any sense on how to install/work.
Old 31st January 2016, 22:10   #3908  |  Link
this is how it works: http://forum.doom9.org/showthread.ph...be#post1739563
livestreamer a easier way to start livestreams but check youtube-dl first.
Old 31st January 2016, 23:26   #3909  |  Link
ryrynz
ryrynz's Avatar
I was kinda expecting something amazing from the new SSIM downscaler but there wasn't that much difference when compared to lanczos 12AR IMO. It looks nice and all and I'd probably use it but it's no night and day difference.
Old 1st February 2016, 01:30   #3910  |  Link
Shiandow
Thanks for the feedback, shame it wasn't as good as you thought it was going to be. Is there anything in particular that you think could be better?
FWIW something like 12 taps Lanczos is already pretty sharp to begin with, so in most case you shouldn't really need much additional sharpness (except if you downscale a lot). That said, in theory SSIM should be somewhat more intelligent, it adds exactly* the right amount of sharpness instead of just a lot of sharpness all the time. It could be sharper when downscaling very fine details, or for higher scaling factors. The SSIM downscaler will also be a bit smoother on less detailed regions, but that might not be particularly useful (although it does suppress source artefacts)*.
*Your mileage may vary.
Old 1st February 2016, 02:12   #3911  |  Link
Anima123
SSIM has it's own character for sure, you need to check several times to find the optimized settings working together with e.g., image doublers.
That is why I am more curious than ever, what it can produce with SuperRes or whatever you might call.
Edit: Right now I am using the following render chain, which seems to benefit from SSIM quite a lot, at least from 576p -> 1080p:
<ListOfPresetOfIFilterIRenderScript xmlns:yaxlib="http://www.sinairv.com/yaxlib/">
  <PresetOfIFilterIRenderScript Name="SuperChromaRes" Guid="17c2c194-4a30-4355-bbcb-1dec7093d383">
    <Script yaxlib:realtype="Mpdn.Extensions.RenderScripts.Shiandow.SuperRes.SuperChromaResUi">
      <Settings>
        <Passes>2</Passes>
        <Strength>1</Strength>
        <Softness>0.25</Softness>
        <Prescaler>True</Prescaler>
      </Settings>
    </Script>
  </PresetOfIFilterIRenderScript>
  <PresetOfIFilterIRenderScript Name="SuperRes" Guid="1a020bec-87ad-4f83-b0dd-545e0ffdc9b6">
    <Script yaxlib:realtype="Mpdn.Extensions.RenderScripts.Shiandow.SuperRes.SuperResUi">
      <Settings>
        <PrescalerGroup>
          <SelectedIndex>0</SelectedIndex>
          <Hotkey />
          <Options>
            <PresetOfIFilterIRenderScript Name="Super-xBR" Guid="418b3ba0-af29-4724-9267-16461ed01a39">
              <Script yaxlib:realtype="Mpdn.Extensions.RenderScripts.Hylian.SuperXbr.SuperXbrUi">
                <Settings>
                  <EdgeStrength>1</EdgeStrength>
                  <Sharpness>1</Sharpness>
                  <FastMethod>False</FastMethod>
                  <ThirdPass>True</ThirdPass>
                </Settings>
              </Script>
            <PresetOfIFilterIRenderScript Name="NEDI" Guid="91aa2996-b2fe-42d1-be0d-1a3479851567">
              <Script yaxlib:realtype="Mpdn.Extensions.RenderScripts.Shiandow.Nedi.NediScaler">
                <Settings>
                  <AlwaysDoubleImage>False</AlwaysDoubleImage>
                  <ForceCentered>False</ForceCentered>
                </Settings>
              </Script>
            <PresetOfIFilterIRenderScript Name="NNEDI3" Guid="316bb7d2-3886-4db3-b0b7-512615fdd76c">
              <Script yaxlib:realtype="Mpdn.Extensions.RenderScripts.Shiandow.NNedi3.NNedi3Scaler">
                <Settings>
                  <Neurons1>Neurons16</Neurons1>
                  <Neurons2>Neurons16</Neurons2>
                  <CodePath>ScalarMad</CodePath>
                  <Structured>False</Structured>
                  <ChromaScalers />
                  <ChromaScalerGuid>00000000-0000-0000-0000-000000000000</ChromaScalerGuid>
                </Settings>
              </Script>
            <PresetOfIFilterIRenderScript Name="OpenCL NNEDI3" Guid="c92fad62-253a-4bfd-830f-a230111af648">
              <Script yaxlib:realtype="Mpdn.Extensions.RenderScripts.Mpdn.OclNNedi3.OclNNedi3Scaler">
                <Settings>
                  <ChromaScalers />
                </Settings>
              </Script>
          </Options>
        </PrescalerGroup>
        <Passes>2</Passes>
        <Softness>0.05</Softness>
        <HQdownscaling>True</HQdownscaling>
      </Settings>
    </Script>
  <PresetOfIFilterIRenderScript Name="Resizer" Guid="06a38b00-8f92-4b6a-961e-12061ca127f0">
    <Script yaxlib:realtype="Mpdn.Extensions.RenderScripts.Mpdn.Resizer.ResizerScript">
      <Settings>
        <ResizerOption>TargetSize150Percent</ResizerOption>
      </Settings>
    </Script>
  <PresetOfIFilterIRenderScript Name="SSIM downscaler" Guid="d447143f-8eaa-41fb-bacd-5cd022bb132a">
    <Script yaxlib:realtype="Mpdn.Extensions.RenderScripts.Shiandow.SSimDownscaling.SSimDownscalerUi">
      <Settings />
    </Script>
</ListOfPresetOfIFilterIRenderScript>
Old 1st February 2016, 13:26   #3912  |  Link
ryrynz
ryrynz's Avatar
It just the content I was using. SSIM's strength is in the details, patterns and white areas. If you don't have this sort of content playing someone might instead prefer to run something else for a sharper picture. The content I was playing was computer generated so what I saw looked similar overall in sharpness to lanczos.
Exactly right. Some might prefer other downscalers with less detailed content. I don't feel it's probably the one downscaler to rule them all but I have no doubt it'll be popular with general content, it's magic is in the finer details.
SSIM
Lanczos 16AR
The broccoli, the quilt patterns and the shreds inside the crayfish are nice areas of improvement over Lanczos 16AR.
Old 1st February 2016, 13:35   #3913  |  Link
madshi
It's always helpful to include the original size image.
Old 1st February 2016, 19:11   #3914  |  Link
Thunderbolt8
It would also preferable to use an imagehost for the two pics instead of having to go through a download process.
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack)
Old 1st February 2016, 23:13   #3915  |  Link
ryrynz
ryrynz's Avatar
I tried for over an hr last night.. Every image provider either resized them wouldn't accept them or changed the brightness.. Any recommendations?
I'll link the source later. I don't have a 4k screen.
http://4ksamples.com/
Screenshot was taken from the Chimei inn sample.
Old 2nd February 2016, 11:52   #3916  |  Link
Thunderbolt8
did you try imagebam or someimage?
Old 2nd February 2016, 12:29   #3917  |  Link
ryrynz
ryrynz's Avatar
For some reason I just cannot explain the Lanzcos image gets brighter when uploaded to various image uploading sites.
If someone could tell me why this happens I'd really appreciate it.
Imagebam link
Mega
Old 2nd February 2016, 12:40   #3918  |  Link
eX``
I wanted to have a look / test SSIM but I got trouble using it for a simple reason: it's not showing in MPDN. When I go to Program Files / MPDN, the folder is in RenderScripts. Though it's not present in App data.
Thank you very much.
eX`` is offline   Reply With Quote
Old 2nd February 2016, 13:24   #3919  |  Link
Shiandow
So you copied the "SSIMdownscaler" folder? Did you also copy the "SSimDownscaler.cs" file? That one should be in the RenderScripts folder as well.
Old 2nd February 2016, 13:26   #3920  |  Link
Zachs
I've released the binary version yesterday. If you updated the extensions you should automatically have SSIM.
direct3d, mpdn, nnedi3, opencl, reclock
