Old 21st December 2022, 03:43   #1  |  Link
Katie Boundary
Katie Boundary's Avatar
Alternative blu-ray ripper needed
DVDfab doesn't seem to handle seamless branching correctly. On the Avatar Extended Collector's Edition blu-ray, it can only see the 2 hour and 42 minute theatrical cut, not the 2:50 Special Extended Edition or the 2:58 Even Specialer And More Extended-er Edition
MakeMKV can see all three cuts of the movie, but can't do chapter selection, which is a real pain in the ass when there's a micrometer-sized scratch in the disc that prevents the end credits from being ripped but the rest of the movie is fine.
What's behind door number three?
I ask unusual questions but always give proper thanks to those who give correct and useful answers.
Katie Boundary is offline   Reply With Quote
Old 21st December 2022, 11:46   #2  |  Link
gonca
You can try, with AnyDVDHD in the background, DGDemux with skip last m2ts checked.
Afterwards remux to the desired container. This should avoid the damaged section
gonca is offline   Reply With Quote
Old 22nd December 2022, 03:09   #3  |  Link
Katie Boundary
Does that assume that the credits are (1) a separate m2ts file, and (2) a whole m2ts file?
Old 22nd December 2022, 11:45   #4  |  Link
gonca
It assumes that the damage is in the last m2ts, which usually contain the credits.
One is free, and the other one has a trial so there is no cost to try, except for some time
Old 22nd December 2022, 12:54   #5  |  Link
hubblec4
Matroska find' ich toll
What is your goal?
What is the final container?
If you want to combine all this 3 editions in one mkv, only chapterEditor can handle such discs correctly. And there is also an option to omit the last m2ts file.
chapterEditor || Matroska-Playback || hSplit || DiscShare
hubblec4 is offline   Reply With Quote
Old 22nd December 2022, 13:01   #6  |  Link
hubblec4
.... there's a micrometer-sized scratch in the disc .....
I have seen many of such disc and there is a 100% solution.(for me)
Take toothpaste and a handkerchief.
After one minute massage clean the disc with water and I'm sure the disc will work again.
Old 22nd December 2022, 18:47   #7  |  Link
Toothpaste (and a little water or spit) can work,
DONT follow tracks around the disk, rub center to outer, against track direction, or,
go round in little circles like "bulling" army boots (my preference).
Worst scratches follow same direction as tracks.
Hold cleaned disk under tap and wash off toothpaste and shake dry.
EDIT: I've recently had some success simply cleaning disk with spray-on Covid Hand-Sanitizer (glycerine / alchohol based), and then wash under tap and shake dry. [not wipe dry]
Maybe try this one before toothpaste.
Old 23rd December 2022, 18:13   #8  |  Link
Katie Boundary
Originally Posted by hubblec4 View Post
What is your goal?
To find a Blu-Ray ripper that can handle both seamless branching and chapter selection.
No preference.
LOLWUT? No, I only want the 3-hour version.
toothpaste
Toothpaste
Again, focusing on the use case and not the more general problem... Let's assume that this will not be the only time in my life when I'll need a Blu-Ray ripper that can handle both seamless branching and chapter selection, and that not every future use case can be solved with toothpaste.
Old 25th December 2022, 12:02   #9  |  Link
hubblec4
You will never find such a ripper :-)
AnyDVD and chapterEditor in combination is your friend :-) if you don't want to copy the Blu-ray content to the HDD first.
No preference.
OK. But you should use mkv as container.
What is LOLWUT?? What means that?
Old 25th December 2022, 16:22   #10  |  Link
gonca
https://www.google.com/search?client...x-b-d&q=lolwut
Old 31st December 2022, 11:46   #11  |  Link
wade7575
@Katie Boudary You may want try Magic Blu Ray Ripper I have never used it but I have used their other program called Magic DVD Ripper and it has always worked for me.
https://magic-blu-ray-ripper.software.informer.com/2.3/
wade7575 is offline   Reply With Quote
Old 1st January 2023, 08:36   #12  |  Link
Katie Boundary
What I WANT to do and what I CAN do are very different things.
No chapter-selection.
Old 10th June 2023, 09:15   #13  |  Link
binaryflow
Any reliable bluray/dvd ripping Open Source alternatives?
binaryflow is offline   Reply With Quote
