Old 25th April 2022, 11:59   #1  |  Link
castellanos
Member
castellanos's Avatar
MeGUI: VP9/ivf coversion.
Hello everyone.
I've been searching the forum but haven't found anything that points me in the right direction.
I am trying to convert a YouTube content (mkv) to which I had to correct the audio. I used gMKVExtract to demux the tracks, the audio was an .aac but the video was VP9/ivf, a format I've never come across before (Yes, I've been away from video conversion for a while ). My idea is to convert this content using MeGUI, but apparently it doesn't support this type of format, neither when embedded in the mkv or separated as an ivf file. It says that a filter is missing, but which one?
Some ideas how can I get this to work?
castellanos is offline   Reply With Quote
Old 26th April 2022, 11:23   #2  |  Link
tebasuna51
tebasuna51's Avatar
Here MeGUI support VP9 video in mkv container with FFMSIndex 20210814 or L-SMASH Works 20220406 (not in ivf format).
Check your ffms2 and L-Smash versions.
Old 4th May 2022, 01:44   #3  |  Link
castellanos
Member
Thanks for the reply.
Everything is up-to-date:
Old 5th May 2022, 03:00   #4  |  Link
tebasuna51
tebasuna51's Avatar
I don't think so. You have ffms2 and L-SMASH Works from 2017.
Please:
Megui -> Options -> Extended -> Auto Update -> Use development update server -> Save
Megui -> Tools -> Update -> Show all packages -> Enable all packages -> Update
To obtain the versions showed in my post.
Old 8th May 2022, 17:06   #5  |  Link
castellanos
Member
I see. Thanks for the info.
I'll try ASAP.
Old 10th May 2022, 12:45   #6  |  Link
castellanos
Member
Thanks a lot for your help. I've already tried your suggestion and worked very well, I still have to try to convert the file I've mentioned above which I don't have anymore and for some reason it's not available in YouTube anymore, but I guess it should work now.
Thanks a lot.
Old 10th May 2022, 15:20   #7  |  Link
tebasuna51
tebasuna51's Avatar
You are welcome.
Old 15th May 2022, 18:44   #8  |  Link
castellanos
Member
Hi, sorry to bother you again. Now I got another problem.
Since the last update I did using "Development update server" I can't load ass subtitle files anymore. I get an AviSynth script error: "Plugin was designed for a later version of AviSynth (8)"
So I think the problem lies in the VSFilter.dll included in the 13 version of the AviSynth plugins. For some reason, it can't load ass file. I had to go back to the 11 version.
Old 17th May 2022, 07:35   #9  |  Link
tebasuna51
tebasuna51's Avatar
Please upload a full log with the problem or try:
Megui -> Options -> Main -> Check the Always use the included Avisynth
Seems you have installed a old AviSynth version
Old 18th May 2022, 01:28   #10  |  Link
castellanos
Member
Thanks for your answer!
It was always like that.
After loading the ass file and pressing "Preview AVS Script" I get the first error (Test1) and then if I press directly "Save" I get the second error (Test2).
Full Log:
[Error] Log
-[Information] Versions
--[Information] MeGUI: 2928 x64
--[Information] MeGUI Debug Data: available
--[Information] Update Check: Disabled
--[Information] System Information
---[Information] Operating System: Windows 10 Pro 2009 x64 (10.0.22000.675)
---[Information] .NET Framework: 4.0 (4.0.0.0)
---[Information] .NET Framework: 4.8 (4.8.04161)
---[Information] Redistributables
----[Information] Microsoft Visual C++ 2010 x64:  10.0.40219
----[Information] Microsoft Visual C++ 2010 x86:  10.0.40219
----[Information] Microsoft Visual C++ 2012 x64:  11.0.61030
----[Information] Microsoft Visual C++ 2012 x86:  11.0.61030
----[Information] Microsoft Visual C++ 2013 x64:  12.0.40664
----[Information] Microsoft Visual C++ 2013 x86:  12.0.40664
----[Information] Microsoft Visual C++ 2015-2019 x64:  14.29.30135
----[Information] Microsoft Visual C++ 2015-2019 x86:  14.23.27820
---[Information] DPI: 100% (96/96)
---[Information] Monitor 1
----[Information] Resolution: 1680x1050
----[Information] Primary Screen: True
--[Information] Component Information
---[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013)
---[Information] Haali DSS2:  (14-04-2013)
---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
---[Information] MediaInfo: 18.05.0.0 (08-05-2018)
---[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
---[Information] 7z: 9.20 (18-11-2010)
--[Information] AviSynth Information
---[Information] AviSynth Wrapper
----[Information] Version: 1.0.2847.0
----[Information] Date: 06-05-2018
----[Information] Interface: 3
----[Information] AviSynth Status: ignored as portable build is forced
---[Information] AviSynth portable
----[Information] File Version: 3.5
----[Information] File Date: 02-04-2020
----[Information] File Name: AviSynth+ 3.5 (r3106, 3.5, x86_64)
----[Information] File Path: c:\program files\megui\avisynth.dll
----[Information] AviSynth Version: AviSynth+ 3.5 (r3106, 3.5, x86_64)
----[Information] AviSynth+: true
----[Information] AviSynth MT: true
----[Information] AviSynth Status: active
-[Information] Update detection
--[Information] [5/17/2022 9:19:48 PM] Automatic update is disabled
--[Information] [5/17/2022 9:19:48 PM] Using cached update config and server: http://megui.tmebi.de/test/
--[Information] [5/17/2022 9:19:48 PM] No package requires an update
-[Information] FileIndexer
--[Information] [5/17/2022 9:20:02 PM] MediaInfo
---[Information] File: D:\Video\TEST\Test.mkv
---[Information] General
----[Information] Format: Matroska
----[Information] FileSize: 395978594
----[Information] PlayTime: 00:54:33.045
---[Information] Video
----[Information] ID: 1
----[Information] StreamOrder: 0
----[Information] CodecID: V_MPEG4/ISO/AVC
----[Information] Format: AVC
----[Information] FormatInfo: Advanced Video Codec
----[Information] Width: 720
----[Information] Height: 360
----[Information] FrameCount: 78552
----[Information] FrameRate: 24.000
----[Information] FrameRateMode: CFR
----[Information] FrameRateModeString: Constant
----[Information] Duration: 00:54:33.000
----[Information] ScanType: Progressive
----[Information] Bits Depth: 8
----[Information] AspectRatio: 2.000
----[Information] AspectRatioString: 2.000
----[Information] PixelAspectRatio: 1.000
----[Information] Delay: 0
----[Information] LanguageString: English
----[Information] Default: Yes
----[Information] Forced: No
---[Information] Audio
----[Information] ID: 2
----[Information] StreamOrder: 1
----[Information] CodecID: A_AAC-2
----[Information] Format: AAC
----[Information] FormatInfo: Advanced Audio Codec
----[Information] FormatProfile: LC
----[Information] SamplingRate: 48000
----[Information] SamplingRateString: 48.0 kHz
----[Information] Channels: 2
----[Information] ChannelsString: 2 channels
----[Information] ChannelPositionsString2: 2/0/0
----[Information] Language: en
---[Information] Text
----[Information] ID: 3
----[Information] StreamOrder: 2
----[Information] CodecID: S_TEXT/UTF8
----[Information] CodecIDInfo: UTF-8 Plain Text
----[Information] Format: UTF-8
----[Information] ID: 4
----[Information] StreamOrder: 3
----[Information] Language: es
----[Information] LanguageString: Spanish
-[Information] Log for job1 (idx, Test.mkv -> Test.mkv.lwi)
--[Information] [5/17/2022 9:20:04 PM] Started handling job
--[Information] [5/17/2022 9:20:04 PM] Preprocessing
--[Information] [5/17/2022 9:20:04 PM] AviSynth script
---[NoImage] LoadPlugin("C:\Program Files\MeGUI\tools\lsmash\LSMASHSource.dll")
---[NoImage] LWLibavVideoSource("D:\Video\TEST\Test.mkv")
--[Information] [5/17/2022 9:20:05 PM] MediaInfo
---[Information] File: D:\Video\TEST\Test.mkv.lwi
---[Information] Indexed File: D:\Video\TEST\Test.mkv
--[Information] [5/17/2022 9:20:05 PM] Postprocessing
---[Information] [5/17/2022 9:20:06 PM] Deleting intermediate files
--[Information] [5/17/2022 9:20:06 PM] Job completed
-[Error] MediaInfo
--[Error] [5/17/2022 9:22:24 PM] Error parsing media file D:\Video\TEST\Test.mkv.avs
---[NoImage] Plugin was designed for a later version of Avisynth (8)
---[NoImage] (D:\Video\TEST\Test.mkv.avs, line 9)
-[Error] MediaInfo
--[Error] [5/17/2022 9:22:26 PM] Error parsing media file D:\Video\TEST\Test.mkv.avs
Old 18th May 2022, 13:41   #11  |  Link
tebasuna51
tebasuna51's Avatar
Yes, I checked the VSfilter from https://github.com/pinterf/xy-VSFilter/releases and can't work with MeGUI AviSynth version until the xy-VSFilter v3.2.0.802 (20181031).
In plugins 11 version there are v3.2.0.801 (20180904) but if work for you is ok.
Old 18th May 2022, 15:14   #12  |  Link
castellanos
Member
So, if I understood correctly, from VSFilter v3.2.0.802 to the latest do not work with MeGUI AviSynth version, right?
Old 18th May 2022, 23:21   #13  |  Link
tebasuna51
tebasuna51's Avatar
Yes, I test from last v3.2.0.806 (20210412), v3.2.0.805 (20210412), v3.2.0.804 (20210306) and v3.2.0.803 (20210305) without success, the same messages than you.
Maybe need new AviSynth versions still not tested with MeGUI by Zathor than need other changes.
Old 19th May 2022, 01:39   #14  |  Link
castellanos
Member
All right. I will pay attention to the new updates.
Muchas gracias.
