Old 28th September 2019, 19:12   #1  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
Chrominance subsampling for MPEG-2 interlaced encodings
Interlaced MPEG-2 allows the chrominance samples to be aligned temporally to the lines or, less common, to the first field of the frame.
Is there an easy way to determine which method was used during encoding?
Cary Knoop is offline   Reply With Quote
Old 29th September 2019, 02:14   #2  |  Link
manolito
manolito's Avatar
Are you referring to field based encoding of interlaced sources? The only encoder which supports this AFAIK is Procoder / Carbon Coder. This option complies with the MPEG2 specs, but not with the DVD specs, so I never used it.
From the ECLPro readme for DVD Rebuilder:
Alsaysframe = 0:Use field base encoding for interlaced sources (better) - 1(default):Always use frame mode (more compatible) - Please use frame mode in DVD-RB else you get errors in rebuilding.
So I do not have an answer to your question how you can determine which mode was used during encoding.
Old 9th November 2019, 21:14   #3  |  Link
kolak
Maybe by converting it (eg. upscaling) and forcing to use different chroma sampling position. Wrong ones may introduce chroma ghosting. Not sure. Maybe this info is also somewhere in mpeg2 headers.
Old 12th November 2019, 01:45   #4  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
temporally aligned ? I thought spatially aligned, and both fields coded as one frame,
so chroma will be temporally smeared.
Horizontal axis: MPEG-2: aligned on even columns, (col 0,2,4 = even),
(MPEG-1: would be aligned in-between neigbored columns 0,1 and 2,3 etc.
Vertical axis: MPEG-1 and MPEG-2: aligned midways in-between two lines.
http://www.cs.columbia.edu/~delbert/...ranscoding.pdf
https://poynton.ca/PDFs/Chroma_subsampling_notation.pdf
https://pdfs.semanticscholar.org/9ae...874539ff3d.pdf
http://dvd.sourceforge.net/dvdinfo/mpeghdrs.html
Extension header.
Sequence_Extension Byte5 Bit1, Bit2
chroma_format
GoTo H.262 Spec:
https://www.google.com/url?sa=t&rct=...A8uq_RQBzRwyCs
page 54/220 Table 6-5 chroma_format
00 = Reserved
01 = 4:2:0
10 = 4:2:2
11 = 4:4:4
Ha, found something more:
Picture_Coding_Extension Byte7 Bit0
chroma_420_type
page 63/220
"chroma_420_type – If chroma_format is "4:2:0", the value of chroma_420_type shall be the same as progressive_frame; else chroma_420_type has no meaning and shall be equal to zero."
