Old 3rd May 2015, 11:58   #1  |  Link
hank315
HCenc author
HCenc 0.28
A new release: HCenc 028
- needs Avisynth 2.6 RC1 or higher
- support for mod8 resolutions
This new release expects Avisynth versions with AVISYNTH_INTERFACE_VERSION = 6.
Tested successful with:
- regular Avisynth 2.6 RC1 - RC3
- Avisynth MT by SEt (Current version 2015.02.20)
- Avisynth+ (tested r1779, r1718 or higher should work)
Download here.
HCenc at: http://hank315.nl
hank315 is offline   Reply With Quote
Old 3rd May 2015, 14:13   #2  |  Link
filler56789
SuperVirus
filler56789's Avatar
Confirmed!
Checked
filler56789 is offline   Reply With Quote
Old 3rd May 2015, 15:30   #3  |  Link
videoh
Useful n00b
Hank, can you please explain how you determine if Avisynth is installed? I have a setup where I run batch files to select the version of Avisynth I want. I don't have registry entries but rather I just have the avisynth.dll directory in my PATH. I currently have AVS+ 1825 MT installed and can open a script with version() with no problem in VirtualDub. But when I run HCenc 0.28 it tells me that Avisynth is not installed. Your assistance would be greatly appreciated.
Old 3rd May 2015, 18:52   #4  |  Link
hank315
HCenc author
The registry is checked:
  iret = RegOpenKeyEx (HKEY_LOCAL_MACHINE,&    ! Key handle at root level
                       regpathC,&              ! Path name (SOFTWARE\Avisynth)
                       0,&                     ! Reserved
                       KEY_READ,&              ! Requesting read access
                       LOC(hKey))              ! Address of key to be returned
  AVS_installed = (iret == ERROR_SUCCESS)
If AVS_installed = false a warning is generated but if there's an Avisynth.dll which can be loaded it will use that one.
Old 3rd May 2015, 19:20   #5  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Now this is an update. Thanks for your continual work.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Old 3rd May 2015, 21:23   #6  |  Link
videoh
Useful n00b
Excellent, thank you very much. And thank you for the update!
Old 3rd May 2015, 22:01   #7  |  Link
videoh
Useful n00b
Apparently, your code does not work on a 64-bit OS. When I test your registry call with KEY_READ | KEY_WOW64_64KEY then it works. Registry handling is a bit different for 64-bit Windows.
I suggest and request, therefore, that you eliminate the registry check entirely and just load the DLL that you find.
Old 4th May 2015, 00:38   #8  |  Link
hank315
HCenc author
Strange, here it works OK (Win7 64 bit).
Maybe not such a bad idea, if LoadLibrary succeeds simply proceed.
Will have a look into it tomorrow, thanks for the report.
Old 4th May 2015, 01:32   #9  |  Link
videoh
Useful n00b
Hmm, yes, confusing. I'll look into that a bit more also.
Old 8th May 2015, 00:01   #10  |  Link
qyot27
qyot27's Avatar
I'm getting crashes and hangs with AviSynth+ r1825 with 0.28. The crash or hang occurs during the sampling pass - if there's a crash, it's at the switch from Phase 1 to Phase 2 (and then even crashes DrWatson), and if there's a hang, it occurs at the very end of the sampling pass, before switching to actual encoding. 0.26 is unaffected and can use r1825 without issues.
I've seen this happen on an old Celeron II (Pentium III Coppermine base) machine running WinXP, and on a mid-2011 iMac running OSX 10.10 with AviSynth+ and HCenc under Wine 1.7. The XP test was single-threaded, and the iMac/Wine case was with Prefetch(4).
EDIT: It appears that a standard 2-pass encode is fine, though, as tested on the aforementioned Celeron. So it seems to only affect the sampling pass in a *1PASS encode.
Old 8th May 2015, 11:31   #11  |  Link
Groucho2004
I can reproduce this. However, it crashes with every version of Avisynth.
-> Crash dump
Groucho's Avisynth Stuff
Old 8th May 2015, 22:46   #12  |  Link
hank315
HCenc author
I can also reproduce it and yes it will crash with every version of Avisynth.
This update should fix it
And as requested by videoh Avisynth.dll is just loaded, which one can be checked with the Avisynth info button.
Old 8th May 2015, 22:57   #13  |  Link
videoh
Useful n00b
Awesome, Hank, thank you!
I confirm things work great for me now. The Avisynth Info feature is great, as it shows the path and version. Sweet.
Old 8th May 2015, 23:10   #14  |  Link
Groucho2004
Thanks Hank, working fine here, too.
Old 9th May 2015, 05:08   #15  |  Link
qyot27
qyot27's Avatar
Yep, it's working now. Thanks.
Old 9th May 2015, 06:15   #16  |  Link
manolito
manolito's Avatar
Just gave version 0.28 a short test run, it does work on my old machine. I normally use an older AviSynth version, but thanks to Groucho I can easily switch to the latest 2.6 RC3.
Question is: Why should I?
Going over the change log all I can see is support for HD output and support of more color spaces. I use HCenc ONLY for DVD creation, so these improvements do not matter for me.
Are there any other improvements in the encoding engine which would result in better quality for DVD compliant output compared to version 0.26 ?
Cheers
manolito
Old 9th May 2015, 09:20   #17  |  Link
Groucho2004
There are quite a number if bug fixes from 2.5.8 -> 2.6.0, as mentioned here. I seem to recall that you use 2.5.7 so that list may be even longer. 2.6.0 is also faster and uses less memory than previous versions.
Old 9th May 2015, 10:38   #18  |  Link
manolito
manolito's Avatar
Sorry, I was not clear enough...
My main question was why I should consider using HCenc 0.28 instead of version 0.26. Since all I use it for is DVD output, will version 0.28 have any advantages? (I also don't see why anyone today would use the MPEG2 format for HD output since even H.264 is almost obsolete these days).
For AviSynth the only reason I still have to use 2.57 is that I cannot live without good old DVD2SVCD. And every AviSynth version after 2.57 gives me a totally white screen in the preview window. I tried a lot of things to debug this behavior, but it is the avisynth.dll, nothing else.
Cheers
manolito
Old 30th June 2015, 02:48   #19  |  Link
SuLyMaN
Bumpzor :P Interested in this too!
SuLyMaN is offline   Reply With Quote
Old 3rd July 2015, 19:46   #20  |  Link
Precomposed
Where can I find the license agreement?
Jon Geddes
Precomposed is offline   Reply With Quote
