16th May 2015, 11:44 | #81 | Link |
For me high-end is NOT only CPU is a desktop PC with fast RAM (e.g. DDR3-1600 MHz dual channel) fast chipset (Z77, Z97) and good motherboard, etc...
Others users has reported +90 fps in these conditions: Also first post screenshot (83 fps) is from a i7-3770k only ("high-end" of couse) |
12th November 2015, 11:54 | #85 | Link | |
You can try new SDK included in BDtoAVCHD v2.5.0 but probably you need also to update the drivers (again). |
18th November 2015, 18:33 | #87 | Link |
Banned
Tried and got an Error
He failed while doin something with eac3, but i want to keep original audio Code:
LAST CMD LINE => "C:\Program Files (x86)\BDtoAVCHD\eac3to\eac3to.exe" "J:" 1) 2: "C:\Users\KeVe\AppData\Local\Temp\BDtoAVCHD\MINIONS UPT4 2D+3D.job_0.avc.h264" 3: "C:\Users\KeVe\AppData\Local\Temp\BDtoAVCHD\MINIONS UPT4 2D+3D.job_0.mvc.h264" 7: "C:\Users\KeVe\AppData\Local\Temp\BDtoAVCHD\MINIONS UPT4 2D+3D.job_0" -progressnumbers -log="C:\Users\KeVe\AppData\Local\Temp\BDtoAVCHD\MINIONS UPT4 2D+3D.job_0.eac3to_log.txt" EXIT CODE => 1 (0x00000001) Code:
Intel Media SDK System Analyzer (32 bit) The following versions of Media SDK API are supported by platform/driver: Version Target Supported Dec Enc 1.0 HW Yes X X 1.0 SW Yes X X 1.1 HW Yes X X 1.1 SW Yes X X 1.3 HW Yes X X 1.3 SW Yes X X 1.4 HW Yes X X 1.4 SW Yes X X 1.5 HW Yes X X 1.5 SW Yes X X 1.6 HW Yes X X 1.6 SW Yes X X 1.7 HW Yes X X 1.7 SW Yes X X 1.8 HW Yes X X 1.8 SW Yes X X Graphics Devices: Name Version State Intel(R) HD Graphics 4600 10.18.14.4280 Active System info: CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz OS: Microsoft Windows 7 Enterprise Arch: 64-Bit Analysis complete... [press ENTER] Last edited by KeVe1983; 18th November 2015 at 18:36. |
18th November 2015, 20:29 | #89 | Link |
Banned
Not needed, maybe i found the issue
I just wanted to keep the untouched german audio The 3D disc has: Code:
German Dolby Atmos 7.1 Code:
Dolby Digital Plus Audio German 576 kbps If i use recode to 640 kbs ac3 it seems to work. Also it's possible to keep english TrueHD Audio, or normal standard 640 kbs ac3 audio files without error Edit: Is this normal? There's nothing happen anymore since 5 minutes? Also just have the BDtoAVCH symbol in the task bar with green color flow from left to right Last edited by KeVe1983; 18th November 2015 at 20:46. |
18th November 2015, 21:16 | #90 | Link |
No is not normal (it seems hanged).
To discard things I suggest you try first with the default settings:
If this does not help try to update Intel Graphics drivers to latest.
KODI 19 Matrix HDR Windows API BDtoAVCHD - One Click Blu-Ray to BD5/BD9/BD25/MKV MVCsource – MVC 3D Avisynth Source Plugin MVCenc – MVC 3D Encoder Last edited by pistacho; 18th November 2015 at 21:35. |
26th November 2015, 23:05 | #91 | Link | |
22nd October 2016, 20:21 | #95 | Link |
New version with significant improvements
Version 2.6.4 (10/26/2016)
KODI 19 Matrix HDR Windows API BDtoAVCHD - One Click Blu-Ray to BD5/BD9/BD25/MKV MVCsource – MVC 3D Avisynth Source Plugin MVCenc – MVC 3D Encoder Last edited by pistacho; 26th October 2016 at 20:48. |
19th November 2016, 23:51 | #96 | Link |
New version works well on my new Notebook :
Windows 10 i7-6700HQ HD 530 Target Usage = 3 (slow) gives 100 fps. Target Usage = 1 (Placebo) gives 45 fps. Both reencoding give a .m2ts file well displayed on my Samsung TV (no pixellisation), but which is the best quality, I don't really see a difference between TU 3 and TU 1 ! The only issue I noticed (that did not occur under Windows 8.1) is when 3D .iso file is mounted from an external disk, BDToAVCH crashes at the beginning of step 2 (MVC 3D encoding) |
1st July 2019, 19:12 | #99 | Link |
It's getting more and more difficult to find new PC notebooks with Intel graphic chipsets. The more often, there is only one graphic card, either Intel Graphic Card incorporated to I3/5/7 processor or Graphic NVIDIA. But I can't see new PC notebooks with both graphic cards anymore ! Only Apple seems to sell new notebooks with both. Does Intel UHD Graphics 620 works with MVC 3D encoder ? |
3d blu-ray encoder, mvc encoder, mvcenc |
