Old 6th January 2017, 09:16   #41901  |  Link
CruNcher
CruNcher's Avatar
or you are not using madVR...:
https://abload.de/img/madvrldp0v.png
this is without debanding. i don't even want to know how you get so much banding in picture.
8 bit output chain because that's what we talked about debanding 8 bit and how efficient MadVR does it
10 Bit p010 is real 10 bit and most probably never needs debanding with those inputs and then it's entirely up to your display panel efficiency what you'll see
10 bit->8 bit->MadVR (Debanding)->Panel
you now did
10 bit->MadVR (no debanding/no dithering)->Panel
Lets sumarize it
10 bit->MadVR (Pure)
10 bit->8 bit->MadVR (Pure)
10 bit->8 bit->MadVR Debanding High
10 bit->8 bit->Ordered Dithering->MadVR (Pure)
10 bit->8 bit->Random Dithering->MadVR (Pure)
Wow here you really see the Power of Ordered/Random Dithering that is Psy wise almost a 100% hit of the input quality without MadVR touching anything.
Now it shouldn't surprise anyone anymore why there is no (No Dithering) Option in Lav Video
It is about Time
Old 6th January 2017, 13:40   #41902  |  Link
ryrynz
ryrynz's Avatar
Jesus, would you look at that detail loss on the transparent skirt in 8 bit... Crazy.
Looks like there's some debanding required even in 10 bit
Old 6th January 2017, 15:36   #41903  |  Link
Clemens
Wrong color Astra1 UHD
I described my problem here: https://forum.doom9.org/showthread.p...14#post1792014
Here the ctrl-j output: http://puu.sh/td7rh/19227caded.jpg
Here a sample: https://www.dropbox.com/s/cbbp9073q8...20UHD_.ts?dl=0
Kind regards,
Clemens
Clemens is offline   Reply With Quote
Old 6th January 2017, 15:48   #41904  |  Link
CruNcher
CruNcher's Avatar
That combination seems to cry after problems 8bit p10 DXVA2
Try Fullscreen Exclusive to get into 10 bit
It is about Time
Old 6th January 2017, 15:55   #41905  |  Link
Clemens
The same problems on a channel with p1010 10 bit 4:2:0 (dxva2)
http://puu.sh/td8tH/3ca44b49e7.jpg
(If sample needed please ask)
I will try your suggestion
EDIT
How do I do this? (sorry I'm a noob )
Which shortcut I have to press or which setting I have to change for this?
Old 6th January 2017, 16:07   #41906  |  Link
CruNcher
CruNcher's Avatar
These 2 options at least
Then go into Fullscreen
It is about Time
Old 6th January 2017, 16:13   #41907  |  Link
YxP
Originally Posted by Asmodian View Post
That is due to the fade detection kicking in. If you keep debanding at the same strength fade detection doesn't run at all for a small increase in performance, and it never rerenders 5 frames which causes that spike and can cause dropped frames.
This is completely from my memory and don't really want to go into any testing, but try disabling use a separate device for presentation. I did sometime ago and haven't had problems since. I did other changes as well so that's why I'm mostly guessing here.
YxP is offline   Reply With Quote
Old 6th January 2017, 16:20   #41908  |  Link
Clemens
I have done some more tests:
- CPU decoding -> colors are fine (off course no fluent image)
- DXVA2 + custom EVR Renderer -> works fine
- DXVA2 + MadVR -> doesn't work
--> seems to be very similar to the magenta bug in the bug tracker:
http://bugs.madshi.net/view.php?id=456
I guess DXVA2 is doing something wrong...
Have you the same problems with other GPUs? (mine is a GTX 960)
The Exclusive mode doesn't change anything...
Problem is there for all 4k HEVC 10 bit channels (also the HLG teststream channel)
Old 6th January 2017, 17:37   #41909  |  Link
CruNcher
CruNcher's Avatar
Indeed strange VP7 should do it are you sure the Mixer input output types are 10 bit with EVR Custom rendering and DXVA ?
And are you in 10 bit Display Driver Mode also for MadVR and still in Exclusive Fullscreen you get those color shifting ?
It is about Time
Old 6th January 2017, 17:47   #41910  |  Link
Clemens
I have no idea what the EVR renderer does How can I check this?
And I'm using a 8bit UHD display.
If you mean with your question "the native display bitdepth is:" then I can say I tried 10 bit and 8 bit there no difference.
Can you play the sample file without any problems (some posts above)? Would like to know if only I have the problem.
And what do you mean with the VP7 thing? (as said I am a noob )
Btw. thanks for looking at it (it's not that important to me I just thougt to report it to make madvr better if the bug is in madvr)
Old 6th January 2017, 17:47   #41911  |  Link
Damien147
Same results with an RX 470 here,dxva2(native) gives black screen.
Damien147 is offline   Reply With Quote
Old 6th January 2017, 17:52   #41912  |  Link
Damien147
Originally Posted by baii View Post
Have a Rx460, don't seem to have much problem with ngu 1080p to 4k.
Really?With rx470 the best I can do is ngu med.Is there something wrong with my system?
Old 6th January 2017, 17:55   #41913  |  Link
Asmodian
That isn't how madVR works, what are you doing to get it to 8-bit before madVR?
10 bit->16 bit madVR (debanding)->8-bit->Panel
ngu low is consistent with "NGU 1080p to 4k"?
madVR options explained
Old 6th January 2017, 18:00   #41914  |  Link
CruNcher
CruNcher's Avatar
10 bit P010->YV12 8 bit (no dithering)->MadVR Debanding High
Is the heavy banding result above
with 10 bit P010->YV12 8 bit (Ordered/Random Dithering) has the biggest visual Deband effect, you virtualy dont need MadVR Debanding High and it's overhead anymore.
It is about Time
Old 6th January 2017, 18:10   #41915  |  Link
Clemens
Other test done with my problem: DXVA2(copy back) works also fine and with correct colors...DXVA2(native) gives the purple screen...
So:
DXVA2 (native) -> EVR custom -> OK
DXVA2 (native) -> MadVR -> NOT OK, purple colors
no Hardware Decoding -> OK with both (but stuttering bacause of software decoding)
DXVA2 (copy back) -> both OK
Old 6th January 2017, 18:14   #41916  |  Link
CruNcher
CruNcher's Avatar
Same with the Samsung 10 bit Streams ?
http://demo-uhd3d.com/fiche.php?cat=uhd&id=91
http://demo-uhd3d.com/fiche.php?cat=uhd&id=97
Hmm so DXVA Native wont work, but why ?
Native Display Bitdepth (Driver) should be 10 bit The Controll Panel should be set to 10 bit
Though if it only would work with copyback that wouldn't be really that bad the overhead is not that much bigger normally, though for people with laptops that want maximum power saving could be a problem.
VP7 stands for Video Processor (Version 7) the VPU (Video Processing Unit) inside of your GM206 GTX 960 also called marketing wise Nvidia PureVideo.
It is about Time
Old 6th January 2017, 18:33   #41917  |  Link
Damien147
The performance gap between these two seemed bigger.Well...ok.
Old 6th January 2017, 18:34   #41918  |  Link
Clemens
yes same thing with the demo...with copy back it works, with native wrong colors...
Old 6th January 2017, 18:44   #41919  |  Link
sorry you should read up the basic how picture processing is working in a PC.
i will never post you a 10 bit screen because it is technically not doable.
setting the output to 10 bit doesn't mean you get 10 bit too. the windows desktop is working in 8 bit.
madVR is not debanding when outputting 8 bit.
@Clemens
DXVA native is a lowering picture quality with nvidia and it should be avoided using madVR.
your GPU is not by any chance a 2 GB GTX 960?
Old 6th January 2017, 18:49   #41920  |  Link
sneaker_ger
What exactly are you trying to say?
Madvr is debanding when - unsurprisingly - debanding is ticked in the settings. This is also true for 8 bit output.
