Old 18th January 2023, 20:15   #1901  |  Link
Dogway
WARN: From here on and for the next 9 pages mostly @TDS basic AVS usage questions (deleted posts make it down to 6 pages). Skip to page 102.
You need to provide your SMDegrain call.
EDIT: Just updated adding some additional checks, still if your source is progressive and is flagged as interlaced you need to explicitly declare interlaced=false
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 18th January 2023, 20:37   #1902  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
Here's the entire script:
# Set DAR in encoder to 162 : 95. The following line is for automatic signalling
global MeGUI_darx = 162
global MeGUI_dary = 95
SetMemoryMax(40960)
SetCacheMode(0)
LoadPlugin("C:\Video Editing\MeGUI (x64)\tools\lsmash\LSMASHSource.dll")
LWLibavVideoSource("G:\WORK\Test.mkv")
AssumeFPS(25)
CTelecine()
CPostProcessing()
crop(28, 4, -28, -4)
ConvertBits(16)
SMDegrain(mode="MDegrain", tr=12, thSAD=240, contrasharp=true, LFR=true, DCTFlicker=true, refinemotion=true, truemotion=true, blksize=16, search=5, pel=4, subpixel=4, chroma=false, plane=0, gpuid=0)
SMDegrain(mode="MDegrain", tr=12, thSAD=120, thSADc=120, contrasharp=false, LFR=false, DCTFlicker=false, refinemotion=true, truemotion=true, blksize=24, search=5, pel=4, subpixel=4, chroma=true, plane=4, gpuid=0)
F3KDB_3(range=20, Y=36, Cb=24, Cr=24, grainY=24, grainC=12, dither_algo=2)
Prefetch(48,48)
Return(Last)
The 2nd call of SMDegrain causes the error, like the one with the fields before. If I just run the first call it works with subpixel=4.
With subpixel=3 both instances run fine.
LeXXuz is offline   Reply With Quote
Old 18th January 2023, 20:53   #1903  |  Link
Dogway
Yes, so what I said above, if your source is progressive and tagged as interlaced, either change the tag with propSet("_FieldBased",0), or use interlaced=false.
Just updated SMDegrain for a typo.
Old 18th January 2023, 20:55   #1904  |  Link
LeXXuz
LeXXuz's Avatar
But I don't understand why the 2nd call causes the error and the 1st one doesn't. They are literally the same, no?
Old 18th January 2023, 21:08   #1905  |  Link
madey83
Posts: n/a
@Dogway,
in your SMDegrain script you mentioned lot of modes, but in dokumention i can't find them and what are differents between them and use cases:
string "mode"="MDegrain" ("MDegrain"/ "MedianT"/ "MedianST"/.........
Could it be possible to give a light on them?
Old 18th January 2023, 21:42   #1906  |  Link
Dogway
@LeXXuz: The first call isn't correct either, you are treating a progressive clip as interlaced, therefore denoising might not behave as you expected. If it doesn't raise an error it doesn't mean it's correct.
@madey83: Yes, docs are work in progress. Check mode descriptions here.
Old 18th January 2023, 22:05   #1907  |  Link
LeXXuz
LeXXuz's Avatar
Sorry but I can't follow you. I clearly must've missed something in the docs. I thought quarter-pel and Nnedi (may) increase accuracy or are these for interlaced sources especially and not suitable for progressive video
I just wanted to use NNEDICL to distribute a little more work to the GPU.
EDIT: It works now with propset but don't think I will use NNEDICL in this constellation. It eats up GPU memory like crazy. Thx kedautinh12 and Dogway.
Old 19th January 2023, 16:20   #1908  |  Link
SetMemoryMax(40960)
Is that intentional ? (40GB)
Old 19th January 2023, 17:46   #1909  |  Link
LeXXuz
LeXXuz's Avatar
Yes. I edited out custom prefiltering which eats a lot of memory.
Old 26th January 2023, 12:37   #1910  |  Link
LeXXuz
LeXXuz's Avatar
FIY: Wolfram Rhodium pushed a new update of BM3DCUDA for Avisynth+
https://github.com/WolframRhodium/Va...discussions/20
Old 27th January 2023, 04:18   #1911  |  Link
anton_foy
Dogway can you explain what the denoising part in this post is doing and how please?
anton_foy is offline   Reply With Quote
Old 27th January 2023, 12:56   #1912  |  Link
Dogway
I don't remember well. He said it was a bit noisy so whatever denoiser it suited. Then I run ex_median() with the "shift back by one" trick, not sure why maybe to reduce ringing a bit further I think.
Old 27th January 2023, 13:01   #1913  |  Link
TDS
Formally known as .......
TDS's Avatar
A question about using deep_resize..
I have been able to use this on a couple of encodes, but on other's, it just refuses to start encoding
I checked the dependencies,
https://github.com/Dogway/Avisynth-S...sPack.avsi#L75
And I have all but "vsTCanny" & "fmtconv".
I'm just using
deep_resize(3840,grain=0)
will adding these, fix it ??
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 27th January 2023, 13:20   #1914  |  Link
kedautinh12
What errors?? Can't fix without errors
Old 27th January 2023, 13:31   #1915  |  Link
kedautinh12
Do you add propSet("_FieldBased",0) before deep_resize??
Old 27th January 2023, 13:42   #1916  |  Link
Dogway
This works for me:
setmemorymax(2048*4)
ffvideoSource("720p_src.mkv")
ConvertBits(16)
Prefetch(8)
You don't need "_FieldBased" frameprop for my scripts.
Old 28th January 2023, 04:18   #1917  |  Link
kedautinh12
Originally Posted by TDS View Post
Thanks for the info, but I'm still have a strange problem.
I am wanting to upscale a 1920 to 3840, but in this case, if I use the 3840 it won't start, but if I change it down to 1920, it's OK, and 1280 downscaling doesn't work either.
It worked on a couple of other video's. They must be different, some how
Strange (to me)
Are you try me suggestion??
Old 28th January 2023, 04:54   #1918  |  Link
kedautinh12
If your source interlaced you need add propSet("_FieldBased",0)
Old 28th January 2023, 05:32   #1919  |  Link
kedautinh12
Just add propSet("_FieldBased",0) above deep_resize
Deep_Resize(...)
Old 28th January 2023, 06:40   #1920  |  Link
kedautinh12
Yes, that position
avisynth, dogway, filters, hbd, packs
