Old 31st March 2024, 00:56   #2881  |  Link
Dogway
Updated SMDegrain to v4.6.0. Fixed ex_DGDenoise arguments, I don't quite like the search windows can't go now lower than 9, but at least I had implemented the LFR argument.
I also updated the manual with current versions of filters, etc.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 31st March 2024, 11:15   #2882  |  Link
tormento
Acid fr0g
tormento's Avatar
AFAIK is because of speed optimizations. It seems that 9 is now a lot faster.
@turment on Telegram
Old 1st April 2024, 12:57   #2883  |  Link
DVB-Freak
FrameRateConverterMIX
@Dogway
Can you look at post #2866? It's a simple script.
I updatet all to the newest versions. I add "ConvertBits(16)".
Nothing helps.
DVB-Freak is offline   Reply With Quote
Old 1st April 2024, 14:17   #2884  |  Link
DTL
Originally Posted by LeXXuz View Post
That may prove useful for some material I have with lots of troublesome dark areas.
New noise-resistant processing mode added to MAnalyse to make motion estimation in low contrast and high noised areas more stable - https://forum.doom9.org/showthread.p...95#post1999795 .
It is not complex in programming so expected to be added to 'stable' -e.XX builds to use in scripts like SMDegrain faster.
Currently this additional layer of MVs searching and averaging works at all levels (down to finest pel-level) so performance impact is great (though still about 2x faster in compare with number of new search runs added). In next releases I going to add option to limit 'area' mode additional search to only high levels down to pel=1 and it is expected to be several times faster while keeping most of accumulated quality at full-pel level.
Old 1st April 2024, 23:30   #2885  |  Link
Dogway
I updated FilmGrain+, I think the bugs in HBD are fixed now.
Originally Posted by DVB-Freak View Post
@Dogway
Nothing helps.
Post your script and error message.
Old 2nd April 2024, 11:02   #2886  |  Link
DVB-Freak
https://www.directupload.net/file/d/...jqm4bp_jpg.htm
My script:
FFVideoSource("C:\edit\Film.mkv")
FrameRateConverterMIX(Preset="RIFE", FrameDouble=true)
plugins:
ExTools v10.4 (19-02-2024)
Frame Rate Converter MIX v2.3.3 (10-10-2022)
Avisynth+ v3.7.3
Old 2nd April 2024, 11:11   #2887  |  Link
DVB-Freak
Sorry, here is the link to the error-message:
Old 4th April 2024, 03:09   #2888  |  Link
Dogway
It's working for me, ensure you are in latest RIFE, GradePack and TransformsPack.
What is your source like, 422 or something out of the norm?
Old 4th April 2024, 10:39   #2889  |  Link
rgr
My script:
plugins:
Avisynth+ v3.7.3
Why don't you use RIFE directly?
convertbits(32).converttoplanarrgb(matrix="Rec709") # or other matrix
RIFE(model=5) # or 6
converttoyuv420(matrix="Rec709").convertbits(8,dither=0)
rgr is offline   Reply With Quote
Old 4th April 2024, 11:43   #2890  |  Link
DVB-Freak
@Dogway
My source is BT.709 or YUV, it does no matter.
I've cleaned my pluginsfolder and put in the newest plugins.
The error remains.
@rgr
It was only a test. Actually is this my script:
ex_InterpolateDoubles(Preset="RIFE")
I hoped, that is the best quality. But it is the same error.
I give up now.
Thank you all
Old 4th April 2024, 12:04   #2891  |  Link
tormento
Acid fr0g
tormento's Avatar
@Dogway
Do you plan to give the possibility to use SVPTools in your scripts?
Old 4th April 2024, 12:13   #2892  |  Link
rgr
@rgr
I give up now.
Thank you all
I don't know how this is supposed to give you better quality since it's the same as RIFE.
Old 4th April 2024, 12:42   #2893  |  Link
FTLOY
Friend of a friend..
FTLOY's Avatar
@Dogway
The error remains.
@rgr
I give up now.
Thank you all
You need to provide the complete script !!
Are you using all the necessary dependancies ??
FTLOY is offline   Reply With Quote
Old 5th April 2024, 23:28   #2894  |  Link
DTL
Some note about thSAD for MRecalculate: As I see it is currently hardcoded as halfthSADR. But it really complex adjustment for performance and performance/quality balance. It may be good to enable at least several control modes of thSAD for MRecalculate in scripting functions without direct control of thSAD for MRecalculate as script function param:
1. Force all new recalculated blocks refining search: set thSAD=0. Slowest mode but depending on source may make best quality (at least it can not make new MVs with more than searchparam offset from input MVs).
2. Sort of 'balanced/auto' - as today in SMDegrain. Average speed (also depends on noise level and thSAD settings).
3. Interpolate MVs only: set thSAD to 'very high' value like 1000 or more. May be average quality but fastest.
Today if user want to increase thSAD as input param to increase denoising in MDegrain - it also cause halfthSAD for MRecalculate to become larger and it passes more blocks with only interpolated MVs from input without real refining search. This may cause decreasing of MVs quality after MRecalculate and cause even more detail loss.
Old 9th April 2024, 14:39   #2895  |  Link
tormento
Acid fr0g
tormento's Avatar
Is there any function in your scripts to convert chroma sampling position to other types, i.e. center to left etc?
Old 9th April 2024, 15:57   #2896  |  Link
Dogway
Yes, ConvertFormat(). I'm on mobile so I can't post examples but on the explanation of the function I think you can see examples.
Old 9th April 2024, 19:02   #2897  |  Link
tormento
Acid fr0g
tormento's Avatar
It has so many switches that some examples would be helpful.
Can it be used when downsizing to half the original size, preserving chroma 4:2:0 to have 4:4:4 video?
I mean something like (thanks FranceBB)
Y = ConvertToY8(matrix="Rec709").DeBilinearResizeMT(960, 540, src_left=-0.50, src_top=0)
U = UToY8()
V = VToY8()
YToUV(U, V, Y)
Old 11th April 2024, 01:23   #2898  |  Link
Dogway
Deriving the offset values is a pain given the sheer number of variables (chroma subsampling, scale factor, etc).
I made the algorithm in line 1965
ConvertFormat(cplace_in="left",cplace_out="center")
And you can specify the shifting kernel with 'kernel_c'
Old 11th April 2024, 10:28   #2899  |  Link
tormento
Acid fr0g
tormento's Avatar
Do you have something similar or better than hysteria in your scripts? I need to sharpen/line darken The dangers in my heart anime, that is so blurry even from BD.
Old 11th April 2024, 12:22   #2900  |  Link
Dogway
Wow, the master is back!
If the blurring was too extreme I would recommend the model HurrDeblur, but in this case it's just "soft". Didée's trick with aWarpSharp2 with lowpass might work. As for line darkening/thinning I made a mod called FastLineDarkenPlus. Maybe give it a try, not sure how it compares to Hysteria.
avisynth, dogway, filters, hbd, packs
