Old 9th March 2024, 19:44   #2861  |  Link
kedautinh12
You need take a look at Dogway's script
https://github.com/Dogway/Avisynth-S...ain.avsi#L1151
Old 9th March 2024, 20:23   #2862  |  Link
tormento
Acid fr0g
tormento's Avatar
As I wrote:
Originally Posted by tormento View Post
I have tried to look at the avsi but can't understand the conditions.
I can't understand that the "obscure" parameters do or the values that can be applied.
@turment on Telegram
Old 10th March 2024, 03:33   #2863  |  Link
kedautinh12
I just answer this question from you
And why do
ex_BM3D(preset="Light") or ex_BM3D(preset="light")
or
ex_BM3D(preset="Normal") or ex_BM3D(preset="normal")
Old 10th March 2024, 04:15   #2864  |  Link
FTLOY
Friend of a friend..
FTLOY's Avatar
Artifacts, but only certain scenes...
I am puzzled about some sort of haloing or ringing that is random during certain scenes.
It's hard to detect on a PC monitor, but rather obvious on a large screen TV.
If someone would be good enough to download my 2 minute sample to "see" what I am on about, and get some suggestions.
https://www.mediafire.com/file/1rbcj...ample.mkv/file (260Mb)
I'm thinking it might just be the phenomenon of "green screens" in the back ground.
If you pay particular attention to the horse riders as they ride passed the city wall, there's a "blurring" on some sort, surrounding them, but as they pass the gateway columns, into the gateway, the "blurring" disappears.
I've tried DeHalo_alpha, FineDehalo & HQDeringmod, to little affect
FTLOY is offline   Reply With Quote
Old 10th March 2024, 11:32   #2865  |  Link
tormento
Acid fr0g
tormento's Avatar
I hoped it was case insensitive.
Old 10th March 2024, 22:12   #2866  |  Link
DVB-Freak
FrameRateConverterMIX
Hello,
I have a problem with this function.
When I load my script in VD2, it show me this error on the picture.
Attachments Pending Approval
File Type: jpg Error.jpg
DVB-Freak is offline   Reply With Quote
Old 11th March 2024, 01:22   #2867  |  Link
kedautinh12
You need use other image websites
Old 11th March 2024, 01:44   #2868  |  Link
FTLOY
FTLOY's Avatar
This is FYI @DVB-Freak, for posting screenshots, etc.
Anything posted / attached here, takes a LONG time to be approved.
Old 11th March 2024, 22:37   #2869  |  Link
DVB-Freak
Here is the link to the image:
https://www.directupload.net/file/d/...jqm4bp_jpg.htm
My script:
FFVideoSource("C:\edit\Film.mkv")
FrameRateConverterMIX(Preset="RIFE", FrameDouble=true)
plugins:
ExTools v10.4 (09-01-2024)
Frame Rate Converter MIX v2.3.3 (10-10-2022)
Old 16th March 2024, 12:17   #2870  |  Link
rgr
Recently I have been testing QTGMCp. At 10 bits it is actually much faster than QTGMC, but the image quality is also lower - even worse than QTGMC at 8 bits.
The same settings: preset slower, TR=3.
Edit: I added it to Issues.
Left: QTGMCp (10bit)
Right: QTGMC (10bit)
File Type: jpg QTGMCp (10bit) vs QTGMC (10bit).jpg
rgr is offline   Reply With Quote
Old 16th March 2024, 12:27   #2871  |  Link
kedautinh12
Lol, please upload your image to other image websites. The mod rarely approval your image from here
Old 19th March 2024, 02:58   #2872  |  Link
takla
@Dogway
I get the following error with FrameRateConverterMIX
Evaluate: operands of "%" must be integers
ExTools.avsi, line 7509
takla is offline   Reply With Quote
Old 19th March 2024, 15:46   #2873  |  Link
DTL
Maybe you need to manually adjust thSAD values for each version of QTGMC script. For denoising part of this script.
From documentation http://avisynth.nl/index.php/QTGMC
ThSAD2 (0...) SAD threshold for block match on final denoising temporal smooth (TR2). Increase to strengthen final smooth (may smear/blur) Default: 256
If while increasing thSAD you got no-increase in denoise - it may mean sc-detector is active because of too high noise level. So you also need to set higher thSCD.
Old 25th March 2024, 01:58   #2874  |  Link
FTLOY
FTLOY's Avatar
I just thought I'd bump this, as I was hoping for some sort of a reply
I'm sure this has been asked about many times, but...
Can you call SMDegrain (with different parameters) twice in the same script ??
If so, an example would be helpful.
Regards
Old 25th March 2024, 06:27   #2875  |  Link
takla
Regards
Yes you can. But why would you do that? It takes more CPU resources since the filter has to run twice.
To run it twice, use two lines with it...
Example
SourceFilter("input.mkv")
SMDegrain(blkSize=8)
SMDegrain(blkSize=32)
Old 25th March 2024, 10:00   #2876  |  Link
FTLOY
FTLOY's Avatar
Example
I will try this...there might be certain situations where the footage needs a 2nd "hit" with different parameters, that's all.
eg:- instead of a real heavy filter setting, use 2 lighter ones....
Old 25th March 2024, 13:08   #2877  |  Link
takla
Uhm no, thats not something you should do. Adjust TR for denoising strength and thSAD for how much noise is picked up.
Old 27th March 2024, 09:47   #2878  |  Link
FTLOY
FTLOY's Avatar
This is only a curiosity script, I have some very specific & complex SMDegrain scripts I use
Old 29th March 2024, 20:50   #2879  |  Link
Dogway
Sorry for the delay, very busy these days. I'm updating a few things mentioned. Typos or minor QoL changes.
Regards
You can run
SMDegrain(mode="rMDegrain")
and it will run MDegrain twice but with the same vectors. If you want to refine vectors simply run
SMDegrain(RefineMotion=true)
. Or a suggestion from the docs, run SMDegrain as a prefilter for SMDegrain. Depends on what you want to do and source quality.
@Dogway
The filter is working for me. That's in ex_bs() function, specifically in ibi = ibi-ibi%2 I think. 'ibi' is an int argument same as 'obi'. I'd need more info.
I got this error when tried SMDerain's latest ver:
My script:
LWLibavVideoSource("C:\Users\ADMIN\Downloads\LR_11.avi")
SMDegrain(6, 400, prefilter=6, ContraSharp=true, RefineMotion=true, plane=4, limits=false, DCTFlicker=false, gpuid=1)
SMDegrain doesn't officially support RGB, as stated in the script:
### Supports all Y, YUV and YUY2 clips progressive or interlaced between 8-16 bits.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 30th March 2024, 16:07   #2880  |  Link
tormento
Acid fr0g
tormento's Avatar
Glad to have you back.
Please fix prefilter=7 in SMDegrain
avisynth, dogway, filters, hbd, packs
