Old 16th April 2024, 23:06   #2821  |  Link
tormento
Acid fr0g
tormento's Avatar
Do we still need to declare SetMemoryMax?
I mean, almost 70% of the computers are now 64-bit with gazillions of GBs of RAM.
Is it of any use? Can't we simply let modern Windows to manage memory?
@turment on Telegram
Old 16th April 2024, 23:20   #2822  |  Link
LigH
LigH's Avatar
You can probably omit it quite safely. Avisynth uses a convenient default.
New German Gleitz board
Old 17th April 2024, 04:47   #2823  |  Link
Boulder
Pig on the wing
Boulder's Avatar
The default is quite conservative and is sometimes not enough if you work on 4K sources with heavy filtering and use multithreading. There's no real harm setting the max higher if you have the memory available, Avisynth will use what it needs and not all of it automatically.
Old 17th April 2024, 12:16   #2824  |  Link
tormento
Acid fr0g
tormento's Avatar
Perhaps I didn't explain well.
I know I can set it as I want but, seen VaporSynth memory use, why can't AVS+ go that way too and send Setmemorymax to ancient memories?
Old 17th April 2024, 12:17   #2825  |  Link
tormento
Acid fr0g
tormento's Avatar
I can't find my post but, some years ago, I did some tests where I saw performance decrease with Setmemorymax increase.
Old 18th April 2024, 00:09   #2826  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
It's already ancient memory.
There's no need to set it, Avisynth will manage that automatically.
By default, in modern x64 systems, it will use 4GB of RAM which is plenty.
Remember that this is the memory of the cache, in other words the memory used to store frames without having to fetch them again, NOT the RAM used by filters in general. This means that even if you were to set SetMemoryMax(512) but you were heavily filtering a UHD content, Avisynth would still use way more than 512MB of RAM. Remember that the cache is there only so that if you have temporal filters and encoders that need to access frames in a non linear fashion, Avisynth won't have to compute them every single time it moves forward and backward and forward and backward etc. The bigger the cache the more frames are gonna be stored, but storing too many frames can be detrimental as it's gonna use RAM that could otherwise be used by - let's say - the encoder, which is why the cache size is calculated on the fly on the basis of the available RAM and it never exceeds 4GB.
Assuming RGB48 (which is overkill anyway), we have:
3840×2160×48 = 398131200 bits = 0.0498 gigabyte
That's just for one frame, so at the current default Avisynth can cache more than 80 frames. Obviously working with RGB48 UHD is a bit unrealistic, but if we work in YUV that number increases and it even goes much further if we work in 8bit and at lower resolutions.
My point is that it's already implemented correctly and I don't see a reason to change that. If anything, having the SetMemoryMax() is useful if you wanna reduce the cache.
Old 18th April 2024, 04:20   #2827  |  Link
DTL
It looks you not understand how frame-based AVS+ MT is working.
To make things as fast as possible (to minimize CPU stall on threads sync) it looks AVS+ simply put several frames cache around _each_ filter in the filtergraph and in _each_ logical thread. So any time system have some free logical CPU cores it can load it with some useful computing.
But it cause awful RAM consuming in any 'complex' scripts of a several filters in a chain.
Total RAM in a cache is about NumFrames_in_Prefetch_x_NumFilters_x_NumThreads_x_FrameSize.
Old 18th April 2024, 04:59   #2828  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Regarding the 4GB, which is unfortunately not enough in many cases: https://forum.doom9.org/showthread.p...75#post1913375
Old 18th April 2024, 10:28   #2829  |  Link
tormento
Acid fr0g
tormento's Avatar
Regarding the 4GB
AVSMeter can provide realistic results?
(Where on hell has Groucho2004 gone?)
Secondo question: SetCacheMode(1) is a good choice?
Old 18th April 2024, 10:57   #2830  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Another interesting thing about prefetch, I see!
I see! But to clarify I don't actually use Prefetch, like ever, I'm on the good old concept of letting plugin developers handle multithreading, so my scripts don't have it.
For instance, my scripts are like:
video=LWLibavVideoSource("video.mxf")
audio=LWLibavAudioSource("audio.mxf")
AudioDub(video, audio)
ConvertBits(16)
ConvertYUVtoXYZ(Color=0, OutputMode=1, HDRMode=0, fullrange=false)
ConvertXYZ_Reinhard_HDRtoSDR(exposure_X=2.5, contrast_X=0.9)
ConvertXYZtoYUV(pColor=0)
without prefetch. In the example above, the filters would create their own threadpool which is how I think it's intended to be. Call me traditionalist but I see Prefetch() as an evolution of the old MT Modes from 2009 and in my head they should only be used if the filter you're calling is old and single-threaded only and of course at your own risk as it might misbehave, especially if it filters temporally.
This however brings me to a different question, then.
Is there an advantage in raising the SetMemoryMax() value from 4GB to something higher IF I don't use Prefetch()?
Old 18th April 2024, 12:08   #2831  |  Link
DTL
If you not use Prefetch() it mean AVS+ will run all filtergraph with single threaded cache mode ? So the equation for total cache size is about
NumFrames_in_Prefetch_x_NumFilters_x_FrameSize.
Default num frames in AVS+ cache (for each filter) is at least several ? (2..3 to 10 ? or num of physical cores ?).
"Is there an advantage in raising the SetMemoryMax() value from 4GB to something higher IF I don't use Prefetch()?"
It may depends on workflow. And easy tested between 4 GB and all RAM avaialble. The idea of SetMemoryMax() may be complex hint to AVS memory manager like to save from swapping of too much allocated cache pages attempt to lower number of cached frames if total process RAM allocation approaches the current RAM limit.
Because with increasing number of frames in the cache user may got some performance boost (depending of filters used and many more effects) setting too low MemoryMax may cause decreasing of performance in some use cases. It is better to check with exact end user workflow.
Old 18th April 2024, 12:58   #2832  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Windows Task Manager shows the same information. With heavy prefetch settings like threads=32, frames=12 on my 5950X, a 4K source with MVTools based filtering and downscaling with avsresize's functionalities, outputting 16-bit data to x265 can take 20GB of memory. The amount of frames to prefetch is the key to memory usage. That's why it is important to restrict it if you have a lot of cores, the default is way too much (would be 64 frames in this case )
I've found out that mode 1 is better.
Old 18th April 2024, 13:01   #2833  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I would say probably not. I've been running my chunked encoding tool and the memory usage is usually max 3GB per avs2yuv64 process with my standard denoising and resizing functions. Though it's with 10-bit output, I've not tested if 16-bit output changes things that much to go over the 4GB limit.
Old 18th April 2024, 16:56   #2834  |  Link
tormento
Acid fr0g
tormento's Avatar
My findings.
Basic script
PHP Code:
SetFilterMTMode("DEFAULT_MT_MODE"2)
LoadPlugin("D:\Eseguibili\Media\DGDecNV\DGDecodeNV.dll")
DGSource("M:\In\2013 GIT - Arise ~864p Dynit\2013_06 Ghost pain.dgi")
Comptest24(1)
Convertbits(16)
libplacebo_Resample(1536,864,filter="ewa_lanczossharp")
SMDegrain (tr=3thSAD=300refinemotion=falsecontrasharp=falsePreFilter=7plane=4chroma=truemode="MDegrain")
libplacebo_Deband(iterations=3temporal=true)
fmtc_bitdepth (bits=10,dmode=7)
Prefetch(3
AVSMeter 3.0.9.0 (x64), (c) Groucho2004, 2012-2021
AviSynth+ 3.7.3 (r4071, 3.7, x86_64) (3.7.3.0)
Number of frames: 1680
Length (hh:mm:ss.ms): 00:01:10.070
Frame width: 1536
Frame height: 864
Framerate: 23.976 (24000/1001)
Colorspace: YUV420P10
Frames processed: 1680 (0 - 1679)
FPS (min | max | average): 1.202 | 116279 | 11.54
Process memory usage (max): 1990 MiB
Thread count: 45
CPU usage (average): 35.7%
GPU usage (average): 15%
VPU usage (average): 8%
GPU memory usage: 1496 MiB
GPU Power Consumption (average): 41.6 W
x265 slow: encoded 1680 frames in 297.25s (5.65 fps), 1134.83 kb/s, Avg QP:23.77
Adding on top:
PHP Code:
SetMemoryMax()
FPS (min | max | average): 1.589 | 55866 | 11.33
Process memory usage (max): 1947 MiB
Thread count: 45
CPU usage (average): 35.6%
x265 slow: encoded 1680 frames in 293.64s (5.72 fps), 1138.50 kb/s, Avg QP:23.70
Adding on top:
PHP Code:
SetCacheMode(1
FPS (min | max | average): 0.340 | 178572 | 11.52
Process memory usage (max): 1849 MiB
Thread count: 45
x265 slow: encoded 1680 frames in 297.86s (5.64 fps), 1137.39 kb/s, Avg QP:23.72
Adding on top:
PHP Code:
SetMemoryMax()
SetCacheMode(1
FPS (min | max | average): 0.338 | 133333 | 11.42
Process memory usage (max): 1846 MiB
Thread count: 45
x265 slow: encoded 1680 frames in 284.14s (5.91 fps), 1136.06 kb/s, Avg QP:23.72
I see some discrepancies between avs+ only and real world scenario with x265 encoding but, perhaps, is just my old machine.
Old 18th April 2024, 18:07   #2835  |  Link
DTL
"SetMemoryMax() "
I think it requires memory size (in MBytes ?). Empty params call do not change current AVS memory max.
SetMemoryMax(amount)
Sets the maximum memory that AviSynth uses (in MB) to the value of amount. Setting to zero just returns the current Memory Max value. In the 2.5 series the default Memory Max value is 25% of the free physical memory, with a minimum of 16MB.
The default Memory Max is also limited to 512MB.
AVS+In Avisynth+ this limit for default Memory Max is 1024MB for 32 bits and 4096MB on the x64 version
DefaultMemoryMax = minimum(physical_memory / 4, secondary_memory_max_limit)
This really working:
ColorBars()
mem=SetMemoryMax(0)
SubTitle(Format("old default max={mem}!"))
SetMemoryMax(5000)
mem=SetMemoryMax(0)
SubTitle(Format("new max={mem}!"), align=4)
First call returns old memory max value (4074 at me) and second call sets to 5000 MB.
So you can first check your current system default memory max and check some significant changes like set to 10 times lower and about 70..80% of current RAM installed.
Old 18th April 2024, 18:54   #2836  |  Link
TDS
Formally known as .......
TDS's Avatar
Where did this come from ??
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 18th April 2024, 20:30   #2837  |  Link
DTL
From documentation at http://avisynth.nl/index.php/Internal_functions
http://avisynth.nl/index.php/Interna...s#SetMemoryMax
Old 18th April 2024, 22:27   #2838  |  Link
TDS
TDS's Avatar
Sorry DTL, you misunderstood
Where did that build of Avisynth come from, (r4071) In tormento's post.
But
Found it....https://gitlab.com/uvz/AviSynthPlus-Builds
Old 19th April 2024, 12:21   #2839  |  Link
tormento
Acid fr0g
tormento's Avatar
"SetMemoryMax() "
I look at numbers
Something happens and is not what I expected.
Some years ago I did benchmarks here with various amount of memory and that () lead to the best results, even against higher ones.
Old 23rd April 2024, 05:59   #2840  |  Link
hello_hello
Is it intended for the Convert functions to change the chroma location when they're not actually changing the color format?
For example, if you have a YUV420 source with the chroma location in frame properties as "top_left", and you add ConvertToYUV420() to the script, the color format doesn't change but the chroma location changes to "left".
I know "left" is the default output chroma location, and it works as the Avisynth wiki says it does, but before I noticed the chroma location had changed and checked, I expected it to remain the same unless the color format had changed.
I can't decide if changing the location when there's no conversion taking place is a good idea. Or maybe it doesn't matter much....
Cheers.
