19th October 2023, 15:10 | #2661 | Link | |
Broadcast Encoder
26th October 2023, 15:25 | #2663 | Link |
Broadcast Encoder
Well, I was testing exactly that and I noticed another issue.
Unfortunately, PlanarTools produce an Access Violation both with 3.7.3 stable and with this new build. Code:
FFImageSource("Image.png") ExtractPlane(0) The image is a simple RGB32 (so RGB24 + 8 for the alpha channel) png lossless, but it can be replaced with a simple ColorBars(): Code:
ColorBars(848, 480, pixel_type="RGB32") ExtractPlane(0) This was tested on Windows 10 22H2 x64 Enterprise, but I also tested it on Windows XP x86 Professional and the result is also an error but perhaps even worse: |
26th October 2023, 15:49 | #2664 | Link | |
But this PlanarTools is crashing of course. It is using the IScriptEnvironment2 interface which is not allowed and Avisynth version dependant. in Avisynth.h: Code:
/* ----------------------------------------------------------------------------- Note to plugin authors: The interface in IScriptEnvironment2 is preliminary / under construction / only for testing / non-final etc.! As long as you see this note here, IScriptEnvironment2 might still change, in which case your plugin WILL break. This also means that you are welcome to test it and give your feedback about any ideas, improvements, or issues you might have. ----------------------------------------------------------------------------- */ |
26th October 2023, 16:52 | #2665 | Link |
Broadcast Encoder
Gotcha!
Well, I used this as a temporary workaround: Code:
FFImageSource("image.png") my_alpha=ShowAlpha(pixel_type="RGB24") RemoveAlphaPlane() ConvertBits(16) ConvertToPlanarRGB(matrix="PC.709", interlaced=false) Cube("3a_BT709_HLG_Type1.cube", interp=1, fullrange=1) my_HLG=last ConvertBits(my_alpha, 16) ConvertToPlanarRGB(matrix="PC.709", interlaced=false) Cube("3a_BT709_HLG_Type1.cube", interp=1, fullrange=1) ConverttoY(matrix="PC.2020") my_alpha_HLG=last AddAlphaPlane(my_HLG, my_alpha_HLG) There I was working in Full Range with your new build and it was fine as levels were preserved during the conversion given that I used "PC.2020". About RGB Narrow Range, this is an RGB 16bit Limited TV Range (i.e Narrow Range) in PQ: Frame: 831 Keys: 15 MasteringDisplayMaxLuminance (4000.0) MasteringDisplayMinLuminance (0.005) MasteringDisplayPrimariesX (0.68, 0.265, 0.15) MasteringDisplayPrimariesY (0.32, 0.69, 0.06) MasteringDisplayWhitePointX (0.3127) MasteringDisplayWhitePointY (0.329) _AbsoluteTime (34.659625) _ColorRange (1[limited]) _DurationDen (24000) _DurationNum (1001) _FieldBased (0[progressive]) _Matrix (0[RGB]) _PictType (I) _SARDen (1) _SARNum (0) it's correctly recognized as limited tv range RGB. Now, in 3.7.3 stable, if I did something like: Code:
#Indexing Studio RGB PQ LWLibavVideoSource("Test.mxf") ConverttoYUV444(matrix="Rec2020") which is clearly wrong. Now, as per your new build, I expected it to read the Limited TV Range flag and actually get it right automagically, however I seem to be misunderstanding something 'cause this: Code:
#Indexing Studio RGB PQ LWLibavVideoSource("Test.mxf") ConverttoYUV444() I even tried to force the range detection with: Code:
PropSet("_ColorRange", 1) This is the build: Last edited by FranceBB; 26th October 2023 at 16:54. |
26th October 2023, 18:26 | #2666 | Link | |
ExtractPlane(0) can't be replaced with avs+ Extract()? like ExtractR()
See My Avisynth Stuff |
26th October 2023, 18:57 | #2667 | Link |
FranceBB, thanks for the feedback, I'm looking into that.
edit: my bad, I've propably used cut-and-paste at one place instead of copy-paste, so before RGB->444 conversion no properties were obtained from 0th frame. Expect new builds on Friday. edit2: Thursday is the new Friday. Avisynth+ 3.7.3post test 5 (20231026 - r4017) (with narrow rgb -> 444 fix - hopefully) Last edited by pinterf; 26th October 2023 at 20:31. Reason: problem found - new test |
31st October 2023, 16:04 | #2668 | Link |
Avisynth+ 3.7.3post test 6b (20231031 - r4018)
Change from test5: Code:
- Fix #368 (https://github.com/AviSynth/AviSynthPlus/issues/368) Make proper vertical alignment for multiline text (containing "\n" and parameter "lsp" is defined) in Subtitle and Text when vertical alignment is set to bottom (align=1,2,3) or center (4,5,6). Ending "\n" is treated as a new empty line, so "Line1" is one line, but "Line1\n" has two lines and the second one is an empty line. See also https://forum.doom9.org/showthread.php?t=185145 Last edited by pinterf; 1st November 2023 at 07:00. |
31st October 2023, 18:36 | #2669 | Link |
Big Bit Savings Now !
Jó estet Ferenc !
Here my findings from 17.03.2023 as I was puzzled too by AviSynth's typographic habits while getting my portalscope tidied. Maybe it helps while rewriting documentation... (Don't know the english wording for some typographical expressions, so please be kind and translate on your side.) AviSynth Subtitle align 789 456 123 size (total line size) := 1/8 Unterlänge + 3/4 Capital letter size + 1/8 Akzent-Oberlänge 7 y:=Oberlänge, Text hängt unter seiner Akzent-Oberlänge y und ist linksbündig, läuft ab x nach rechts 8 y:=Oberlänge, Text hängt unter seiner Akzent-Oberlänge y und ist x-zentriert, läuft nach links und rechts 9 y:=Oberlänge, Text hängt unter seiner Akzent-Oberlänge y und ist rechtsbündig, läuft ab x nach links 4 y:=Grundlinie, Text steht auf seiner Grundlinie y und ist linksbündig, läuft ab x nach rechts 5 y:=Grundlinie, Text steht auf seiner Grundlinie y und ist x-zentriert, läuft nach links und rechts 6 y:=Grundlinie, Text steht auf seiner Grundlinie y und ist rechtsbündig, läuft ab x nach links 1 y:=Unterlänge, Text schwebt auf seiner Unterlänge y und ist linksbündig, läuft ab x nach rechts 2 y:=Unterlänge, Text schwebt auf seiner Unterlänge y und ist x-zentriert, läuft nach links und rechts 3 y:=Unterlänge, Text schwebt auf seiner Unterlänge y und ist rechtsbündig, läuft ab x nach links Vertical centering: 7,8,9 y:=y-size/2 4,5,6 y:=y+size*3/8 1,2,3 y:=y+size/2 subtitle applies font_angle first, then aligns along the original orientation. In the end AviSynth's derivation appears logical: For a fullsize glyph having all possible underlengths/upperlengths/accents giving one of the 4 width x height corner coordinates any appropriate (inward running) alignment's rendering must result in touching, but not exceeding both appropriate screen borders. P.S. As this has been discussed recently, I would concur that this had been conceived with only one-liners in mind, so one should not expect any provisions for multiline-text.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 31st October 2023 at 19:31. |
1st November 2023, 01:23 | #2672 | Link | |
Nope, dont like that, but dont like below either "Line1" has only a single line of text. "Line1\n", has still only a single line of text, text written/flushed to output device, and logical print cursor position moves down 1 line due to NewLine '\n', but there is no more text to print and so still only a single line of text was output. "Line1\nLine2", 2 lines output, "Line1" and "Line2", with a Newline moving cursor down between them. "Line1\nLine2\n", 2 lines output, "Line1" and "Line2", with a Newlines moving cursor down after both of them. A final move of the cursor (after final print line) does not affect the number of lines printed. [EDIT: This Line in SubV script function, Code:
# Line count with/without final newline END EDIT] However, NewLines in any position other than at very end of the string, have to be counted as they affect the 'area' of [and position of any additional] print. "\nLine2", is 2 lines. In this case leading empty line has to be taken into account. The initial '\n' prints empty line and then moves down 1 line and prints "Line2". "\nLine2\n". is 2 lines, the initial '\n' prints empty line and then moves down 1 line and prints "Line2", the final '\n' only moves the cursor, does not affect 'area' of print. "Line1\n\n". is 2 lines, the initial '\n' prints empty line and then moves down 1 which does affect print 'area', the final '\n' only moves the cursor, does NOT affect 'area' of print. "\nLine2\n\n", is 3 lines, If an ending empty line is required (to affect justification) then cannot omit the final '\n' (ie "\nLine2\n" is only 2 lines, not 3). "\nLine2\nLine3\n", is 3 lines. [final '\n' just moves cursor] "\nLine2\nLine3\n\n", is 4 lines. [final '\n' just moves cursor] "\n\nLine3\nLine4", is 4 lines. "\n\nLine3\nLine4\n", is 4 lines. [final '\n' just moves cursor] "\n\nLine3\nLine4\n\n", is 5 lines. [final '\n' just moves cursor] "\n\nLine3\n\nLine5", is 5 lines. "\n\nLine3\n\nLine5\n", is 5 lines. [final '\n' just moves cursor] "\n\nLine3\n\nLine5\n\n", is 6 lines. [final '\n' just moves cursor] Ending complete multi-line string with '\n' has no justifiication effect [same line count as the string without any trailing '\n']. Ending complete multi-line string with '\n\n' vertical center justifies upwards by 0.5 lines [vertical print lines 'area' seems 1 bigger than actual text lines]. Ending complete multi-line string with '\n\n\n' vertical center justifies upwards by 1 line [vertical print lines 'area' seems 2 bigger than actual text lines]. Ending complete multi-line string with '\n\n\n\n' vertical center justifies upwards by 1.5 lines [vertical print lines 'area' seems 3 bigger than actual text lines]. Ending complete multi-line string with '\n\n\n\n\n' vertical center justifies upwards by 2.0 lines [vertical print lines 'area' seems 4 bigger than actual text lines]. Similarly, starting a multiline string with '\n' will vertical center justify downwards by 0.5 of a line (and '\n\n' by 1, and '\n\n\n' by 1.5). Its a bit awkward to explain, but has to work like above so as to be able to affect vertical justification using Newlines. To be sure that you are counting your newlines correctly, always end with '\n'. [but if you dont, there is an implied one there anyway] Counting Lines in Multi-line string: For vertical justification we need to count the number of lines printed in a multi-line string. So, firstly if the multi-line text string is "" then number of lines is 0, Otherwise below, To count the text lines, you need to count the '\n' newlines, but, if newline '\n' does not occur at very end of the multi-line string, then counting newlines alone gives wrong answer (you need add 1 to line count in such a case).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 1st November 2023 at 05:32. |
1st November 2023, 07:16 | #2674 | Link |
Thanks, x86 folder contained an x64 dll as well, package is fixed, please redownload (the link was edited above)
@Emulgator, thank you @StainlessS Thanks for the feedback, I'm going to digest your whole post later, I see now that newline count must be changed (following "Counting Lines in Multi-line string"). Till then, pls test it with this future change in mind. I'd really like to upload my changes to git before I die (I was lightly and gently hit by a car yesterday when riding home - fortunately I have no injuries) |
1st November 2023, 14:42 | #2676 | Link | |
Broadcast Encoder
OH! I'm so sorry to hear that, Ferenc! Get well soon and rest. |
1st November 2023, 18:24 | #2677 | Link |
Formerly davidh*****
Just came across an oddity. Since 2.54, ChangeFPS has a parameter linear = true which forces linear access (apparenly for up to 10 frame gaps).
If you use SelectEven (or some other frame-culling filter) after ChangeFPS with linear = true (the default), it will insist on fetching every frame, which can cause quite an unexpected slowdown. Does anyone know the rationale for linear = true? Last edited by wonkey_monkey; 1st November 2023 at 20:29. |
1st November 2023, 18:39 | #2678 | Link |
P,
This is source for RT_TxtQueryLines(), however it counts '\n' [Chr(10) Linefeed, rather than "\n" subtitle string style escape]. Some scriptors {MAC users ?} use Chr(13) {carriage return} instead of correct [IMHO] Chr(10) {LineFeed} for NewLine, we have to deal with both in RT_TxtQueryLines(), but you do not have to do that for subtitle escaped strings. We also do not know source of the provided string, and so have to cope with matched pairs of both '\r' + '\n' OR, '\n' + '\r' just incase somebody got the order mixed up. DOS order should be CR/LF where paired {if you create a text file containing lots of wrongly paired LF/CR, and load it into eg Word, it will drive the poor app crazy... very jumpy about-y}. Use if you wish., should be easy modded. Anyways, you be careful and stop having fights with the traffic, bicycle riders rarely win such fights. This guy here was NEARLY lightly and gently hit by a car yesterday too [standing by his broken down car on motorway]. https://www.thesun.co.uk/motors/2458...y-lamborghini/ OOps, forgot the source. Code:
AVSValue __cdecl RT_TxtQueryLines(AVSValue args, void* user_data, IScriptEnvironment* env) { const char *Str=args[0].AsString(); const char *s=Str; int c,Lines=0; while(c=*s) { if(c=='\n' || c == '\r') { if((c=='\n' && s[1]=='\r') || (c=='\r' && s[1]=='\n')) ++s; ++Lines; } ++s; } if(Str < s && s[-1] != '\n' && s[-1] != '\r') ++Lines; // Last line not n/l terminated, but still counts return Lines; }
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 1st November 2023 at 18:44. |
2nd November 2023, 00:46 | #2679 | Link | |
Broadcast Encoder
Essentially, if the difference between the ChangeFPS() target frame rate and the original clip framerate was higher than x it outputted an error and I've seen it in lots of logs as I was using it in one of my automated workflows. I changed it to linear=false in the script, the files processed fine and I never looked back, but I'd like to know more on what exactly that parameter is doing. Still, I think that linear=false will reproduce the original behavior, especially 'cause before that you could use ChangeFPS() on literally any FPS in input to produce any FPS in output by dropping or duplicating frames (the only one having limitations was ConvertFPS() instead as it uses blending). This can be easily reproduced with: Old Avisynth (works): Code:
ColorBars(848, 480, pixel_type="YV12") ChangeFPS(100) ChangeFPS(5) Code:
ColorBars(848, 480, pixel_type="YV12") ChangeFPS(100) ChangeFPS(5) Avisynth 3.7.3 r4013 works (old behavior is restored with linear=false): Code:
ColorBars(848, 480, pixel_type="YV12") ChangeFPS(100, linear=false) ChangeFPS(5, linear=false) Wouldn't it make more sense to have linear=false set by default rather than having it set to true by default so that the old behavior is restored? Last edited by FranceBB; 2nd November 2023 at 09:52. |
