Old 21st May 2011, 21:01   #12061  |  Link
worknstiff
@jdobbs, RE:X264's settings are less challenging and it is encoding faster than the frames are being presented to it.
Thanks for the input from the person in charge that should know if anyone here does, lol. I was just wondering why such a big difference between pass1 and pass2 unless it's because it is actually writing the data to the HD instead of just examining the data. I thought maybe that accounts for the 40 fps difference, and maybe a intel X25 SSD would help close the gap between pass 1 and 2, but I am still really pleased with 20 fps in pass2. I was getting around 5 fps in pass2 with my old E8400.
worknstiff is offline   Reply With Quote
Old 21st May 2011, 21:04   #12062  |  Link
omegaman7
omegaman7's Avatar
Keep in mind, that the amount of compression will greatly effect how many FPS you'll see. If you have over 4hrs to compress, that's gonna take some time. 3+ hrs seems to be pretty common I've noticed. If you're converting only the main title, that's gonna take considerably less time. Myself, I prefer to keep as much intact as possible
omegaman7 is offline   Reply With Quote
Old 21st May 2011, 21:09   #12063  |  Link
had-z
A perfect backup of Black Hawk Down done with the latest build!! many thanks jdobbs seems like the IGS problem is 100% fixed, now the only major issue is the DTS-E Mux...
Cheers!
had-z is offline   Reply With Quote
Old 22nd May 2011, 15:07   #12064  |  Link
KillingTime
So it's working now?
No, I meant I've found the .ini fiile from the re-encode I did, my mistake was to give you the log file first time round.
All the errors I've had so far have been with those transparent discs though. I think it has more to do with your optical drive design than anything else. Remember the silliness with DVDs when the distributors wanted to stop home ripping? They made DVDs that did not conform to Philips spec, that would play in most set top players, but not in computer drives. This could be the start of something similar, but I have no proof.
The rip and rebuild of your copy will put this issue to bed. At exactly 20 muinutes into the film, there's a scene where the new CO is telling Eastwood he's obsolete, and you get a close up of the actors faces. It's asy to spot audio lag here.
KillingTime is offline   Reply With Quote
Old 22nd May 2011, 16:07   #12065  |  Link
jdobbs
I ran "Heartbreak Ridge" yesterday -- no issues here. Just to be sure I just reviewed the scene you mentioned. I wanted to punch the CO , but the sound was in perfect sync.
Website: www.jdobbs.net
Old 23rd May 2011, 14:25   #12066  |  Link
[SLiM]D12
Originally Posted by [SLiM]D12 View Post
Re-encoded again using custom size, was 7GB this time.........here's the log:
[12:13:28] BD Rebuilder v0.37.08 (beta)
- Source: STAND_BY_ME
- Input BD size: 29.25 GB
- Approximate total content: [02:42:11.511]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7601]
- Quality: High Quality (Default), Two Pass
[12:13:28] PHASE ONE, Encoding
- [12:13:28] Extracting A/V streams [VID_00021]
- [12:13:29] Reencoding: VID_00021 (1 of 14)
- [12:13:29] Collecting video information
- Source Video: MPEG-2, 1920x1080
- Rate/Length: 23.976fps, 24 frames
- [12:13:29] Reencoding: VID_00021, Pass 1 of 1
- [12:13:30] Video Encode complete
- [12:13:30] Reencoding audio tracks (if req'd)
- [12:13:30] Multiplexing M2TS
- [12:13:30] Extracting A/V streams [VID_00081]
- [12:13:35] Reencoding: VID_00081 (2 of 14)
- [12:13:35] Collecting video information
- Rate/Length: 23.976fps, 1,440 frames
- [12:13:35] Reencoding: VID_00081, Pass 1 of 1
- [12:13:50] Video Encode complete
- [12:13:50] Reencoding audio tracks (if req'd)
- [12:13:50] Multiplexing M2TS
- [12:13:50] Extracting A/V streams [VID_00101]
- [12:13:55] Reencoding: VID_00101 (3 of 14)
- [12:13:55] Collecting video information
- Rate/Length: 23.976fps, 1,012 frames
- [12:13:55] Reencoding: VID_00101, Pass 1 of 1
- [12:14:10] Video Encode complete
- [12:14:10] Reencoding audio tracks (if req'd)
- [12:14:10] Multiplexing M2TS
- [12:14:11] Extracting A/V streams [VID_00104]
- [12:14:16] Reencoding: VID_00104 (4 of 14)
- [12:14:16] Collecting video information
- [12:14:16] Reencoding: VID_00104, Pass 1 of 1
- [12:14:31] Video Encode complete
- [12:14:31] Reencoding audio tracks (if req'd)
- [12:14:31] Multiplexing M2TS
- [12:14:32] Extracting A/V streams [VID_00107]
- [12:14:40] Reencoding: VID_00107 (5 of 14)
- [12:14:40] Collecting video information
- Source Video: MPEG-2, 720x480
- Rate/Length: 29.970fps, 6,040 frames
- [12:14:40] Reencoding: VID_00107, Pass 1 of 1
- [12:15:01] Video Encode complete
- [12:15:01] Reencoding audio tracks (if req'd)
- [12:15:01] Multiplexing M2TS
- [12:15:03] Extracting A/V streams [VID_00108]
- [12:15:10] Reencoding: VID_00108 (6 of 14)
- [12:15:10] Collecting video information
- Rate/Length: 23.976fps, 1,451 frames
- [12:15:10] Reencoding: VID_00108, Pass 1 of 1
- [12:15:30] Video Encode complete
- [12:15:30] Reencoding audio tracks (if req'd)
- [12:15:30] Multiplexing M2TS
- [12:15:31] Extracting A/V streams [VID_00022]
- [12:15:38] Reencoding: VID_00022 (7 of 14)
- [12:15:38] Collecting video information
- Rate/Length: 23.976fps, 1,555 frames
- [12:15:38] Reencoding: VID_00022, Pass 1 of 1
- [12:16:01] Video Encode complete
- [12:16:01] Reencoding audio tracks (if req'd)
- [12:16:01] Multiplexing M2TS
- [12:16:03] Extracting A/V streams [VID_00109]
- [12:16:14] Reencoding: VID_00109 (8 of 14)
- [12:16:14] Collecting video information
- Rate/Length: 23.976fps, 3,151 frames
- [12:16:14] Reencoding: VID_00109, Pass 1 of 1
- [12:16:55] Video Encode complete
- [12:16:55] Reencoding audio tracks (if req'd)
- [12:16:55] Multiplexing M2TS
- [12:16:57] Extracting A/V streams [VID_00113]
- [12:17:10] Reencoding: VID_00113 (9 of 14)
- [12:17:10] Collecting video information
- Rate/Length: 23.976fps, 3,797 frames
- [12:17:10] Reencoding: VID_00113, Pass 1 of 1
- [12:18:05] Video Encode complete
- [12:18:05] Reencoding audio tracks (if req'd)
- [12:18:05] Multiplexing M2TS
- [12:18:08] Extracting A/V streams [VID_00110]
- [12:18:21] Reencoding: VID_00110 (10 of 14)
- [12:18:21] Collecting video information
- Rate/Length: 23.976fps, 3,771 frames
- [12:18:21] Reencoding: VID_00110, Pass 1 of 1
- [12:19:14] Video Encode complete
- [12:19:14] Reencoding audio tracks (if req'd)
- [12:19:14] Multiplexing M2TS
- [12:19:17] Extracting A/V streams [VID_00111]
- [12:19:33] Reencoding: VID_00111 (11 of 14)
- [12:19:33] Collecting video information
- Rate/Length: 23.976fps, 4,559 frames
- [12:19:33] Reencoding: VID_00111, Pass 1 of 1
- [12:20:53] Video Encode complete
- [12:20:53] Reencoding audio tracks (if req'd)
- [12:20:53] Multiplexing M2TS
- [12:20:57] Extracting A/V streams [VID_00105]
- [12:21:28] Reencoding: VID_00105 (12 of 14)
- [12:21:28] Reencoding secondary video [TRK_02]
- [12:21:38] Collecting video information
- Rate/Length: 23.976fps, 5,712 frames
- [12:21:38] Reencoding: VID_00105, Pass 1 of 1
- [12:23:52] Video Encode complete
- [12:23:52] Reencoding audio tracks (if req'd)
- [12:23:52] Multiplexing M2TS
- [12:24:03] Extracting A/V streams [VID_00106]
- [12:25:38] Reencoding: VID_00106 (13 of 14)
- [12:25:38] Collecting video information
- Rate/Length: 29.970fps, 66,135 frames
- [12:25:39] Reencoding: VID_00106, Pass 1 of 1
- [12:29:14] Video Encode complete
- [12:29:14] Reencoding audio tracks (if req'd)
- [12:29:14] Multiplexing M2TS
- [12:29:27] Extracting A/V streams [VID_00011]
- [12:45:31] Reencoding: VID_00011 (14 of 14)
- [12:45:31] Reencoding secondary video [TRK_02]
- [12:51:52] Collecting video information
- Rate/Length: 23.976fps, 127,656 frames
- Bitrate: 23,952 Kbs
- [12:51:52] Reencoding: VID_00011, Pass 1 of 2
- [14:04:07] Reencoding: VID_00011, Pass 2 of 2
- [18:30:54] Video Encode complete
- [18:30:54] Reencoding audio tracks (if req'd)
- [18:30:54] Multiplexing M2TS
[18:43:43]PHASE ONE complete
[18:43:43]PHASE TWO - Rebuild Started
- [18:43:43] Rebuilding BD file Structure
[18:44:07] - Encode and Rebuild complete
[18:44:07] Writing BD structure to ISO file
- ImgBurn completed successfully
- WORKFILES folder removed.
[18:48:43]JOB: STAND_BY_ME finished.
@jdobbs here is the log you asked me to post. Encoded twice, one came out 11GB in size, and the other 7GB. It def seems like it's re-encoding the main movie so i'm not sure what's causing it to be so undersized.
Thanks in advance.
[SLiM]
[SLiM]D12 is offline   Reply With Quote
Old 23rd May 2011, 15:44   #12067  |  Link
jdobbs
Thanks in advance.
I'm looking at your log and the main feature is encoded at a bitrate of 23,952 Kbs. I also see that you are keep HD audio. A guess mght be that you are hitting the maximum combined bitrate. But that should add up to almost 16GB for the video alone...
Are you using all the exact versions that are linked in the first post of this thread?
Old 23rd May 2011, 15:49   #12068  |  Link
[SLiM]D12
@jdobbs
Ok let me try to change to 640 kbps and see what happens. Will post back with results.
[SLiM]
Old 23rd May 2011, 15:52   #12069  |  Link
Capsbackup
Just curious, not related to the suspect undersize, but the top of the log says:
The only file reencoded with 2-pass is the last one, with all the rest 1-pass.
Capsbackup is offline   Reply With Quote
Old 23rd May 2011, 15:58   #12070  |  Link
Capsbackup
@jdobbs
Lowering the audio to 640kbps will not increase the file size, but perhaps lower it. The suggestion is that the video bitrate is already very high, so giving the video more space by lowering the audio will not increase the file size since it is already maxed out.
Old 23rd May 2011, 16:10   #12071  |  Link
[SLiM]D12
But if I make the audio small enough, it can leave the video untouched and thus make it closer to the 25GB size I desire.
[SLiM]
Old 23rd May 2011, 16:12   #12072  |  Link
jdobbs
Probably "Quick Encode for Extras"
Old 23rd May 2011, 16:13   #12073  |  Link
jdobbs
I edited my response -- are you using the exact versions of the apps linked in the first post of this thread? Something is wrong because the bitrate and length of the main feature should add up to almost 16GB for that stream's video alone.
Old 23rd May 2011, 16:23   #12074  |  Link
Capsbackup
Awe yes, I forgot about that option. Thanks!
Old 23rd May 2011, 23:24   #12075  |  Link
[SLiM]D12
So selecting 640 audio got me to 15GB, but still quite a bit under. I confirmed i had the versions defined in this thread, but uninstalled and reinstalled to ensure and i'm trying again with HD Audio.
[SLiM]
Old 24th May 2011, 00:05   #12076  |  Link
jdobbs
I guess I'm going to have to run that disc to find out what's going on...
[Edit] Picked it up, will run tonight. Glad to find out this movie is now available in Blu-Ray -- one of my favorites.
Old 24th May 2011, 12:16   #12077  |  Link
[SLiM]D12
Awesome. I ran it again and got 17GB....getting closer
[SLiM]
Old 24th May 2011, 13:18   #12078  |  Link
RobertM
@jdobbs:
Is there any significance to the fact that VID_00105 (12 of 14) and VID_00011 (14 of 14) say "Reencoding secondary video [TRK_02]" instead of "Reencoding: VID_00### (## of 14)"?
Also, I noticed that VID_00106 (13 of 14) reencodes 66,135 frames in 3.1/2 minutes, or approx 300fps. That seems pretty fast.
@[slim]D12: Try turning OFF the option that clears the WORKFILES folder after the process completes, so you can see what actual files are used to create the BD file structure (and how big they are). Also, until you get this figured out, perhaps you should remove ImgBurn as a variable, and just evaluate the contents of the recreated BD folders.
RobertM is offline   Reply With Quote
Old 24th May 2011, 14:10   #12079  |  Link
jdobbs
Originally Posted by RobertM View Post
@jdobbs:
It's supposed to say "Secondary" -- because that stream has a secondary video stream (PiP).
300fps isn't unusual for a 720x480 stream. I get around 360fps on my dedicated video computer.
Old 24th May 2011, 18:09   #12080  |  Link
empty1
Failed Video encode
I have had a lot of good results with BD-RB, but recently I have been getting some errors. I tried version 37.07 and had errors so I downloaded 38.02 and got the same results. Here is the log:
[20:34:09] BD Rebuilder v0.37.07 (beta)
- Source: DRWHO_ENDOFTIME_PART2
- Input BD size: 41.62 GB
- Approximate total content: [03:19:44.013]
- Windows Version: 6.1 [7600]
- Auto Quality: Good (Very Fast), ABR
- Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640
[20:34:09] PHASE ONE, Encoding
- [20:34:09] Extracting A/V streams [VID_00123]
- [20:36:51] Reencoding: VID_00123 (1 of 4)
- [20:36:51] Collecting video information
- Source Video: VC-1, 1920x1080
- Rate/Length: 29.970fps, 31,078 frames
- [20:36:52] Reencoding: VID_00123, Pass 1 of 1
- [20:41:42] Video Encode complete
- [20:41:42] Reencoding audio tracks (if req'd)
- [20:41:42] Multiplexing M2TS
- [20:41:45] Extracting A/V streams [VID_00122]
- [20:45:59] Reencoding: VID_00122 (2 of 4)
- [20:45:59] Collecting video information
- Rate/Length: 29.970fps, 37,950 frames
- Bitrate: 18,690 Kbs
- [20:46:00] Reencoding: VID_00122, Pass 1 of 1
- [20:53:50] Video Encode complete
- [20:53:50] Reencoding audio tracks (if req'd)
- [20:53:50] Multiplexing M2TS
- [20:53:53] Extracting A/V streams [VID_00121]
- [21:05:26] Reencoding: VID_00121 (3 of 4)
- [21:05:27] Collecting video information
- Rate/Length: 29.970fps, 102,317 frames
- Bitrate: 20,604 Kbs
- [21:05:30] Reencoding: VID_00121, Pass 1 of 1
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.37.07 (beta)
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3326, Ok
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set incorrectly: [1]
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[21:08:44] - Failed video encode, aborted
[23:56:03] BD Rebuilder v0.38.02 (beta)
[23:56:05] PHASE ONE, Encoding
- [23:56:05] Extracting A/V streams [VID_00120]
- [00:12:56] Reencoding: VID_00120 (1 of 4)
- [00:12:56] Collecting video information
- Rate/Length: 29.970fps, 130,667 frames
- Bitrate: 14,936 Kbs
- [00:13:02] Reencoding: VID_00120, Pass 1 of 1
- BD-Rebuilder v0.38.02 (beta)
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[00:16:21] - Failed video encode, aborted
Am I missing something obvious?
empty1 is offline   Reply With Quote
