Old 22nd February 2025, 00:48   #32161  |  Link
Moviewatcher666
Originally Posted by MrVideo View Post
How can you not have the UPC if you have the original disc(s) and packaging.
When you asked for UPC, we were discussing the blu-ray player. I thought you wanted it for the blu-ray player.
UPC for Godzilla is 715515305112.
Moviewatcher666 is offline   Reply With Quote
Old 22nd February 2025, 00:52   #32162  |  Link
Moviewatcher666
I'm surprised that worked. I've sometimes swapped something out and the disc refused to play. You got lucky.
Looking at the info about this release, it has an English soundtrack, so why the worry about subtitles?
I wasn't hopeful but thought I would try it. Comparing the MPLS files, that was the only difference. Virtually identical.
Like I said, there was a flag that was not set properly and that was it.
English is the commentary track. This movie is not dubbed. Language is Japanese with English subtitles only.
Old 22nd February 2025, 08:56   #32163  |  Link
varekai
varekai's Avatar
Although the soundtrack is in English, but, if English is not your mother tongue and although you both understand, speak and write fairly well English, English subtitles are an excellent support, just sayin'...
varekai is offline   Reply With Quote
Old 22nd February 2025, 13:33   #32164  |  Link
lauguru
Originally Posted by lauguru View Post
hello!
What is the process of converting bd to uhd, how does the preset "quality" change to other better quality and less speed?
I get a 30gb bd, 17gb uhd, I have 24000 mb custom target installed
One problem, when I want to convert (Converting to UHD-BD (HEVC) output format), it always uses h264 to encode, having NVENC activated in full backup, How can I enable HEVC in that mode?
other problem in Archive backup/aac , No matter what size you set for custom target, it is always the same output MB size.
[Options]
VERSION=0.62.0.12
ENCODER=1
MODE=4
NEW_CRF_PREDICTION=1
MIN_M2TS_SIZE=0
MIN_PLAYLIST_MINS=0
REENCODE_MENUS=1
ARCHIVE_QUALITY=4
ARCHIVE_265=1
ARCHIVE_ENABLE=1
UHD_CONVERT_ENABLE=1
UHD_V3_MODE=1
ENCODE_QUALITY=4
ONEPASS_ENCODING=2
AUTO_QUALITY=0
NVENC_CAPABLE=1
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=0
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=24000
TARGET_SIZE=24000
[Paths]
WORKING_PATH=L:\TEST BDREBUILDER\
LASTCMD.TXT
BD_Rebuilder\tools\nvenc\nvencc.exe" --avhw  --fps 25 --interlace tff --vpp-deinterlace normal -i "E:\  (BLU-RAY)\BDMV\STREAM\00003.m2ts" --codec hevc --preset quality --qp-min 0 --multipass 2pass-full --vbr 0 --vbr-quality 23 --aq --aq-temporal --sar 1:1 --aud --pic-struct --vbv-bufsize 30000 --max-bitrate 35000 --lookahead 24 --no-b-adapt --gop-len 25 -o "L:\TEST BDREBUILDER\WORKFILES\VID_00003.AVS.hevc"
In the end I answer myself, I have managed to do the complete conversion from BD to UHD "full backup" with custom resize and with nvec encoder main 10 h265, recorded on disk and played on Xbox One perfectly. Where can I find the hidden commands that do not appear in HIDDENOPTS. TXT? I found these commands by reading you
UHD_V3_MODE=1
UHD_ALL_MODE=1
[Options]
VERSION=0.62.0.12
ENCODER=1
MODE=0
ARCHIVE_LIMIT=0
ARCHIVE_265=1
ARCHIVE_ENABLE=1
ARCHIVE_QUALITY=4
UHD_V3_MODE=1
UHD_ALL_MODE=1
ENCODE_QUALITY=4
REENCODE_MENUS=0
ONEPASS_ENCODING=1
AUTO_QUALITY=0
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=1
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=0
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=25325
NVENC_CAPABLE=1
TARGET_SIZE=24000
WIDE_PERCENT=40
WIDE_OFFSET=.85
MOVIEONLY_TYPE=40
ALTCRF=23
ALT_TARGET=1024
ALT_CRF_TARGET=190
ALTMETHOD=3
ALTAUTOCROP=0
[Paths]
SOURCE_PATH=F:\
lauguru is offline   Reply With Quote
Old 23rd February 2025, 17:04   #32165  |  Link
SquallMX
Special SeeD
Text
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Your problem is similar to my problem, BD-Rebuilder is not using proper values for subtitles in the output disc.
According to your logs your subtitle track is in "1200" but UHD Blu-ray specs for HDR video requires subtitle track in "12A0". Because of this your player does not "see" your subtitle track.
SquallMX is offline   Reply With Quote
Old 23rd February 2025, 17:39   #32166  |  Link
jdobbs
Originally Posted by SquallMX View Post
Text
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Maybe you should reread what he posted:
So, I decided to compare the MPLS playlist file from the original disc to the MPLS playlist created by BDR.
Under this section:
"number_of_PiP_PG_textST_stream_entries_plus": 0,
there was this entry from the original disc:
"type": 1,
"pid": 4608,
"stream_coding_type": "PGS",
"language_code": "eng",
"reserved01": 0
Under the same section in the BDR created playlist, the entry was this:
"type": 1,
"pid": 4768,
"reserved01": 0
The "ORIGINAL DISC" was using 0x1200 (4608)...
Since the original was 4K -- it would lead one to believe that the original was improperly authored?
jdobbs softworks
Old 23rd February 2025, 20:26   #32167  |  Link
SquallMX
Special SeeD
Maybe you should reread what he posted:The "ORIGINAL DISC" was using 0x1200 (4608)...
Hi, very weird indeed if that is the case, but we can agree that a subtitle placed at 1200 for HDR video would no be show in a proper UHD player.
I'm currently having the inverse situation, original BR is using 1200 for subtitles in a SDR H265 playlist but BD-Rebuilder is using 12X0, resulting in missing subtitles when playing on my hardware player. Using BDEdit to manually correct the values works fine.
Old 23rd February 2025, 23:11   #32168  |  Link
jdobbs
An SDR H265 playlist? I haven't looked in a while, and I'll have to go back and check... but I didn't think H265 was allowed for SD content. I may be wrong, though. I know it works, as I have a switch that allows it, but for some reason I thought it had to be H264.
jdobbs softworks
Old 24th February 2025, 02:59   #32169  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
From BD-ROM V3.2 UHD Format Specs 2018:
Table 3-6 lists all 6 combos of HDMV HEVC resolution, transfer_characteristics and bitdepth:
10-bit SDR is legal in FHD and UHD as primaries BT-709 and BT.2020 with with transfer_characteristics 1 resp. 14
10-bit BDMV HDR is legal in FHD and UHD as primaries BT.2020 with transfer_characteristics 16 (ST 2084)
Framerates 23.976p,24.000p,25.000p,50.000p,59.940p,60.000p. No 29.97p, no 30.000p, no interlaced !
8-bit: only AVC, only BT.709, only FHD, only 23.976p and 24.000p, no interlaced !
Emulgator is online now   Reply With Quote
Old 24th February 2025, 15:00   #32170  |  Link
jdobbs
jdobbs softworks
Old 4th March 2025, 14:51   #32171  |  Link
MrVideo
MrVideo's Avatar
I am playing with a full backup of the new Godzilla Criterion 4K release.
I downloaded a copy of the release in order to do a test. Well, that was a bust, because the main movie refused to recode. I get a PredictAndEncode error.
Oh well.
Old 4th March 2025, 16:07   #32172  |  Link
jdobbs
Oh well.
What error was it? PredictAndEncode just tells me what routine it was in. The numbers tell me the error number and where it happened.
jdobbs softworks
Old 6th March 2025, 21:59   #32173  |  Link
MrVideo
MrVideo's Avatar
I'll have to redownload the movie and get back to you.
Old 7th March 2025, 16:03   #32174  |  Link
MrVideo
MrVideo's Avatar
OK, rework of the Godzilla title was interesting. This time around, the title did not fail encoding. What did catch my eye was that the config file was set for 45+ GB as the target. But, in the end, it was only 37 GB. That was a big miss. As originally reported, the subtitles were not seen. The subtitle playback was set to on at movie start. So, the bug is confirmed.
Here is the log:
[07:48:39] PHASE ONE, Encoding
 - [07:48:39] Processing: VID_00005 (3 of 3)
 - [07:48:39] Reencoding video [VID_00005]
 - [07:48:40] PredictAndEncode() 00070  2810
[07:48:49] - Aborted by user request
[03/06/25] BD Rebuilder v0.62.12
[22:47:04] Source:  GOJIRA_AKA_GODZILLA_1954_CRITERION_2160P_USA_UHD_BLU-RAY_HEVC_LPCM_1.0-HORROR
  - Input BD size: 67.21 GB
  - Approximate total content: [01:37:41.855]
  - Target BD size: 45.90 GB
  - Windows Version: 6.1 [7601]
  - Quality: High Quality (Default), CQM
  - UHD-BD source detected.
  - Decoding/Frame serving: NVENCC
[22:47:06] PHASE ONE, Encoding
 - [22:47:06] Processing: VID_00009 (1 of 3)
 - [22:47:06] Extracting A/V streams [VID_00009]
 - [22:47:11] Reencoding video [VID_00009]
   - Track 4353 (eng): Keeping original audio
 - [22:47:21] Processing: VID_00007 (2 of 3)
 - [22:47:21] Extracting A/V streams [VID_00007]
 - [22:47:26] Reencoding video [VID_00007]
   - Track 4352 (min): Keeping original audio
 - [22:47:36] Processing: VID_00005 (3 of 3)
 - [22:47:36] Extracting A/V streams [VID_00005]
 - [22:59:17] Reencoding video [VID_00005]
   - Analyzing 1.00 [1.00]
   - Track 4352 (jpn): Keeping original audio
[23:40:50]PHASE ONE complete
[23:40:50]PHASE TWO - Rebuild Started
 - [23:40:50] Rebuilding BD file Structure
[23:40:55] - Encode and Rebuild complete
[23:40:55] Writing BD structure to ISO file
 - ImgBurn completed successfully
[23:51:34] JOB: GOJIRA_AKA_GODZILLA_1954_CRITERION_2160P_USA_UHD_BLU-RAY_HEVC_LPCM_1.0-HORROR finished.
And yes, the original failure code is also there. I wasn't expecting it. Usually when I see those error dialogs show up, they don't normally appear in the log. At least this time it was, since it did fail this time around.
Old 7th March 2025, 16:34   #32175  |  Link
jdobbs
Here is the log:
The sizing isn't an issue. That's just as large as it could make it using CQM -- you'll note that the CQM value used was 1 -- that's the highest quality possible -- meaning it is pretty much identical to the original. To me that just means that a ridiculously high bitrate was used on the original.
I'll have to look at the subtitle problem... probably an issue with the PID.
The error you got (00070) was "permission denied". I'm guessing that for some reason the operating system thought a file BD-RB was trying to access was open or in use.
jdobbs softworks
Old 7th March 2025, 23:37   #32176  |  Link
MrVideo
MrVideo's Avatar
According to MediaInfo: 92.4
Strange.
Old 8th March 2025, 01:52   #32177  |  Link
CV91913
Where are you downloading from. Are you sure the download isn't corrupt?
CV91913 is offline   Reply With Quote
Old 8th March 2025, 08:51   #32178  |  Link
MrVideo
MrVideo's Avatar
Yes. Corrupt downloads will fail.
Old 17th April 2025, 12:09   #32179  |  Link
thebuff
Failed in attempt to multiplex
Wondered if someone could help - attempting to backup Nosferatu (2024) and it's failing. It actually failed quite a few times during the process with error code "PredictAndEncode() 00075 2809" - I've tried restarting from scratch, but had the same outcome.
I then tried resuming from the previous job each time it failed, which felt like it was working; it eventually got up to the 100% but failed to rebuild with error code "TSMUXER ERR: 0xFFFFFFFE - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta"
It's one of those movies/discs that has multiple parts, rather than just one m2ts file - not sure if this is the issue, but I've not had this problem before.
Log is below - any help would be greatly appreciated;
- Input BD size: 28.23 GB
- Approximate total content: [02:12:35.697]
- Windows Version: 6.2 [9200]
- Quality: High Quality (Default), 1-Pass VBR
- Audio Settings: AC3=1 DTS=0 HD=0 Kbs=640
[23:35:58] PHASE ONE, Encoding
- [23:35:58] Processing: VID_00820 (1 of 16)
- [23:35:58] Extracting A/V streams [VID_00820]
- [23:36:14] Reencoding video [VID_00820]
- Rate/Length: 23.976fps, 25,822 frames
- Bitrate: 10,366 Kbs
- [23:49:23] Video Encode complete
- Track 4352 (eng): Reencoding audio to AC3...
- Track 4353 (eng): Reencoding audio to AC3...
- Track 4354 (eng): Reencoding audio to AC3...
- [23:50:35] Processing: VID_00810 (2 of 16)
- [23:50:35] Extracting A/V streams [VID_00810]
- [23:50:40] Reencoding video [VID_00810]
- Rate/Length: 23.976fps, 2,269 frames
- Bitrate: 10,306 Kbs
- [23:50:40] Reencoding: VID_00810, Pass 1 of 1
- [23:51:52] Video Encode complete
- [23:51:52] Processing: VID_00822 (3 of 16)
- [23:51:52] Extracting A/V streams [VID_00822]
- [23:51:56] Reencoding video [VID_00822]
- Bitrate: 10,560 Kbs
- [23:54:11] Video Encode complete
- [23:54:11] Extracting A/V streams [VID_00811]
- [23:54:15] Reencoding video [VID_00811]
- Rate/Length: 23.976fps, 649 frames
- Bitrate: 10,237 Kbs
- [23:54:15] Reencoding: VID_00811, Pass 1 of 1
- [23:54:36] Video Encode complete
- [23:54:36] Processing: VID_00823 (5 of 16)
- [23:54:36] Extracting A/V streams [VID_00823]
- [23:54:42] Reencoding video [VID_00823]
- Rate/Length: 23.976fps, 12,753 frames
- [23:54:42] Reencoding: VID_00823, Pass 1 of 1
- [00:02:02] Video Encode complete
- [00:02:02] Extracting A/V streams [VID_00812]
- [00:02:06] Reencoding video [VID_00812]
- Bitrate: 10,233 Kbs
- [00:03:24] Video Encode complete
- [00:03:24] Processing: VID_00824 (7 of 16)
- [00:03:24] Extracting A/V streams [VID_00824]
- [00:03:34] Reencoding video [VID_00824]
- Rate/Length: 23.976fps, 53,912 frames
- Bitrate: 10,528 Kbs
- [00:03:34] Reencoding: VID_00824, Pass 1 of 1
- [00:34:31] Video Encode complete
- [00:34:31] Extracting A/V streams [VID_00813]
- [00:34:36] Reencoding video [VID_00813]
- Rate/Length: 23.976fps, 1,720 frames
- [00:34:36] Reencoding: VID_00813, Pass 1 of 1
- [00:35:31] Video Encode complete
- [00:35:31] Extracting A/V streams [VID_00826]
- [00:35:36] Reencoding video [VID_00826]
- Rate/Length: 23.976fps, 14,018 frames
- Bitrate: 10,425 Kbs
- [00:35:36] Reencoding: VID_00826, Pass 1 of 1
- [00:43:27] Video Encode complete
- [00:43:27] Processing: VID_00814 (10 of 16)
- [00:43:31] Reencoding video [VID_00814]
- Rate/Length: 23.976fps, 766 frames
- [00:43:31] Reencoding: VID_00814, Pass 1 of 1
- [00:43:54] Video Encode complete
- [00:43:54] Processing: VID_00827 (11 of 16)
- [00:44:00] Reencoding video [VID_00827]
- Rate/Length: 23.976fps, 19,203 frames
- Bitrate: 10,298 Kbs
- [00:44:00] Reencoding: VID_00827, Pass 1 of 1
- [00:54:43] Video Encode complete
- [00:54:43] PredictAndEncode() 00075 2809
- Resuming from previously started job.
[09:23:23] PHASE ONE, Encoding
- [09:23:23] Processing: VID_00822 (3 of 16)
- [09:23:23] Extracting A/V streams [VID_00822]
- [09:23:27] Reencoding video [VID_00822]
- Rate/Length: 23.976fps, 3,758 frames
- [09:23:27] Reencoding: VID_00822, Pass 1 of 1
- [09:25:31] Video Encode complete
- [09:25:31] Extracting A/V streams [VID_00811]
- [09:25:35] Reencoding video [VID_00811]
- [09:25:56] Video Encode complete
- [09:25:56] Processing: VID_00823 (5 of 16)
- [09:25:56] Extracting A/V streams [VID_00823]
- [09:26:01] Reencoding video [VID_00823]
- Bitrate: 10,461 Kbs
- [09:26:02] Reencoding: VID_00823, Pass 1 of 1
- [09:33:21] Video Encode complete
- [09:33:21] Extracting A/V streams [VID_00812]
- [09:33:25] Reencoding video [VID_00812]
- Rate/Length: 23.976fps, 2,070 frames
- [09:33:25] Reencoding: VID_00812, Pass 1 of 1
- [09:34:43] Video Encode complete
- [09:34:43] PredictAndEncode() 00075 2809
- Target BD size: 11.72 GB
- MOVIE-ONLY mode enabled
- Decoding/Frame serving: DirectShow
[09:35:24] PHASE ONE, Encoding
- [09:35:24] Processing: VID_00812 (6 of 16)
- [09:35:24] Extracting A/V streams [VID_00812]
- [09:35:27] Reencoding video [VID_00812]
- [09:35:28] Reencoding: VID_00812, Pass 1 of 1
- [09:36:37] Video Encode complete
- [09:36:37] PredictAndEncode() 00075 2809
[09:37:04] PHASE ONE, Encoding
- [09:37:05] Processing: VID_00824 (7 of 16)
- [09:37:05] Extracting A/V streams [VID_00824]
- [09:37:14] Reencoding video [VID_00824]
- [09:37:14] Reencoding: VID_00824, Pass 1 of 1
- [10:08:08] Video Encode complete
- [10:08:08] Processing: VID_00813 (8 of 16)
- [10:08:08] Extracting A/V streams [VID_00813]
- [10:08:12] Reencoding video [VID_00813]
- [10:09:07] Video Encode complete
- [10:09:07] PredictAndEncode() 00075 2809
[10:23:35] Source: NOSFERATU_UPB1_00000
[10:23:39] PHASE ONE, Encoding
- [10:23:39] Processing: VID_00813 (8 of 16)
- [10:23:43] Reencoding video [VID_00813]
- [10:23:43] Reencoding: VID_00813, Pass 1 of 1
- [10:24:28] Video Encode complete
- [10:24:28] PredictAndEncode() 00075 2809
[10:42:52] Source: NOSFERATU_UPB1_00000
[10:42:54] PHASE ONE, Encoding
- [10:42:54] Processing: VID_00826 (9 of 16)
- [10:42:54] Extracting A/V streams [VID_00826]
- [10:42:59] Reencoding video [VID_00826]
- [10:50:42] Video Encode complete
- [10:50:42] Processing: VID_00814 (10 of 16)
- [10:50:42] Extracting A/V streams [VID_00814]
- [10:50:45] Reencoding video [VID_00814]
- Bitrate: 10,209 Kbs
- [10:50:45] Reencoding: VID_00814, Pass 1 of 1
- [10:51:08] Video Encode complete
- [10:51:08] Extracting A/V streams [VID_00827]
- [10:51:14] Reencoding video [VID_00827]
- [10:51:14] Reencoding: VID_00827, Pass 1 of 1
- [11:01:58] Video Encode complete
- [11:01:58] Processing: VID_00815 (12 of 16)
- [11:01:58] Extracting A/V streams [VID_00815]
- [11:02:02] Reencoding video [VID_00815]
- Rate/Length: 23.976fps, 4,041 frames
- Bitrate: 10,201 Kbs
- [11:02:02] Reencoding: VID_00815, Pass 1 of 1
- [11:04:18] Video Encode complete
- [11:04:18] PredictAndEncode() 00075 2809
[11:04:34] PHASE ONE, Encoding
- [11:04:34] Processing: VID_00828 (13 of 16)
- [11:04:34] Extracting A/V streams [VID_00828]
- [11:04:39] Reencoding video [VID_00828]
- Rate/Length: 23.976fps, 9,387 frames
- [11:04:39] Reencoding: VID_00828, Pass 1 of 1
- [11:09:51] Video Encode complete
- [11:09:51] Extracting A/V streams [VID_00816]
- [11:09:55] Reencoding video [VID_00816]
- Bitrate: 10,271 Kbs
- [11:10:31] Video Encode complete
- [11:10:31] Processing: VID_00829 (15 of 16)
- [11:10:31] Extracting A/V streams [VID_00829]
- [11:10:38] Reencoding video [VID_00829]
- Rate/Length: 23.976fps, 29,418 frames
- Bitrate: 10,436 Kbs
- [11:10:38] Reencoding: VID_00829, Pass 1 of 1
- [11:27:08] Video Encode complete
- [11:27:08] Processing: VID_00817 (16 of 16)
- [11:27:08] Extracting A/V streams [VID_00817]
- [11:27:13] Reencoding video [VID_00817]
- Rate/Length: 23.976fps, 9,892 frames
- Bitrate: 10,151 Kbs
- [11:27:13] Reencoding: VID_00817, Pass 1 of 1
- [11:29:09] Video Encode complete
[11:29:09]PHASE ONE complete
[11:29:09]PHASE TWO - Rebuild Started
- [11:29:09] Rebuilding BD file Structure
- TSMUXER ERR: 0xFFFFFFFE
[11:29:13] - Failed to REBUILD
[11:29:53] Source: NOSFERATU_UPB1_00000
[11:29:55] PHASE ONE, Encoding
[11:29:55]PHASE ONE complete
- [11:29:55] Rebuilding BD file Structure
thebuff is offline   Reply With Quote
Old 17th April 2025, 13:20   #32180  |  Link
jdobbs
That error code (75) means "Path/File access error". You may want to check the path to your working or source folder(s) and see if it has some unusual characters, or if it is exceptionally long.
jdobbs softworks
