#32021 | Link | |
![]() Join Date: Oct 2001
The real question here is why was the audio out of sync the first time you tried it? What kind of audio was it? Last edited by jdobbs; 6th October 2024 at 16:17. |
#32023 | Link | |
General Unique ID : 285951807814491606971365394848124601680 (0xD720509F64DCD036067E8C51CF458550) Complete name : E:\the.lord.of.the.rings.the.rings.of.power.s02e07.doomed.to.die.720p.amzn.web-dl.ddp5.1.atmos.h.264-flux.mkv Format : Matroska Format version : Version 4 File size : 1.46 GiB Duration : 1 h 12 min Overall bit rate : 2 900 kb/s Frame rate : 24.000 FPS Writing application : mkvmerge v85.0 ('Shame For You') 64-bit Writing library : libebml v1.4.5 + libmatroska v1.7.1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 12 min Bit rate mode : Constant Bit rate : 2 319 kb/s Nominal bit rate : 4 000 kb/s Width : 1 248 pixels Height : 520 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 24.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.149 Stream size : 1.17 GiB (80%) Language : English (US) Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : E-AC-3 JOC Format/Info : Enhanced AC-3 with Joint Object Coding Commercial name : Dolby Digital Plus with Dolby Atmos Codec ID : A_EAC3 Duration : 1 h 12 min Bit rate mode : Constant Bit rate : 576 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 298 MiB (20%) Language : English (US) Service kind : Complete Main Default : Yes Forced : No Complexity index : 16 Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE Dialog Normalization : -22 dB compr : -0.28 dB dialnorm_Average : -22 dB dialnorm_Minimum : -22 dB dialnorm_Maximum : -22 dB Text #1 ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 6 min Bit rate : 1 b/s Frame rate : 0.009 FPS Count of elements : 34 Stream size : 675 Bytes (0%) Title : Forced Language : English (US) Default : Yes Forced : Yes Text #2 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 7 min Bit rate : 29 b/s Frame rate : 0.126 FPS Count of elements : 508 Stream size : 14.6 KiB (0%) Language : English (US) Default : No Forced : No Text #3 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 7 min Bit rate : 37 b/s Frame rate : 0.179 FPS Count of elements : 724 Stream size : 18.5 KiB (0%) Title : SDH Language : English (US) Default : No Forced : No Menu 00:00:00.000 : en:Studio Logo 00:00:06.000 : en:Previously On 00:01:53.000 : en:Scene 1 00:02:05.000 : en:Scene 2 00:03:51.000 : en:Scene 3 00:06:07.000 : en:Scene 4 00:06:28.000 : en:Scene 5 00:06:47.000 : en:Scene 6 00:07:15.000 : en:Scene 7 00:07:58.000 : en:Scene 8 00:08:02.000 : en:Scene 9 00:08:11.000 : en:Scene 10 00:08:26.000 : en:Scene 11 00:08:45.000 : en:Scene 12 00:08:52.000 : en:Scene 13 00:08:56.000 : en:Scene 14 00:09:03.000 : en:Scene 15 00:09:14.000 : en:Scene 16 00:09:19.000 : en:Scene 17 00:09:42.000 : en:Scene 18 00:09:56.000 : en:Scene 19 00:10:06.000 : en:Scene 20 00:10:11.000 : en:Scene 21 00:10:13.000 : en:Scene 22 00:10:16.000 : en:Scene 23 00:10:41.000 : en:Scene 24 00:10:50.000 : en:Scene 25 00:11:31.000 : en:Scene 26 00:11:33.000 : en:Scene 27 00:12:31.000 : en:Scene 28 00:12:38.000 : en:Scene 29 00:14:13.000 : en:Scene 30 00:14:39.000 : en:Scene 31 00:14:42.000 : en:Scene 32 00:15:17.000 : en:Scene 33 00:15:29.000 : en:Scene 34 00:15:54.000 : en:Scene 35 00:18:23.000 : en:Scene 36 00:18:31.000 : en:Scene 37 00:18:38.000 : en:Scene 38 00:20:38.000 : en:Scene 39 00:21:56.000 : en:Scene 40 00:22:01.000 : en:Scene 41 00:22:17.000 : en:Scene 42 00:23:33.000 : en:Scene 43 00:24:18.000 : en:Scene 44 00:24:20.000 : en:Scene 45 00:24:27.000 : en:Scene 46 00:24:35.000 : en:Scene 47 00:24:56.000 : en:Scene 48 00:25:08.000 : en:Scene 49 00:25:24.000 : en:Scene 50 00:25:31.000 : en:Scene 51 00:25:34.000 : en:Scene 52 00:25:40.000 : en:Scene 53 00:25:58.000 : en:Scene 54 00:26:07.000 : en:Scene 55 00:26:50.000 : en:Scene 56 00:30:11.000 : en:Scene 57 00:31:08.000 : en:Scene 58 00:31:48.000 : en:Scene 59 00:32:12.000 : en:Scene 60 00:32:27.000 : en:Scene 61 00:32:33.000 : en:Scene 62 00:32:50.000 : en:Scene 63 00:32:57.000 : en:Scene 64 00:33:07.000 : en:Scene 65 00:33:12.000 : en:Scene 66 00:33:29.000 : en:Scene 67 00:34:53.000 : en:Scene 68 00:36:23.000 : en:Scene 69 00:36:47.000 : en:Scene 70 00:37:05.000 : en:Scene 71 00:37:11.000 : en:Scene 72 00:38:06.000 : en:Scene 73 00:38:36.000 : en:Scene 74 00:39:47.000 : en:Scene 75 00:40:24.000 : en:Scene 76 00:40:51.000 : en:Scene 77 00:41:55.000 : en:Scene 78 00:42:02.000 : en:Scene 79 00:42:14.000 : en:Scene 80 00:43:03.000 : en:Scene 81 00:46:10.000 : en:Scene 82 00:46:36.000 : en:Scene 83 00:47:08.000 : en:Scene 84 00:49:10.000 : en:Scene 85 00:49:40.000 : en:Scene 86 00:53:08.000 : en:Scene 87 00:53:25.000 : en:Scene 88 00:54:16.000 : en:Scene 89 00:55:10.000 : en:Scene 90 00:55:54.000 : en:Scene 91 00:56:16.000 : en:Scene 92 00:56:46.000 : en:Scene 93 00:57:06.000 : en:Scene 94 00:57:11.000 : en:Scene 95 00:57:13.000 : en:Scene 96 00:57:17.000 : en:Scene 97 00:58:58.000 : en:Scene 98 00:59:08.000 : en:Scene 99 00:59:47.000 : en:Scene 100 00:59:59.000 : en:Scene 101 01:01:15.000 : en:Scene 102 01:02:11.000 : en:Scene 103 01:02:37.000 : en:Scene 104 01:03:03.000 : en:Scene 105 01:03:11.000 : en:Scene 106 01:03:21.000 : en:Scene 107 01:03:25.000 : en:Scene 108 01:03:35.000 : en:Scene 109 01:03:40.000 : en:Scene 110 01:04:15.000 : en:Scene 111 01:04:24.000 : en:Scene 112 01:04:51.000 : en:Scene 113 01:05:05.000 : en:Scene 114 01:05:08.000 : en:Scene 115 01:05:16.000 : en:Scene 116 01:06:00.000 : en:Scene 117 01:06:27.000 : en:Scene 118 01:07:36.000 : en:End Credits Last edited by musiclover; 11th October 2024 at 12:52. |
#32024 | Link | |
In the same vein, flac is a popular anime sub release format, since a lot of sources are Japanese with LPCM. |
#32025 | Link |
Trying to IVTC some Pokemon DVDs and am getting combing artifacts. Tried to add FieldDeinterlace as added AVS script, but anything added is placed before the plugins being loaded and the IVTC. Is there a reason for this?
Then tried to compare the results using just the default program deinterlace. Hidden options says that default is SmoothDeinterlace, and no field blending, but the workfiles script shows deinterlacing defaults to FieldDeinterlace with blend=true. Last edited by iambryanknowles; 17th October 2024 at 09:50. |
#32026 | Link | |
I kept going back to my project of making episode blu-rays of 24 FPS files. I found out that the length of the imported files in the pseudo bluray is 4 or 5 seconds longer than the original files. That never happens with PAL or NTSC 23,976 of 29,97 episodes. With the use of ''IMPORT_FORCE_FRAMERATE=24'' the length of the episodes stays the same. Last edited by musiclover; 19th October 2024 at 08:54. |
#32027 | Link |
I wasn't aware of the ''IMPORT_FORCE_FRAMERATE=24'' option. Nice! Guess it's time to download the latest build. That will come in handy. Will eliminate the extra step I'm taking now when encoding menu background videos that are in 24fps.
#32028 | Link | |
There are other reasons that could be causing the issue. You need to supply us with the technical info regarding the DVD. |
#32029 | Link |
TSMUXER ERR: 0xFFFFFFFE and a too large AV frame
I tried to make a blu-ray small enough for a 25gb disc by blanking half the content. But there was a pop-up with this content: ----------------------------------------------------------------- Audio Detection Mismatch The audio type for PID 1102 determined by reading the PAD/PMT program information (DTS HDMA) does not match the detected audio (AAC). In many cases, this is caused by emulation of audio headers (false detection) and the PAT/PMT type is the correct type. Hit Yes to use the PAT/PMT type. Hit No to use the detected type. Hit Cancel to disable this stream. YES NO CANCEL ----------------------------------------------------------------- The log mentions a TSMUXER ERR: 0xFFFFFFFE and a too large AV frame. ----------------------------------------------------------------- [11.03.24] BD Rebuilder v0.62.12 [21.44.05] Source: DISC-1_-_CAMEL___MIRAGE - Input BD size: 22,43 GB - Approximate total content: [02:47:34.794] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - Auto Quality: Very Good (Very Fast), 1-Pass VBR - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [21.44.07] PHASE ONE, Encoding - [21.44.07] Processing: VID_00000 (1 of 9) - [21.44.07] Extracting A/V streams [VID_00000] - TSMUXER ERR: 0xFFFFFFFE - Extracting video streams [VID_00000] - Extracting audio/subtitle streams [VID_00000] - TSMUXER ERR: 0xFFFFFFFE - AV frame too large (57600 bytes). Increase AV buffer. - Extracting audio streams [VID_00000] - TSMUXER ERR: 0xFFFFFFFE - Error in attempt to extract audio. - AV frame too large (57600 bytes). Increase AV buffer. - AV frame too large (57600 bytes). Increase AV buffer. [21.44.56] - Failed to retrieve audio, aborted ----------------------------------------------------------------- This happens when I hit Yes, but also when I hit No. So I think the real culprit is the AV frame. Is there anything to be done? How to increase the AV buffer? Last edited by musiclover; 3rd November 2024 at 22:32. |
#32033 | Link |
Big Bit Savings Now !
Maybe you hit a tsMuxeR demux limitation, or BD-R misinterprets a stream as being AAC.
(as blu-ray cannot have AAC audio) You may want to demux the assets using DGDemux and work from there.
#32034 | Link |
Thank you all for contributing. But after a re-rip all is well. What a nuisance a faulty rip can be. By the way.... Can the AV buffer in TSMUXER be increased? Last edited by musiclover; 8th November 2024 at 20:10. |
#32035 | Link |
Just reporting a minor bug.
After BD Rebuilder reports an audio/PGS sizing issue and choosing to continue the log window stops reporting the progress of the remainder of the job. The log itself keeps filling up but it is not visible in the log window. Last edited by musiclover; 8th November 2024 at 13:57. |
#32036 | Link |
Not sure if it's the same for other sources, but when importing PAL MKVs with Pal to Film set, chapters aren't adjusted to fit the new timing. Not sure how else to do it, but MKVToolnix GUI allows you to set a stretch parameter in the options setting of chapter files - assuming it works in the CLI too - just in case you're not sure of a way to do it.
Also, it would be nice if when both Convert SD to 1080 and Convert 1920x1080 to 1440x1080 were selected, that the output was 1440x1080 - right now it only upconverts to 1920x1080 and ignores the other option. |
#32037 | Link | ||
#32038 | Link |
PAL to FILM is in BDRB hidden options.It's just to slow down 25fps to 23.976 so that it plays back smoothly on a 120hz screen. I've never tried to play 25fps on my Blu-ray player before- I'm assuming it would have to add frames to pad the video to play back at a standard 29.97 which would disrupt smooth camera panning.
I was given 500 single layer DVD+Rs so I've been playing around a lot - squeezing to 1440x1080 with sar 4:3 reduces number of encoded pixels by 1/4 - on a DVD-5 that gives better overall quality than encoding the same thing at full 1920x1080. I mentioned SD to 1080, but I more often use the 720 to 1080 option for 29.97fps videos since encoding to 720p requires doubling the frames encoding at 59.94fps to be compliant. |
#32039 | Link | |||
I store all these videos on HDDs, not DVDs or BDs. Fine print: YMMV
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 11th November 2024 at 10:41. |
#32040 | Link | |
