#31901 | Link | |
That said, I'm confused as to why you would want to convert a smaller video file into a larger video file. Is the wrapper for the new file going to be MKV? If not, what? If it is going to be a MKV file, then don't use BDRB, instead use the standalone encoder. That is assuming you have a compatible nVidia or Intel GPU. The whole process will then be quick and easy. |
#31903 | Link | |
No, I don't want to create a larger file, but my OPPO will not play HEVC files, so since I archive everything to playable disc I need to convert to x264 with the correct parameters. It's so funny how I can never tell how big a file is going to come out (unless I do a sample and extrapolate on that of course) But, sometimes I can take a full on UHD file at like 50+ Gigs and use a fairly high CRF value (high as in low) and I'll be surprised at how small the resulting playable Blu-ray is. Then, I can take a small file like this and use basically the same CRF, and the file goes from around 3 Gigs to like 15! ![]() |
#31904 | Link | ||
Here is an example. Quote:
Use the standalone program that comes with the BDRB release to recode the H265 videos to H264. Of coursse the use of this program requires a compatible nVidia or Intel GPU. If so, you can select H.264 and the quality or bitrate. It is a one-stop shop for re-encoding videos. If you don't have a compatible GPU, then I'm afraid that I can't be of help, as I do not use BDRB for any kind of archiving, other than building UHD discs w/ menus. |
#31905 | Link | |
Thank you! ![]() |
#31907 | Link |
![]() Join Date: Oct 2001
My experience has been that they are of equivalent quality at a given bitrate. I can't say for sure if that holds true when you are forced to use low bitrates, as I haven't tested that. But definitely when using constant quality encodes you see similar quality at similar output sizes.
jdobbs softworks Last edited by jdobbs; 27th July 2024 at 15:49. |
#31908 | Link | |
#31915 | Link |
Hello everyone,
First time poster here, so I hope it’s okay to ask this right here. I’m testing the newly available Decoding/Frame serving: QSVENCC option in BD Rebuilder v0.62.06 with my Intel Iris Plus Graphics GPU on my Intel Core i7 – 1065G7 system. It works really well and super-fast at reencoding MPEG-4 (AVC), 1920x1080 HD video source, but fails when encountering VC-1, 1920x1080 HD video source. It also fails when encountering MPEG-4 (AVC), 720x480 SD video source within the BD structure. Needless to say, the reencoding works fine for all SD or HD video sources when using Decoding/Frame serving: DirectShow. I’m thinking there’s probably a setting(s) that needs to be changed so that Intel QuickSync can work properly on my system when using BD Rebuilder. Also, everything looks fine here: [08/02/24] Checking System Settings - BD-Rebuilder v0.62.06 - Windows Version: 6.2 [9200] - Working Path Free Space: 857.07GB - AVISYNTH Version: 2.6.0.6, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 4504, Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [08/02/24] Systems Settings Check complete Hoping someone can help. Thanks in advance. Last edited by Intel Iris the Great; 3rd August 2024 at 02:06. |
#31916 | Link | |
jdobbs softworks |
#31918 | Link | |
But, if you need smaller file sizes then many use 20-22 or so. Personally, I wouldn't go higher than that. I hope that helps! |
#31919 | Link | |
