#31861 | Link | |
#31862 | Link | |
This happens when I import from an MKV movie Last edited by Blurayhd; 15th July 2024 at 19:17. |
#31865 | Link | |
[13:14:29] Importing MKV: SISU.2022.BDREMUX.1080P.H.264-LMHD - Collecting audio/video streams from source... - Converting audio, Track #3, THD to AC3... |
#31868 | Link |
![]() Join Date: Oct 2001
That setting is for deinterlacing -- not IVTC. There are also hidden settings for IVTC:
IMPORT_NO_PULLDOWN=n n = 0/1 - Default=0, if set to 1, removes pulldown flags (IVTC) during import of MPEG2/DVD IVTC_1080i=n n = 0/1 - Default=0, 1=Perform IVTC on all 1080i sources (careful -- sometimes a bad idea) IVTC_1080p=n n = 0/1 - Default=0, 1=Perform IVTC on all 1080p 29.97fps sources (careful) IVTC_480i=n n = 0/1 - Default=0, 1=Perform IVTC on all 480i sources (careful -- sometimes a bad idea) IVTC_METHOD=n n = 0/1 = Default=1, 1=Use TIVTC for IVTC, 0=Use DECOMB for IVTC, IVTC_SELECTION=n n = 0/1 - Default=0, 1=Enables IVTC on dropdown menu, normally for hard telecined sources IVTC_TELECIDE=n n = 0/1 - Default=1, 1=Use IVTC_METHOD for Inverse telecining (IVTC) never uses direct IVTC SD_PROGRESSIVE=n n = 0/1 - 1=ON (default). Keeps IVTC'd 480i sources as 480p. "0" inserts pulldown flags.
jdobbs softworks Last edited by jdobbs; 16th July 2024 at 15:40. |
#31869 | Link |
Ahh! Gotchya. Maybe this should have been mentioned earlier so that Lathe could have used one, or more, of those settings. Specifically:
IMPORT_NO_PULLDOWN=1 IVTC_SELECTION=1 IVTC_480i=1 IVTC_1080i=1 |
#31870 | Link | |
Still, FWIW, just adding the AVS line seemed to do it perfectly, but I sure don't understand all the ins and outs of it... |
#31871 | Link |
Oh, BTW... Does BDRB do HDR-SDR conversion? I'm currently using CleverFFmpeg since it seems to use some sort of 'Mobius' thing and the colours come out better than using Handbrake's colour BT709 colour filter.
I'd be going of course from UHD to HD also. |
#31879 | Link |
They are AVS filters
https://www.rationalqm.us/mine.html |
#31880 | Link | |
***EDIT So, the ones where it says 2.6 and 'above', can I then just drop them in my new AVS+ plugins folder or do I have to put them in my old 2.6 plugins folder? |
