Old 14th March 2019, 11:31   #841  |  Link
Natty
Noob
can someone help me in removing ghosting/blending in this clip ? i dont understand exactly what type of artifact is this. i tried plain qtgmc + srestore and
QTGMC(Preset = "Slower", InputType=0, NoiseProcess=0)
srestore(mode=4, thresh=44)
but cant fix it completely or reduce it to minimum. heres the sample source and encoded clip
https://www34.zippyshare.com/v/wpy3Lzha/file.html
Natty is offline   Reply With Quote
Old 14th March 2019, 20:11   #842  |  Link
SaurusX
I didn't look, but I can immediately recommend not using QTGMC as your detection clip for sretore. The best results come from simpler bobs. However, you can still using the frames generated by QTGMC by running both at the same time like so:
FFmpegSource2("....")
d=TDeint(mode=1, type=2, full=false, tryWeave=true)
srestore(frate=23.976, speed=-1, thresh=1, dclip=d, mode=4)
Yes, these are aggressive srestore parameters, so I'd suggest bumping up the thresh value until the filter stops working well. You might want to try mode=-4 also, since sometimes srestore will work better by analyzing the chroma instead of the luma. It's kind of an art using srestore since no one method seems to work best all the time.
SaurusX is offline   Reply With Quote
Old 14th March 2019, 20:26   #843  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I've also had better results sometimes by downscaling the analysis clip with ReduceBy2() after bobbing it.
Old 15th March 2019, 11:27   #844  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Here's one strange case I've been trying to fix.
https://drive.google.com/open?id=1oI...PD71KtYKHKyZsp (original clip)
https://drive.google.com/open?id=1O1...dNAplNFP5oUVnw (bobbed clip)
I tried figuring out a pattern with a that bobbed clip and it looks like 4 good frames, 2 blended ones. Then if you look closer, it looks more like 3 good frames and 3 blended ones where the middle one is a real blended mess and the surrounding frames much less so Is it something that cannot be handled by SRestore as the origins seem to be an interlaced clip?
Old 4th August 2019, 21:49   #845  |  Link
simple_simon
I'm using the latest version of the script (2.796) with the latest avisynth+ x64 and all the latest necessary plugins (masktools, etc) and I'm getting an error complaining "I don't know what 'avsplusversionnumber' means". I tried usiing 2.795 but with that one it complains about not knowing what 'dm' means. I looked at the script and both things are specified so it should 'know' what it means. What am i doing wrong? I can't find any mention of this in the previous entries of this thread.
simple_simon is offline   Reply With Quote
Old 4th August 2019, 21:56   #846  |  Link
real.finder
you need SMDegrain.avsi (v3.1.2.101s or up)
See My Avisynth Stuff
Old 4th August 2019, 23:03   #847  |  Link
hello_hello
The functions for checking the Avisynth version don't come with SRestore. They come with SMDegrain. Given it's only a few lines, I'd also include the functions with the SRestore script myself, so people won't have this problem, but that's just me and it's not up to me.
Here's what you're missing if you don't want to download the latest SMDegrain, you could add it to the end of the SRestore script if you have it in the auto-loading Avisynth plugins folder, or you could create a separate avsi file etc.
function IsAvsNeo(){ FindStr(VersionString, "AviSynth Neo") != 0 }
function IsAvsPlus(){ FindStr(VersionString, "AviSynth+") != 0 || IsAvsNeo }
function AvsPlusVersionNumber(){ \
IsAvsNeo ? eval(MidStr(VersionString(),20,4)) : \
IsAvsPlus ? val(MidStr(VersionString(),17,4)) : 0 }
Old 5th August 2019, 19:29   #848  |  Link
simple_simon
Thanks for letting me know. I thought I had latest one (smdegrain_v3.1.2.100s) but guess not. Downloading SMDegrain v3.1.2.104s solved the 'avsplusversionnumber' error but now it's throwing up "I don't know what 'dm' means" error. Anyone know what that one's about?
Old 5th August 2019, 20:03   #849  |  Link
real.finder
what is your full srestore line?
Old 5th August 2019, 22:29   #850  |  Link
simple_simon
srestore(frate=24.975, thresh=14, cache=8)
Old 6th August 2019, 01:40   #851  |  Link
real.finder
work fine for me
edit: are you using MT Prefetch() in avs+? if yes then that known thing that mt not work (yet) with real-time functions like srestore
Old 6th August 2019, 02:24   #852  |  Link
simple_simon
Ahhh! That's what it was. Thank you.
What's it mean that a filter is a realtime filter and how do i tell to avoid using prefetch with them?
Old 6th August 2019, 05:46   #853  |  Link
real.finder
http://avisynth.nl/index.php/Runtime_environment
Old 16th March 2020, 00:08   #854  |  Link
foobar2000
PAL with blends.. hard to deal with..
hi folks I came across two PAL dvds, both with blends..
the first one is progessive but I tried many filters can't fix it, seems to be hard double-telecine?
the second is interlaced with more blends, even more messy
the first one is TFF, second one BFF
here're the samples, thanks a lot
http://www.mediafire.com/file/biwgkp...PAL_blends.rar
foobar2000 is offline   Reply With Quote
Old 24th May 2020, 23:40   #855  |  Link
manolito
manolito's Avatar
Follow-up to this old post:
https://forum.doom9.org/showthread.p...34#post1844334
So using an old MaskTools version together with a new SRestore script will not work, but what about the other way around?
Using an old SRestore script (v 2.7e) with he latest pinterf MaskTools2 version? Is this safe if I stay away from Hi BitDepth and Hi Color?
Old 25th May 2020, 04:48   #856  |  Link
real.finder
if you use new masktools then why you need old SRestore?!!
anyway it should work, new SRestore should also work with old masktools2 in avs 2.5 but new SRestore in avs 2.6 or avs+ will need new masktools2
Old 25th May 2020, 12:39   #857  |  Link
manolito
manolito's Avatar
The reason because I want to keep the old SRestore script is that I use at least three different computers for my video conversions, and one of them is my ancient WinXP machine with with a P3 Coppermine CPU (no SSE2), and I do not want to maintain different plugin folders with different versions of the filters. Least common denominator, and this means using older plugins from the pre "modernization effort" era. And this old SRestore version 2.7e has always worked well for me...
Old 25th May 2020, 12:53   #858  |  Link
real.finder
you can ask pinterf for c only build
anyway you have others like 2.7i or older like 2.7g, should work with older masktools
Old 31st May 2020, 14:47   #859  |  Link
real.finder
hope this will make you happy https://www.solidfiles.com/v/nDeywNzjnKyKG
it's the last version but build with /arch:SSE
Old 31st May 2020, 17:47   #860  |  Link
manolito
manolito's Avatar
Thanks for this build, but it does not work on my ancient WinXP machine.
I removed the old mt-masktools.dll and copied your build of masktools2 into my plugin folder. Then replaced the old SRestore.avsi with your latest version, then I also needed the file Zs_RF_Shared.avsi in the plugins folder.
When calling SRestore I got this error:
"There is no function MT_Makediff"
So it looks like my Non-SSE2 machine does not like this build...
mrestore, srestore
