30th May 2006, 21:59 | #1061 | Link |
I just ran into the bug that Inc described.
I have a 4:3 video with a resolution of 528:576. Now I cropped away 166 lines and MeGui resulted in a ratio of 37:20 (the height gets resized to 416 from 406 to be a multiple of 16). But that leads to a width fo 976 pixels and that's too much. As MeGui calculates the wrong values I have to do it myself. Now the question is how to do it correctly. As I ony cropped the heigth, the horizontal resolution has to stay at 768 as in the original video. Then the video is stretched from a height of 406 to 416 so it is streched by (416/406). So I stretch the "original" width by (416/406), too and get 768*416/406 as the new horizontal resolution. Now I have to get the ratio of the of the real height and the desired height. So I get (768*416/406)/528 as the ratio. The reduced fraction then is 3328/2233. Is that the correct AR? |
30th May 2006, 23:31 | #1063 | Link | |
31st May 2006, 07:10 | #1064 | Link | |
clueless n00b
31st May 2006, 14:29 | #1065 | Link | |
Brazilian Anime Ripper
Job completed successfully and deletion of intermediate files is activated Generating jobs. Desired size: 103809024 bytes No audio encoding. Calculating desired video bitrate directly. Encoded audio file is present: C:\encodes\2006-04-01\ygh178 T01 DELAY 0ms.mp3 It has a size of 17976704 bytes. Setting video bitrate for the video jobs to 606 kbit/s Setting desired size of video to 85185536 bytes Starting job job1-1 at 17:42:35 calling setup failed with error Could not find C:\encodes\megui\tools\xvid_encraw\xvid_encraw.exe in the path specified: C:\encodes\megui\tools\xvid_encraw\xvid_encraw.exe Please specify the proper path in the settings Starting job job1-1 at 17:43:12 encoder commandline: -i "C:\encodes\ygh1.AVS" -pass1 "C:\encodes\ygh1.stats" -bitrate 606 -kboost 100 -overhead 0 -turbo -vhqmode 1 -closed_gop -imax 31 -max_bframes 2 -bmax 31 -threads 1 successfully started encoding Processing ended at 17:43:13 ---------------------------------------------------------------------------------------------------------- Log for job job1-1 Trying to retrieve width and height from input header Wrong Framerate 0.000000 xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003 ---------------------------------------------------------------------------------------------------------- Job completed successfully and deletion of intermediate files is activated job job1-1 has been processed. This job is linked to the next job: job1-2 Starting job job1-2 at 17:43:13 encoder commandline: -i "C:\encodes\ygh1.AVS" -pass2 "C:\encodes\ygh1.stats" -bitrate 606 -kboost 100 -overhead 0 -vhqmode 1 -closed_gop -imax 31 -max_bframes 2 -bmax 31 -threads 1 -avi "C:\encodes\Yu-Gi-Oh 178.avi" successfully started encoding Processing ended at 17:43:14 ---------------------------------------------------------------------------------------------------------- Log for job job1-2 xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003 Trying to retrieve width and height from input header Couldn't open statsfile 'C:\encodes\ygh1.stats'! ---------------------------------------------------------------------------------------------------------- The current job contains errors. Skipping chained jobs
Capture cards: Compro VideoMate Gold+ (Philips SAA7134 based) (not active) Hauppauge PVR 150MCE (not active) ATI TV Wonder Elite (active) |
31st May 2006, 15:12 | #1066 | Link | |
clueless n00b
@acrespo:
Aren't you wondering why the following is in the log: Quote:
31st May 2006, 15:25 | #1067 | Link |
I get the wrong part of log. This is my first encode when I rename xvid_encraw to try a menconder encode but megui still try xvid_encraw.
This second part of the log is my encode with xvid_encraw: Log for job job1-1 Trying to retrieve width and height from input header Wrong Framerate 0.000000 xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003 ---------------------------------------------------------------------------------------------------------- Job completed successfully and deletion of intermediate files is activated job job1-1 has been processed. This job is linked to the next job: job1-2 Starting job job1-2 at 17:43:13 encoder commandline: -i "C:\encodes\ygh1.AVS" -pass2 "C:\encodes\ygh1.stats" -bitrate 606 -kboost 100 -overhead 0 -vhqmode 1 -closed_gop -imax 31 -max_bframes 2 -bmax 31 -threads 1 -avi "C:\encodes\Yu-Gi-Oh 178.avi" successfully started encoding Processing ended at 17:43:14 ---------------------------------------------------------------------------------------------------------- Log for job job1-2 xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003 Trying to retrieve width and height from input header Couldn't open statsfile 'C:\encodes\ygh1.stats'! ---------------------------------------------------------------------------------------------------------- The current job contains errors. Skipping chained jobs
31st May 2006, 15:28 | #1068 | Link |
I did other encode with the same error. Here is the log:
Starting job job2-1 at 11:27:35 encoder commandline: -i "C:\encodes\ygh1.AVS" -pass1 "C:\encodes\ygh1.stats" -bitrate 606 -kboost 100 -overhead 0 -turbo -vhqmode 4 -closed_gop -imin 1 -imax 31 -pmin 1 -max_bframes 2 -bvhq -bmin 1 -bmax 31 -threads 2 successfully started encoding Processing ended at 11:27:35 ---------------------------------------------------------------------------------------------------------- Log for job job2-1 xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003 Trying to retrieve width and height from input header Wrong Framerate 0.000000 ---------------------------------------------------------------------------------------------------------- Job completed successfully and deletion of intermediate files is activated job job2-1 has been processed. This job is linked to the next job: job2-2 Starting job job2-2 at 11:27:35 encoder commandline: -i "C:\encodes\ygh1.AVS" -pass2 "C:\encodes\ygh1.stats" -bitrate 606 -kboost 100 -overhead 0 -vhqmode 4 -closed_gop -imin 1 -imax 31 -pmin 1 -max_bframes 2 -bvhq -bmin 1 -bmax 31 -threads 2 -avi "C:\encodes\Yu-Gi-Oh 178.avi" successfully started encoding Processing ended at 11:27:36 ---------------------------------------------------------------------------------------------------------- Log for job job2-2 Trying to retrieve width and height from input header Couldn't open statsfile 'C:\encodes\ygh1.stats'! xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003
31st May 2006, 16:53 | #1069 | Link | |
The Internet: where men are men, women are men, and children are FBI Agents |
31st May 2006, 18:18 | #1070 | Link |
I did other test but this time I check "Add pre-rendering job" to generate a huff video before xvid encode. The first pass (generate huff video) was OK. The second and third pass (xvid 1pass and 2pass) was OK too. The forth pass (mux audio and video) was not OK. This is the log of forth pass:
Log for job job3-4 DivXMux: Version 6.1 Build Num: 36 Output File Streams: TrackId 0: Video Stream: From AVI Frame Rate: 23.976024 Resolution: 320x240 TrackId 1: Audio Stream: From MP3 SamplesPerSec: 48000 BlockAlign: 1 Creating Index... ---------------------------------------------------------------------------------------------------------- Job completed successfully and deletion of intermediate files is activated But the final video is gray. I can't see anything in the video. Then I did a manual mux in virtualdubmod and the final video is OK. During add job to queue, the "Automatic Encoding" window (pressing Autoencode button), show Container = MP4 but I choose AVI in the main screen. I change to AVI in this window, check "Add additional content" and press Queue. In "Adaptative Mux" window the settings are the same of .MP4 container (Audio 1 and 2, Subttitles chapter etc) but I choose AVI in last window. I think this is the problem of Mux process.
31st May 2006, 19:55 | #1071 | Link |
clueless n00b
@acrespo: parts of your log for the last error are still missing... it's better to post too much information than too little.. we can always disregard information that's not pertinent.. but finding information that is pertinent but hasn't been posted is another story entirely
Can you open your Avisynth script from the failed video jobs in VirtualDubMod? Because what the log says is that there's a problem opening your AviSynth script.
31st May 2006, 20:31 | #1072 | Link |
I try to use WinAmp CT AAC with MeGUI (fully updated to the latest files). Here are the settings I use:
I get the following log: Code:
Starting job job1 at 10:31:04 μμ encoder commandline: successfully started encoding Processing ended at 10:31:04 μμ ---------------------------------------------------------------------------------------------------------- Log for job job1 Channels=6, BitsPerSample=16, SampleRate=48000Hz D:\Backup of Programs\Ripping\MeGUI\tools\encaacplus\enc_aacPlus.exe - "D:\DVDs\MOULIN_ROUGE\Test\Original_Sound.mp4" --rawpcm 48000 6 16 --cbr 128000 --nopsError: System.ApplicationException: Can't start encoder: Cannot process request because the process (1588) has exited. ---> System.InvalidOperationException: Cannot process request because the process (1588) has exited. at System.Diagnostics.Process.GetProcessHandle(Int32 access, Boolean throwIfExited) at System.Diagnostics.Process.set_PriorityClass(ProcessPriorityClass value) at MeGUI.AviSynthAudioEncoder.createEncoderProcess(AviSynthClip a) --- End of inner exception stack trace --- at MeGUI.AviSynthAudioEncoder.createEncoderProcess(AviSynthClip a) at MeGUI.AviSynthAudioEncoder.encode() ---------------------------------------------------------------------------------------------------------- |
1st June 2006, 00:57 | #1074 | Link |
Curious BetaTester
using 0.2.3.2157
just tested the ct-aac encoder i set it to produce, a 48khz 192kbps joint stereo no-ps file but it produced this: Log for job job1 Channels=2, BitsPerSample=16, SampleRate=48000Hz D:\Utils\AV\DVD\Me.GUI\tools\encaacplus\enc_aacPlus.exe - "D:\DVD-Rips\test\VIDEO_TS\VTS_03_1 T01 2_0ch 192Kbps DELAY 0ms.aac" --rawpcm 48000 2 16 --cbr 192000 --nops******************************************************************** * AACPlus v2 Encoder (using Winamp 5.2 enc_aacplus.dll) * Source timestamp Mon May 15 17:24:26 2006 * Build May 15 2006, 17:24:35 ******************************************************************** * NOTE! enc_aacplus.dll must be into executable directory * get it from Winamp 5.2 plugins directory * tested on Winamp 5.2 Release Feb 23 2006 Full (Not Pro) version) ******************************************************************** Input file: - Output file: D:\DVD-Rips\test\VIDEO_TS\VTS_03_1 T01 2_0ch 192Kbps DELAY 0ms.aac SampleRate: 48000 ChannelCount: 2 BitsPerSample: 16 Bitrate: 128000 ChannelMode: Stereo Encoder: aacPlus v2 (HE-AAC+PS) Done
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC Last edited by cc979; 1st June 2006 at 01:10. |
1st June 2006, 01:12 | #1075 | Link | |
1st June 2006, 01:41 | #1076 | Link |
aka Rabomil
0.2.3.2156
Commit by berrinam: - Fix the mp4/aac bug with AutoEncoding. ------------------------------------------------------------ Generating jobs. No desired size. User doesn't care what the filesize is. Leaving bitrate/qp/crf at the profile's valueStarting job job6-1 at 2:19:21 encoder commandline: successfully started encoding Processing ended at 2:19:44 ---------------------------------------------------------------------------------------------------------- Log for job job6-1 Channels=6, BitsPerSample=16, SampleRate=48000Hz D:\Program Files\megui\tools\neroaacenc\neroaacenc.exe -ignorelength -lc -q 0.2 -if - -of "E:\Samples\Saving Private Ryan T02 3_2ch 448Kbps DELAY -176ms.mp4"************************************************************* * * * Nero Digital Audio Reference MPEG-4 & 3GPP Audio Encoder * * Copyright (C) 2006 Nero AG * * All Rights Reserved Worldwide * * * * Package build date: May 1 2006 * * * * See -help for a complete list of available parameters. * * * ************************************************************* ---------------------------------------------------------------------------------------------------------- Job completed successfully and deletion of intermediate files is activated job job6-1 has been processed. This job is linked to the next job: job6-2 No desired size. Continuing without making any changes. Starting job job6-2 at 2:19:44 encoder commandline: --crf 20 --ref 3 --mixed-refs --no-fast-pskip --nf --no-cabac --subme 7 --analyse p8x8,b8x8,i4x4 --me umh --progress --no-dct-decimate --no-psnr --output "E:\Samples\SPR.m4v" "E:\Samples\SPR.avs" successfully started encoding Processing ended at 2:25:18 ---------------------------------------------------------------------------------------------------------- Log for job job6-2 avis [info]: 720x400 @ 25.00 fps (1500 frames) x264 [info]: using cpu capabilities MMX MMXEXT SSE 3DNow! x264 [info]: slice I:11 Avg QP:21.73 size: 36093 x264 [info]: slice P:1489 Avg QP:24.78 size: 14034 x264 [info]: mb I I16..4: 25.8% 0.0% 74.2% x264 [info]: mb P I16..4: 6.3% 0.0% 12.5% P16..4: 40.5% 24.1% 4.7% 0.0% 0.0% skip:11.9% x264 [info]: ref P 75.6% 16.1% 8.3% x264 [info]: kb/s:2839.1 encoded 1500 frames, 4.51 fps, 2839.17 kb/s desired video bitrate of this job: 20 kbit/s - obtained video bitrate (approximate): 2839 kbit/s ---------------------------------------------------------------------------------------------------------- Job completed successfully and deletion of intermediate files is activated job job6-2 has been processed. This job is linked to the next job: job6-3 Starting job job6-3 at 2:25:18 encoder commandline: -add "E:\Samples\SPR.m4v" -add "E:\Samples\Saving Private Ryan T02 3_2ch 448Kbps DELAY -176ms.mp4" -fps 25 -new "E:\Samples\SPR-muxed.mp4" successfully started encoding Processing ended at 2:25:21 ---------------------------------------------------------------------------------------------------------- Log for job job6-3 MPEG-4 Video import - 0 x 0 @ 25.0000 FPS Indicated Profile: Simple Profile @ Level 1 Import results: 0 VOPs (0 Is - 0 Ps) IsoMedia import - track ID 1 - Audio (SR 48000 - 6 channels) Converting to ISMA Audio-Video MP4 file... Saving E:\Samples\SPR-muxed.mp4: 0.500 secs Interleaving Adjusting visual track size to 0 x 0 ---------------------------------------------------------------------------------------------------------- Job completed successfully and deletion of intermediate files is activated ---------------------------------------------------------------------------------------------------------- Actually, I used v2157 The muxed file does not play video in MPC, Nero Showtime and XBMC, but the audio does. The muxed filesize really is audio + video. The m4v file does not play seperately. The mp4 (audio) file does play seperately. Last edited by Limobar; 1st June 2006 at 01:55. |
1st June 2006, 02:29 | #1078 | Link |
Curious BetaTester
using 0.2.3.2159
if i manually create .mp4/.aac and mux them they play using autoencode the video part of the .mp4 have extra data in the file, which makes it not play - mediainfo says it is 0x0 0fps mpeg4 video here is the extra data: @31 bytes into the x264 - core 47 svn-530M - H.264/MPEG-4 AVC codec - Copyleft 2005 - http://www.videolan.org/x264.html - options: cabac=1 ref=16 deblock=1:1:1 analyse=0x3:0x133 me=umh subme=7 brdo=1 mixed_ref=1 me_range=16 chroma_me=1 trellis=2 8x8dct=1 cqm=0 chroma_qp_offset=0 slices=1 nr=0 decimate=1 bframes=3 b_pyramid=1 b_adapt=1 b_bias=0 direct=3 wpredb=1 bime=1 keyint=250 keyint_min=25 scenecut=40 rc=2pass bitrate=1000 ratetol=1.0 rceq='blurCplx^(1-qComp)' qcomp=0.60 qpmin=10 qpmax=51 qpstep=4 cplxblur=20.0 qblur=0.5 ip_ratio=1.40 pb_ratio=1.30
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC Last edited by cc979; 1st June 2006 at 02:31. |
1st June 2006, 03:00 | #1079 | Link |
Curious BetaTester
using 0.2.3.2160
the autoencode works fine now, cheers i've tried lowering the bitrate and changing stereo-modes on ct but it still produces ps/sbr when not asked to
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC |
1st June 2006, 06:43 | #1080 | Link | |
