Go Back   Doom9's Forum > Video Encoding > (Auto) Gordian Knot
Old 9th September 2011, 19:01   #21  |  Link
Taurus
Taurus's Avatar
DgIndex, which is used for indexing/preparing the vob file spits out a repaired d2v file on your vob sample.
You can verify this and look in the AutoGK/Tmp folder for a *d2v.bad file.
Have a look in the DGIndex Help manual what this means
I think it's from cutting at non I frame.
Another thing to try:
Dont load the ifo file, just use the Vob files as input for AutoGk.
This is all from aging memory.
I dont use AutoGk anymore.
Got some new toys
Taurus is offline   Reply With Quote
Old 10th September 2011, 17:56   #22  |  Link
manono
Don't forget the AC3 filter. Neither Windows nor AutoGK comes with the ability to play AC3 audio:
http://www.videohelp.com/tools/AC3_Filter
Old 10th September 2011, 20:55   #23  |  Link
CWR03
Custom User Title
CWR03's Avatar
Originally Posted by iamkeq
ill try the xvid reinstall, again see if that helps, but thank you for taking a look at that file
Xvid is a video codec. You're having problems with audio. Just reinstalling Xvid will do nothing. Uninstall everything Taurus mentioned and install ONLY AutoGK and AC3Filter..
CWR03 is offline   Reply With Quote
Old 11th September 2011, 12:33   #24  |  Link
hello_hello
Once you get VirtualDub opening the AVIs again if you can't solve the problem it might still pay to upload a sample of a "problem" AVI too. Given you say the audio in those AVIs doesn't work when trying to play them on three different PCs, it might help if someone can look at them and/or see if they'll play on their computer.
Old 12th September 2011, 11:58   #25  |  Link
iamkeq
well i reinstalled basically everything and it seems to have done the trick. at least for now
thank you for all the help
iamkeq is offline   Reply With Quote
