Old 20th May 2013, 15:59   #15201  |  Link
wanezhiling
First?
Old 20th May 2013, 16:25   #15202  |  Link
pearlblack15
This could really be a noob question but what good is it to enable HW deinterlacing when using QuickSync Decoder? Deinterlacing is enabled in MadVR (if in doubt) and set to auto in LAV. Based on the discussion here and here, you said MadVr would be more efficient in doing so assuming Madvr is 'completely' GPU oriented.
pearlblack15 is offline   Reply With Quote
Old 20th May 2013, 16:42   #15203  |  Link
nevcairiel
There are other use-cases than simple playback, where it is useful. Not always is a renderer involved, or there is some processing before the renderer which needs progressive video. Its all about the options.
Old 20th May 2013, 19:17   #15204  |  Link
pearlblack15
Well, I just want the videos to play and have better picture quality, atleast that which can be achieved with the GPU handling almost every processing. CPU heat annoys me (I have mobile Platform).
So, I have QS Decoder HW Acceleration enabled in LAV and using MadVr, although 'avcodec' is better compared to Quicksync decoder. Therefore, I am good to go with HW deinterlacing option disabled in LAV and let MadVr handle it ? Because, both will be using GPU to do the same kind of work. But if disabling Deinterlacing in renderer and enabling HW Deinterlacing in LAV gives me something better without performance hit or costing the CPU , I would be glad to enable it. Otherwise this line is good:
"For a pure playback chain with no CPU post processing at all, in theory there should be no benefit letting LAV Video do the hardware deinterlacing instead of the renderer" - madshi
________________________________________________
#Just trying to learn
Old 20th May 2013, 19:20   #15205  |  Link
paradoxical
Posts: n/a
As nev says, LAV can be used in instances where there is no renderer involved (such as using it in conjunction with DirectShowSource in AviSynth). So if one wants hardware-accelerated deinterlacing it's beneficial in such a case.
Old 20th May 2013, 20:57   #15206  |  Link
ThurstonX
total noob question...
...but I have to ask.
I understand that in order to use MPC's built-in audio delay feature, I need to enable its Audio Switcher. By doing so, am I missing out on anything in LAV Audio? I prefer the ability to tweak the delay via the keyboard.
I have MPC set up to prefer all three LAV elements in External Filters.
ThurstonX is offline   Reply With Quote
Old 20th May 2013, 20:58   #15207  |  Link
pearlblack15
and thanks Nev, for his excellent work. And good luck with the project Since v 0.56, it saw great improvements in performance!
Old 20th May 2013, 21:12   #15208  |  Link
derpycat
ooo. thanks for the update!
does the last change in the changelog render madflac obsolete...?
also quick question, what's the correct install procedure - uninstall and then reinstall?
thanks =3
derpycat is offline   Reply With Quote
Old 20th May 2013, 21:22   #15209  |  Link
paradoxical
Posts: n/a
No, you aren't.
Old 20th May 2013, 21:43   #15210  |  Link
ThurstonX
Originally Posted by paradoxical View Post
No, you aren't.
Excellent. Thanks for the quick reply.
Old 20th May 2013, 22:04   #15211  |  Link
mastrboy
Question related ordered chapters, just noticed a difference in behavior with the default tag for subtitles between Haali and LAV splitter.
The main video files have subtitle track 3 as default and the OP/ED which is in separate files for the series has subtitle track 1 as default, Haali switches from subtitle track 1 to subtitle track 3 when done playing the Opening and correctly switches back to track 1 when starting to play the Ending file in the virtual timeline.
LAV splitter stays on track 1 throughout the entire virtual timeline without "honoring" the default track tag in mkv.
Is this intended behavior?
(i have a tendency to drunk post)
mastrboy is offline   Reply With Quote
Old 21st May 2013, 10:14   #15212  |  Link
itsonlyjustincase
Does the latest Lav 0.57 includes the latest intel QS 0.42 ?
itsonlyjustincase is offline   Reply With Quote
Old 21st May 2013, 10:14   #15213  |  Link
nevcairiel
No, it does not. I didn't have time or a Win8 system to test on right now, and i don't include untested updates.
Old 21st May 2013, 10:17   #15214  |  Link
itsonlyjustincase
Thank you for this feedback .
Old 21st May 2013, 12:49   #15215  |  Link
AndreaMG
AndreaMG's Avatar
LAV Filters 0.57
- Added a Popup Menu to the Tray Icon which allows Stream, Edition and Chapter switching
Thanks Nev.
Raven RVZ01 * i7-4790k * 16GB RAM * Zotac GTX 970 4G * SSD 850Evo 500GB * Blu-Ray Burner Slot-In * PSU SFX 80+ Gold 450Watt * Windows 10 64bit * MPCHC+MadVR+SVP * Panasonic 50" VT30 ^^
AndreaMG is offline   Reply With Quote
Old 21st May 2013, 15:47   #15216  |  Link
Andrey /MAG/
SVP developer
Hello Nev.
I see good working HW deinterlacing with QuickSync in new LAV Decoder. It makes 50 fps from 25i source. Thanks!
But CUVID HW deinterlacing stop working to me. It gives only 25 fps from the same 25i source. Option "50p/60p (Video)" is selected. What I do wrong?
Core i5-3570K + GTX 660 Ti
Andrey /MAG/ is offline   Reply With Quote
Old 21st May 2013, 16:15   #15218  |  Link
nevcairiel
If you want to switch decoder on stream switch, you need to activate the option "Remove Audio Decoder on Audio Stream Switch"
Old 21st May 2013, 16:24   #15219  |  Link
wanezhiling
I never notice that option...
You are a genius nev.
Old 21st May 2013, 19:05   #15220  |  Link
aufkrawall
Thanks for the new version, nev. QS deinterlacing seems to be working fine on a quick test.
