Old 3rd September 2011, 19:24   #5201  |  Link
nevcairiel
I currently have no concrete plans to support raw video input, but maybe one day..
Old 3rd September 2011, 19:37   #5202  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Originally Posted by Snowknight26 View Post
On a side note, LAV Splitter doesn't parse the 'test_audacity.wav' file in this zip.
Q.: Should LAV Splitter start supporting b0rked .WAV files?
A.: Of course it shouldn't
Midzuki is offline   Reply With Quote
Old 3rd September 2011, 19:38   #5203  |  Link
nevcairiel
That .wav file actually worked for me. Its only missing some information in the media type, so it requires LAV Audio and doesn't connect directly to the renderer.
Of course, i'm using a development version, maybe something changed in ffmpeg that wasnt in the last release.
Old 4th September 2011, 01:50   #5204  |  Link
STaRGaZeR
4:2:0 hater
nev, MPEG-4 ASP (DivX 5 and Xvid at least) in matroska causes video corruption when seeking. The problem is in the splitter, MPC's and Haali are fine. Is this a known issue or do you need a sample?
Also seeking is quite a bit slower than both of them with matroska in general, if the video has long GOPs. As if LAVS was waiting till the next keyframe or something.
Specs, GTX970 - PLS 1440p@96Hz
Originally Posted by Manao View Post
That way, you have xxxx[p|i]yyy, where xxxx is the vertical resolution, yyy is the temporal resolution, and 'i' says the image has been irremediably destroyed.
STaRGaZeR is offline   Reply With Quote
Old 4th September 2011, 06:59   #5205  |  Link
nevcairiel
Somehow those two symptoms don't match. If its waiting for the next key-frame, how can there be corruption?
I know that Matroska seeking is a bit slow on oddly muxed files, right now it'll always seek to the nearest Cue point and take it from there, which can take quite some time. Luckily most people mux their MKVs sanely with enough Cue points for smoother seeking.
I do have plans and ideas how to improve that. To avoid corruption, it does have to find a key-frame to start with, though.
Anyhow, i can't seem to find a Xvid in MKV, all i have are in .avi, so a sample which directly shows the corruption would be good.
I'll then look at it when i work on the seeking issues, which should be relatively soon. (After the next release)
Old 4th September 2011, 07:15   #5206  |  Link
betaking
Fantasy Codecs writer
betaking's Avatar
I have one files about Xvid in MKV!but is very big!
and lavfilters can not use lavvideo to decoder this mpeg file!
Format : MPEG-PS
File size : 63.1 MiB
Duration : 4mn 13s
Overall bit rate : 2 086 Kbps
Video
Format : MPEG Video
Format version : Version 1
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 4mn 13s
Bit rate : 1 789 Kbps
Maximum bit rate : 1 800 Kbps
Width : 352 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.706
Stream size : 54.1 MiB (86%)
Audio
Format : MPEG Audio
Format profile : Layer 2
Duration : 4mn 13s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Delay relative to video : -67ms
Stream size : 7.74 MiB (12%)
betaking is offline   Reply With Quote
Old 4th September 2011, 07:39   #5207  |  Link
nevcairiel
Media Info is really not helpful. Either post the media type (maybe its as simple as that), or a sample of the file.
Old 4th September 2011, 07:55   #5208  |  Link
betaking
betaking's Avatar
OK! sample download here!
http://hotfile.com/dl/128806918/a301...ME_PK.mpg.html
Old 4th September 2011, 08:15   #5209  |  Link
Carpo
Carpo's Avatar
In mkvmerge you have the options for cue points as, default, only for I frames, for all frames, and none - which would you suggest people use? Normally I just leave it on default
The Internet: where men are men, women are men, and children are FBI Agents
Carpo is offline   Reply With Quote
Old 4th September 2011, 09:19   #5210  |  Link
nevcairiel
I dunno what default does, but i guess it might be fine. Its mostly pretty old files or files not muxed with mkvmerge that have those issues.
It also depends on your encode how big GOPs are / how often a key frame is inserted.
Less key-frames may give you slightly smaller files, but of course without key-frames you cannot seek.
Old 4th September 2011, 09:21   #5211  |  Link
nevcairiel
Originally Posted by betaking View Post
That file plays just fine with LAV Video, with both LAV Splitter and the MPC-HC MPEG Splitter.
Maybe something that was fixed in the latest version, try again with the next release.
Old 4th September 2011, 10:51   #5212  |  Link
VipZ
Nev, do you have any plans to do a status page for LAV Video showing input format and colour conversions etc in use?
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1)
VipZ is offline   Reply With Quote
Old 4th September 2011, 11:19   #5213  |  Link
betaking
betaking's Avatar
i Enabled mpeg1 decoder on lavvideo,but mpc-hc still use MPEG VIDEO DECODER by System embedded!
Old 4th September 2011, 13:15   #5214  |  Link
BloodySword
BloodySword's Avatar
Only I-Frames is good because some dumb splitters or decoders may cause the named "corruption".
I try to not use mkv at all, because I don't like its design.
BloodySword is offline   Reply With Quote
Old 4th September 2011, 13:19   #5215  |  Link
kerimcem
mkv and flv thumbnails not open show added lav codec ?
great codec thanks..
kerimcem is offline   Reply With Quote
Old 4th September 2011, 14:37   #5216  |  Link
STaRGaZeR
4:2:0 hater
With ASP, you have corruption and fast seeking.
With everything else (that's why I said in general, but it's H.264 mainly), you have no corruption and slow seeking if the GOPs are long. Maybe it's always slow, but only noticeable with long GOPs, I can't know that. x264 with most presets will produce files with up to 250 frames between keyframes. That's more than 10 seconds of 23.976 video, so go figure.
It should be possible to do it better, since other splitters provide both faster seeking and no corruption.
ASP in MKV sample here: http://www.mediafire.com/?2rwv3ua3138sz78
Old 4th September 2011, 14:41   #5217  |  Link
nevcairiel
With a fast software decoder (and a fast CPU), 250 frames shouldn't be a big issue. On my system, decoding 250 frames takes about 1 second, and thats the worst case, but i do see longer seeking delays on some files, so i know that something else is going wrong, and i already have some ideas what, and i do plan to look into that soon.
With a hardware decoder, those 250 frames can take a few seconds to decode though (they typically top out around 70-80 fps on 1080p), so a higher delay is certainly possible.
Thanks for the sample, the problem is easily reproducible, that should make fixing much easier.
Old 4th September 2011, 16:03   #5218  |  Link
Stephen R. Savage
Stephen R. Savage's Avatar
nevcairiel: Is there a reason LAV Video won't connect to DVDs? It doesn't seem to be related to CSS, as I can't get it to load for decrypted discs either.
Stephen R. Savage is offline   Reply With Quote
Old 4th September 2011, 16:11   #5219  |  Link
nevcairiel
Supporting DVDs requires some special magic in the video decoder, which i just didn't put any priority on.
Old 4th September 2011, 16:24   #5220  |  Link
SamuriHL
SamuriHL's Avatar
If it was supported does that mean we could render it with madVR?
SamuriHL is online now   Reply With Quote
