Old 18th June 2010, 08:54   #21  |  Link
setarip_old
setarip_old's Avatar
Let us know when you resolve this...
setarip_old is offline   Reply With Quote
Old 19th June 2010, 10:41   #22  |  Link
Nick
One click is all it takes
Nick's Avatar
The more you tell us the less likely I think you are to resolve this with alternative software.
It sounds like a deep-rooted OS problem or possibly a hardware issue.
Reinstalling Vista may fix it. Short of that, or if that doesn't help, I would check for resource conflicts, remove any unnecessary peripheral hardware and see if it helps. Check for driver updates for all your hardware. Try running Memtest from a bootable CD to check for RAM errors. Things like this may turn something up.
I am pretty sure there will be no simple fix for this though, I'm afraid
Nick is offline   Reply With Quote
apphangb1, dvd shrink, vista
[IMG] code is Off
