#1 | Link |
FFCoder author
Avisynth Studio v1.2 Beta (OpenSource Avisynth NLE)
Latest version: 1.2 Beta (02-12-2009)
This is a video editor based on Avisynth. It requires .NET 2.0 or higher to run and has been tested on 32-bit Vista only. Download Avisynth Studio v1.2 Beta (5 MB) Download Source Code (900 KB) SourceForge.net Project Page If this program makes your life any easier, please consider donating $2 for its development. You don't need a PayPal account to donate. You can use a credit card or e-check through PayPal without having to open a PayPal account. If you are a computer professional earning money from the use of this software, then it would be nice if you could donate more. ![]() Screenshot
#2 | Link | |
Formerly davidh*****
![]() Join Date: Jan 2004
After some false starts in the past I am very interested in seeing this! David |
#4 | Link |
FFCoder author
@davidhorman
I removed the check for avisynth. Download this file: v1.0.1 Beta Can you check if the following registry key exists on your computer? HKEY_LOCAL_MACHINE\SOFTWARE\AviSynth This key is supposed to exist if Avisynth is installed correctly. |
#7 | Link | ||
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.BadImageFormatException: is not a valid Win32 application. (Exception from HRESULT: 0x800700C1)
at AvisynthStudio.frmMain.MouseMove_UpdateStatusBar()
at AvisynthStudio.frmMain.frmMain_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3603 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
AvisynthStudio
Assembly Version: 1.0.1.0
Win32 Version: 1.0.1.0
CodeBase: file:///C:/Documents%20and%20Settings/Administrator/Desktop/AviSynth%20Studio/AvisynthStudio.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\AviSynth David |
#8 | Link |
What exactly are your plans for this? How far are you willing to take it, feature-wise?
I'm getting an error too. v1.0.1 beta with 64bit mediainfo.dll Running on windows 7 64bit. System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.DirectX.AudioVideoPlayback, Version=1.0.2902.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified. Also, I find it ironic that in a video editor based on avisynth, it can't import avs scripts
#9 | Link | |
with a very similar (same?) list of exceptions to those seen by davidhorman Cheers, David. |
#11 | Link |
Very interesting!
May I suggest the option to apply a external set of filters from an .avs file to the video? This way people will easily load and use their favorite tools and it will probably be a simpler way to add complex filters. Good luck with your project. |
#13 | Link | |
FFCoder author
There should be two values under that key: (Default) = "Path to avisynth's install folder" plugindir2_5 = "Path to plugins folder" Can you please confirm this? This program has not been tested on 64-bit windows. I have no idea why those exception are being thrown. I don't have a copy of 64-bit windows now. I'll test it later. |
#14 | Link |
FFCoder author
All those people who are getting 'Microsoft.DirectX.AudioVideoPlayback.dll' not found error, please install download the dlls from the internet and put them in the application folder. You will need two DLLs:
Microsoft.DirectX.AudioVideoPlayback.dll Microsoft.DirectX.dll The second one should be there on your system already. The reason I didn't include it with the download is because I thought these files are available on every windows PC. I think these files are part of the DirectX 9c Update but i'm not sure. Download it off the internet or install the latest DirectX 9c update |
#15 | Link | |
David |
#16 | Link | |
FFCoder author
Parsing an avisynth script and loading it is an insanely difficult task. So i'm using an XML based project file for saving and loading settings. |
#18 | Link | |
Edit: sorry, your post may not apply to me, I'm having different errors. David Last edited by wonkey_monkey; 19th November 2009 at 17:24. |
#19 | Link | |
Wow - you're doing what so many people have talked about for years...
![]() v1.0.1 Beta works runs fine here on Vista(Used run as Admin...) Now, how can we help? ![]() There are Tango icons for NLEs here. Some bugs: - I'm getting an error thanks to sample_type=32bit, which should be sample_type="32bit" in the blankclip function when importing other than mpg(avi, flv). I'm using Avisynth 2.60 beta. - If I split a clip into two clips: A and B and change the order to B and A the B part will come out black and silent. On features: Locking/unlocking video and audio is a must IMHO. Import of avisynth scripts. Quote:
To make sure that variables in the imported scripts will not interfere with each other you should use the import("avisynth_script.avs") from within a function. When you got that part down. You could add AvsP as an external tool to allow users to open the scripts up in and edith them and when they colse AvsP(after saving the script under tha same name - just recheck the script for errors.
DVD slideshow GUI(Freeware). Last edited by tin3tin; 19th November 2009 at 21:54. |
#20 | Link | |||
FFCoder author
Importing an avisynth file as a source media can be done. I'm aware of the Import function. The problem is that I'm using MediaInfo for analyzing imported files. MediaInfo can't read info from AVS files. I will have to use ffmpeg or mplayer which will add another 5 to 10 MB to the download package. I'll do it later. All the video filters displayed in the GUI will be loaded using definitions from an XML file. I'll need help defining all the video filters. There are more than 100. I'll add a simple editor for editing the definitions. Quote:
![]() Quote:
you can position the audio and video clips by dragging them along the timeline so that their start position are aligned together. You don't need to worry about the audio and video going out-of-sync. Locking the audio and video clips together so that they can be moved as a single unit will require some work. I'll do it later. its not a priority right now. I'll add it. Last edited by teejee2008; 20th November 2009 at 05:39. |
| Tags |
| avisynth, nle |
| Thread Tools | |
| Display Modes | |
