Old 21st September 2019, 12:36   #1  |  Link
wolflop
Scenarist UHD Dolby Vison How to do?
Can someone explain to me what additional steps are necessary with scenarist 1.2, for 1x movie with chapter and an audio stream. Hdr goes without problems with the previous versions ... It's just about the additional steps ...
wolflop
wolflop is offline   Reply With Quote
Old 22nd September 2019, 19:55   #2  |  Link
ocean
Hi wolflop, Data Editor:
Clip Editor:
Stream Editor:
Insert SubPlayItem:
Final Result:
ocean is offline   Reply With Quote
Old 22nd September 2019, 20:25   #3  |  Link
wolflop
Thanks ocean for the screens. I try it with your help...
I'll contact you if it has been cut.
wolflop
Old 29th September 2019, 08:31   #4  |  Link
wolflop
Unfortunately, I am already failing to import the mpls files, since I normally use the mui genertor to generate *.ves files and imported them.
Can you explain the procedure even more exactly?
wolflop
Old 29th September 2019, 19:05   #5  |  Link
ocean
Yes, scenarist generates 3 files with extensions: mui, ves, xui, to extract the streams you can use eac3to, by selecting the main playlist:
https://www.videohelp.com/software/eac3to
rename the extensions files from H265 to hevc, use the mui generator and import in the data editor, or if you prefer to drag & drop the selection into the data editor directly.
Old 3rd October 2019, 08:20   #6  |  Link
wolflop
Hello ocean,
At the moment I am stuck with the "insert of the subplay item" ... I do not know how to get to the window Subplayitem settings. In addition, when will Audio / Chapter and Sub be inserted. Only after Dolby vision is done or already at the beginning of the Data Editor / Streamtree?
Old 3rd October 2019, 15:56   #7  |  Link
ocean
Hi, insert audio/chapter and subtitles first, then create the dolby vision track, to do this drag Clip: 00026.track_4113.hevc over SubPath#1, give it ok and it should create Enhancement layer, look at the 4 image above.
Old 3rd October 2019, 18:16   #8  |  Link
wolflop
hi ocean,
Thank you for your help. Will test it as specified by you. I'll contact you if it worked. Since you have idea of scenarist ... maybe you can tell me how I can put a trailer (like Thx-trailer) before the movie, which is automatically played before the film starts. And how to convert a movie clip into a with mui-generator accepted hevc file.
No one here could help me ...
Best wishes
wolflop
Old 3rd October 2019, 20:37   #9  |  Link
wolflop
It worked as well.Fine!! Thanks again. A minor problem has occurred after the mux. See pictures ... How could that be the layers are green, i. E. OK. Nevertheless the error message. Film is playable.
I have not burned the movie yet.
wolflop
Old 4th October 2019, 13:52   #10  |  Link
ocean
Yes, it should work anyway, you could try the entry: Max Transfer Rate, use the LTR or HTR zones, but it is likely to get the same error, since version 1.3.1 of scenarist have solved this error:
https://www.scenarist.com/scenarist-uhd-v1-3-1/
Old 5th October 2019, 06:23   #11  |  Link
wolflop
"Maybe you can tell me how I can put a trailer (like Thx-trailer) before the movie, which is automatically played before the film starts. And how to convert a movie clip into a with mui-generator accepted hevc file. "
Did you have any idea about this?
wolflop
Old 25th November 2019, 15:56   #12  |  Link
Editfan
wolflop
hevc file is an elementary stream.
for the moment I know TmpGE Video Mastering Work 6 does it very well.
You can set GOP and many other speciment.
Then you can import video through Mui Generator.
TmpGE accepts almost all video files UHD and not.
About trailer, have you tried to create an HDMV file and put it between FirstPlay and Menu or directly in FirstPlay folder.... depending what you need.............
Editfan is offline   Reply With Quote
Old 11th December 2019, 10:35   #13  |  Link
wolflop
Thanks for your Infos. I will try IT. Did you have an Link for Tmpg Work 6?
wolflop
Old 2nd May 2023, 18:19   #14  |  Link
Lucius Snow
Hi all,
I know this is an old tutorial but someone may help.
I followed it successfully, I think. However, Mediainfo doesn't indicate any Dolby Vision metadatas inside the Enhancement Layer of the .m2ts. Does it look normal?
Video #1
Menu ID                                  : 1 (0x1)
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Codec ID                                 : 36
Duration                                 : 3 s 720 ms
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 25.000 FPS
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : BT.2020
Mastering display luminance              : min: 0.0001 cd/m2, max: 1000 cd/m2
Video #2
Menu ID                                  : 1 (0x1)
Format                                   : HEVC
Codec ID                                 : 36
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bit depth                                : 10 bits
But BDEdit sees it:
Lucius Snow is offline   Reply With Quote
Old 2nd May 2023, 18:41   #15  |  Link
ocean
Hi Lucius Snow, yes, the second track is 1920x1080 4117 (0x1015) Dolby Vision.
Old 2nd May 2023, 18:57   #16  |  Link
Lucius Snow
Thank you Ocean.
Look at this other Mediainfo capture from another .m2ts:
The metadata mention profile 7 and the RPU. I'm wondering why it's different here.
Old 2nd May 2023, 21:02   #17  |  Link
ocean
Try scanning with BDinfo.
Old 2nd May 2023, 23:08   #18  |  Link
Lucius Snow
BDInfo can't read the playlist. Strange...
Please find the ISO test here:
https://www.mediafire.com/file/k36nw...TestY.iso/file
PowerDVD can play it.
Thanks for your help.
Old 3rd May 2023, 01:16   #19  |  Link
ocean
BDinfo seems not to see it because it is very short, however Dolby Vision is recognized, look in the P.M.
Old 3rd May 2023, 09:34   #20  |  Link
Lucius Snow
Thank you very much!
